ISO 9001:2000 Clause 7.5.2 Validation of Processes - Level II Response
howste
Thaumaturge
#11
IMO destructive testing is product testing, which can be used to validate the process.
I'm just having a hard time thinking of an example where there is no way (destructive or otherwise) to verify the output of a process.
How do you verify that an airbag or a hand grenade is going to function as intended?
Rachel
#12
Point taken...but can that logic not be applied to many situations?
For example...we have gasketing operations in our facility. We make the gasketing compound; in some cases we sell the compound to companies for their own use, and in some cases the customers supply us with parts and we apply the gasket for them.
Now, we have no way of verifying that any one gasketed part is going to function as intended, but we do have material specs that give us a good indication of the hardness/curing time/etc. of the material. That, and the products are dedsigned and developed to perform in certain environments (extreme cold/heat, moisture, etc.). We may test certain specs on the completed gaskets, like hardness and height, but we don't necessarily immerse a pair of mated parts in water to see if the set leaks. So, we're testing the product, not the process. Right?
(Does anyone know what I'm asking here?...because I'm not sure *I* am at this point!)
I guess I'm just having a hard time distinguishing between testing the product and the process - because in many cases, you test the process by achieving the required product specs.
Am I out to lunch here? :bonk:
Randy Stewart
#13
Don't Over Think It!
Rachel,
We do fastener plating here. We check our paint samples each day. If my paint viscosity is correct and the sample parts show proper plating thickness, then the parts being run on that line are considered "good".
Our processes are designed to meet a certain spec (GM, Ford, etc.) and salt spray test requirements. Once the parameters are set (spec requirements), my inputs are verified (viscosity, spin time, bake time, etc.) and my output of the process is checked (samples). My process is set. I don't need to test every piece off the line, nor do I need to do salt spray testing on each part/product.
You are doing the same. You know that given a certain weight, height and hardness, that the gasket is suppose to meet a certain performance criteria.
Todd_w
#14
7.5.2 for chemical industry
I work in the chemical industry. I CAN do destructive testing on a sample of each shipment. In my mind, if the testing meets the customer’s specifications, both the process and product have been validated. The clause reads “…where the resulting output cannot be verified”. I don’t see how this applies to my company since I can validate a representative aliquot of a homogenous mixture . The only thing I can’t guarantee is the condition of the product upon receipt by the customer. Generally, product quality complaints resulting from the production process are very low. Packaging, delivery and poor condition of the product due to transportation are our major customer complaints.
Please correct me if I’m not looking at this correctly.
Douglas E. Purdy
#15
It has been a week - You must be correct!
Todd,
I am not the one to correct you! I am searching the threads to get a better understanding of revalidation in 7.5.2, and I have hardly any chemistry in my background, but with your verification - how do you know the remainder of the product would pass the destructive test? Isn't that why it is a validation activity as oppose to verification?
Just Pondering the Difference!
Doug
Paul Simpson
#16
Why validate?
I thought we had killed off this discussion in an earlier thread.
atetsade said:
I'm not sure how to read this requirement, at all. I struggle with the following sentence under:
7.5.2 Validation of processes for production and service provision
"The organization shall validate any processes for production and service provision where the resulting output cannot be verified by subsequent monitoring or measurement."
A bit of background: “Validation of processes” has its origins in the special processes clause of BS 5750 when it first came out. The element required an organisation to consider manufacturing processes that could not be fully assessed by inspection and testing. There are some good examples above including welding, heat treatment, painting, bonding and plating. The principle for each of these processes is that the only we you can know the process has been successful is by destroying the part concerned.
• So a weld can only be fully tested by breaking it
• You can only demonstrate that heat treatment has given the correct hardness to the correct depth by taking a section and making hardness tests
And so on for all of these other processes.
Now we do not want to do this for each part that comes off the process (yield rate = 0), so hence the requirement to validate the process – if we have qualified welders and we destructively test the first few parts of a new design we provide confidence that the process will give us the standard of weld we require and we can ship good parts instead of broken pieces! But we have to control the process to ensure we keep our confidence in the process – hence the need to follow elements a to e
a) the only way to validate a process is by using known methods / knowledgeable people (e.g. development and sign off of a weld process with defined parameters following destructive test of components)
b) if we want to be confident the process is in control we may want to ensure that only known / calibrated equipment (e.g. weld sets) is used or that only qualified people (e.g. coded welders) operate the process
c) we may have work instructions for the task (e.g. weld procedures)
d) we may ask for people to make specific records to demonstrate the process has been operated in accordance with defined process methods (e.g. we ask the welder to record the weld wire feed rate, voltage, current and shield gas settings for each job)
e) periodically we go back and check that the process is still operating effectively (e.g. by destructively testing a sample part or series of parts).
But the important thing is - if you can go back and measure / inspect a part (or service) you are entitled to claim exemption from clause 7.5.2
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
