simon999
4.2.3d - Document Management Systems, Passwords and Points of Use
I would be very grateful if you could help me with the interpretation of the following clause in ISO9000:2000: -
Section 4.2.3d states “relevant versions of applicable documents are available at points of use”
The part that I need help with is “points of use.”
In the company that I used to work for, I was responsible for the procurement of a document management system (DMS) for our department.
When a user wants to create a document, this is done from within the tool by selecting an appropriate document type (e.g. Test Specification). The DMS then creates the document from the correct template and gives the document an appropriate number and revision.
The DMS therefore enforces correct use of document templates and the company’s numbering and versioning rules.
However I was then told that the DMS was not compliant with ISO9000 because users had to log on to the DMS using a user-id and password.
To access the DMS users had to: -
1) Log on to the their PC using their user-id and password
2) Click on a shortcut for the DMS.
3) Log on to the DMS by entering their normal PC user-id and password.
Even though every user in the department had their own DMS user-id (which was the same as their normal PC/network user-id), I was told that this was not “point of use” and therefore was not compliant with ISO9000.
As a result, all the document templates were then copied to the company’s intranet, which was not password protected once the user had logged on to the PC network.
As far as I’m concerned, this negated many of the benefits of purchasing the DMS in the first place.
Therefore, for future reference, I would very much like to know if what I was told is correct or not. Does having to enter a password contravene the “point of use” rule?
I was also given a second reason for copying the templates onto the intranet. Other parts of the company, in other countries and involved in a different field of work, did not have access to the DMS. I did not regard this as a problem because they were involved in a different field of work and would never need access to the templates and documents that my department used.
I was told that it did not matter that the other departments never needed access to our documents, they must be made available anyway, so they were all copied to the intranet.
Section 4.2.3d explicitly says “applicable documents”, so if a document or template is not normally used by a department then surely it is not an “applicable document” and therefore does not need to be “available at points of use”?
Thanks in advance for your help.
Best Regards,
Simon
Best Regards,
Simon
That gives you a lot of backbone when those interpretation battles appear.
