ISO 9001:2000 Clause 4.1e Monitor, Measurement of Processes, etc.
Marc
Fully vaccinated are you?
4.1e Monitor, Measure... Processes
Comments anyone?
"Leon Poels" wrote in message news:[email protected]
> Hi,
> I'm updating our quality system to the new standard now.
> In chapter 4.1e of ISO 9001-2000 it is stated that we have to "monitor,
> measure and analyse" -skip- "the processes needed for the quality management
> system and their application throughout the organization".
> My question now is: which processes are meant here? I can hardly imagine any
> processes needed for the QM *system* in our company; I can imagine, though,
> our production processes, but that's not what is stated here.
> Does anybody know for quite sure?
> Thanks,
> Leon
Newsgroups: misc.industry.quality
Subject: Re: ISO 9001-2000 Which processes are these?
Lines: 44
Date: Sat, 13 Jan 2001 21:39:24 GMT
Leon,
I'm glad I'm not the only one who thinks that line is little vague. When I first skimmed through the standard, I thought it was odd.
After looking at 4.1 for a while, I finally saw the Note at the bottom which says that it does include "processes for management activities", which presumably includes internal audits and management reviews, and implies that they were mainly talking about production processes. This raises the question of how one "measures" an internal audit or management review.
But it seems really strange to call a production process a process "needed for the quality management system".
Brian O
David Mullins
My advice would be to not get hung up on anything the standard contains in clauses 4.1 or 4.2.1 as these are all encompassing statements which have detailed requirements spread throughout the standard.
In the case of monitoring, measuring, etc, a good place to start is 8.2, which is curiously titled 'monitoring and measurement'!!!!
O
Oscar
I took an ISO 9001 transition course in August from a gentleman that sat on the commitee that rewrote the standard (TAG-76 or whatever). He explained that the processes referred to are QMS processes and not production processes. His suggestion was to prepare a flow chart of all processes in your unique QMS and then define criteria, methods, how you will measure and monitor each of the identified processes.
I don't know if this helps but I am interested in what others have to say on this subject.
David Mullins
A former employer had a massive amalgamation of businesses after I left, with each former company being certified/registered. Certification to 9002 was then also amalgamated by the thrid party auditor. Consequently the system/s were left to decay, with the former employers staff still using the documents written several years ago.
This would appear to be just fine under 9001:2000!
An auditor asks three questions (let's pretend):
1. What do you do?
2. where does it tell you to do it like that?
3. Show me the proof/evidence/records.
An auditee can now respond (provided we are talking about following the "SIX" procedures rule):
1. None of your business.
2. Nowhere.
3. Don't require any.
QUESTION:
So what will you include in 5.6.2 where it requires management review to include process performance and product conformity?
[This message has been edited by David Mullins (edited 15 January 2001).]
David Mullins
Let me take the subject of records one step further. We need to have a procedure for doc control, right? (ISO SIMON SAYS)
BUT, 9001:2000 doesn't require us to keep records of document control.
The only records required, and I've verified these against the final standard, are detailed at http://www.iso.ch - Dead Link - was /9000e/2000rev_7e.htm
Implications - a simple example:
5.3 requires that the quality policy is reviewed, but it doesn't require us to keep any records of these reviews. Hmmm.
G
gutieg
See the introduction of ISO 9004: 2000, point 0.2 Process approach. This paragraph defines and explains the concept and provide a graphical description of the model of a process-based quality management system.
What are those processes ? The sequence of inter-related tasks, responsibilities and actions needed for the organization to run with compliance to the requirements of the customers. The standard provide guidelines and "shalls" that need to be addressed.
G.G.
Alf Gulford
I'm still pretty vague on the finer points of 9000:2000, particularly in the area of what documentation is required, but I always go back to the FDA philosophy: "If it isn't documented, it wasn't done." I have to believe that any ISO registrar will adopt the same viewpoint when looking for evidence of document control, management reviews or anything else.
Ron Byrge
If you do anything related to the QMS, from a Registrar's point of view, it'll need to be documented. If it isn't recorded, dated and approved...it didn't happen, and you aren't complying with 4.2.3, a thru g. If you think you are complying, then prove it to me by showing me records. *smile*
Ron Byrge
Operations Manager
CwC Registrar, Inc.
http://cwcregistrar.com
David Mullins
Yes - QMS - Records - Yes.
Ron, people may translate your post to mean you are advocating the hard line on documenting everything about everything.
The reality of your post is an endorsement of the 6 procedures approach, is it not?
"If you do anything related to the QMS"
Ah, but what is in the 2000 concept of a QMS? Easy:
Write two procedure, one for auditing and one for corrective action (Control of nonconformity and preventive action are generally covered in this procedure anyway).
Now write a third procedure about how you will control the first two procedures. Now put the 3 procedures in a pot with a policy and some objectives. Stir, simmer for 1 month, then serve to the nearest auditor. Now put it all on the shelf, until you need it next time, and get back to business.
2 minute QMS c/- ISO Simon Says!
Ron Byrge
What I mean is that if you change anything in the system, or the documentation that describes the system (procedures, work instructions, flow diagrams...whatever), you need to review and approve the changes, and retain records of those changes. You need to ensure the changes don't compromise the integrity of the system, and the only way to do this is to review the records you've made of the changes.
As for documenting everything about everything, that's not necessarily needed. But, if you discover a problem in a process that has historically been stable, then the records you've made will be indispensible in troubleshooting the process, hence, those records are required by inference in the new revision of the standard.
Does it spell out for you exactly what records are needed?? Yes and no...you need to use your head when determining what is and isn't needed, and not try to cut corners just because the standard doesn't specifically tell you what records are needed...make the system work FOR you and not against you.
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
