Hi Anton,
On definition of Planning and Control:
Though ISO9001:2000 uses the word “Control” in titles as well as clauses , there is no formal definition for it in ISO9000:2000. However. ISO/TC176/SC 2 has published a guidance doc on terminology which can be downloaded free at (broken link removed)
This document defines control as follows :
Contrl: a) Power to give orders to restrain something
b) means of restraining or regulating
c) standard of comparison for checking the results of an action or measurement
(Note: it is different from the word ‘monitor”)
Plan (Verb) – arrange in advance (an action or proposed proceeding)
(noun) - formulation or organized method by which something is to be done.
(An interesting article on this came in February 2002 issue of Quality progress by JP Russell)
We need to link the above words to PDCA cycle to get the full understanding. And that is what Jim has said succinctly .
Coming to the difference between cl 7.1 Planning of product realization and 7.5.1 Control of production and service provision.
Pl ref fig 1 of ISO9001:2K Model of process based QMS.
• It can be seen from this figure that input to the product realization process is requirements(stated, implied and obligatory) and output is product (H/W,S/W ,Service or processed matl) As such product realization process covers all processes except those related to Management Responsibility , Resource Management & Measurement ,analysis and Improvement.
Now coming to 7.5.1 Control of production and service provision. It by and large covers all we learnt in 9001:94- cl 4.3,4.4,4.6,4.7,4.8,4.9,4.10,4.11 ,4.12 and 4.15) The requirements of 7.5.1 is as follows:
The organization shall plan and carry out production and service provision under controlled conditions. Controlled conditions shall include, as applicable.
a) The availability of information that describes the characteristics of the product.
b) The availability of work instructions, as necessary,
c) The use of suitable equipment,
d) The availability and use of monitoring and measuring devices,
e) The implementation of monitoring and measurement, and
f) The implementation of release, delivery and post-delivery activities
7.1 Covers the Following:
The organization shall plan and develop the processes needed for product realization. Planning of product realization shall be consistent with the requirements of the other processes of the Quality Management System (see 4.1).
In planning product realization, the organization shall determine the following, as appropriate:
a) Quality objectives and requirements for the product;
b) The need to establish processes, documents, and provide resources specific to the product;
c) Required verification, validation, monitoring, inspection and test activities specific to the product and the criteria for product acceptance;
d) Records needed to provide evidence that the realization processes and resulting product meet requirements (see. 4.2.4).
The output of this planning shall be in a from suitable for the organization’s method of operations.
So we can say that 7.1 a,b,c&d are essentially the inputs required for 7.5.1 a,b,c,d,e,f
Anton asks another question :
“We do not have to perform planning for generic products manufacture each time an item is let out from the conveyor, do we? The planning can in this case be performed in form of a procedure defining standard operations flow”
Let us consider following aspects:
• Even though the product is same the Quality objective to be set under 7.1a need not be the same because objective with respect to QCDSM (Quality,cost,Delivery, Safety, Moorale) could be set entirely different considering the present market conditions, competitor performance, innovation in manufacturing technology and other breakthrough changes. That is the plan we make under 7.1a is not static. We need to revisit it as often as we can and as often we need to .
• As explained above 7.1b need to be revisited to evolve a new process based on new technological excellence elsewhere or by sheer benchmarking learnings (again it is not a must , but an option to re-visit all this in a closed loop form is essential- we change or we may not change the existing processes. But we need to review in the light of our new learning.
• Similary 7.1c and d may also need re-look.
ISO 9001:2000 envisages a totally dynamic systuation with multiple loops of learning.
The Changes required in 7.5.1(a,b,..f) may be triggered by Corrective action or preventive actions.(mostly CA) All the same both 7.1 and 7.5.1 are applicable except those clauses which are specifically excluded . But 7.1 may not be feasible to exclude when 7.5.1 becomes applicable as 7.5.1 gets its life from 7.1! Also PDCA cycle can not be effectively/efficiently rotated without the handshaking of 7.1 and 7.51 where it is not excluded.
Sorry for being unwontedly lengthy. Hope it elucidated the points raised.
Anilkumar
