ISO 9001:2000 Clause 7.6 - Chemical company? Controls are Visual Observations
#11
Chemical Certs
Does your chemical supplier provide certifications of contents and are their sampling or measurements set to a national standard or industry standard and they can prove compliance.
If they do, use the suppliers assurance and just make sure that their monitoring & measuring process is compliant.
D.Scott
#13
Welcome Pilchard. You make a good point on certification of the base materials, but as Graeme points out, I can't see how they can mix the materials and create a new product without some sort of measurement. Whatever is used to determine the measurement must surely require calibration. Any thoughts on that portion?
Once again, it's nice to have you on board.
Dave
howste
Thaumaturge
#14
My initial thought was the same as what several here have said. But then I thought of some examples where products come pre-measured from the supplier so I don't have to. I have epoxy with part A and B that I can just empty the two containers, mix, and viola! The other day I had one of those La Choy dinners where the meat sauce and vegetables come in separate cans. It was so simple that my teenage daughter mixed them in the right proportions without blinking an eye.
In addition to the above, there are other things that do require some measuring, but exact measurements are not critical. I have a patio in my back yard that I put in by mixing bags of concrete with approximate volumes of water. My measuring devices were a 5-gallon bucket and my eyeball/shovel used to check consistency.
At the same time, there are other applications where measurement would be critical. I think the key to 7.6 is the phrase "where necessary to ensure valid results..." If any relatively small error in ratios might cause a problem, then calibrated equipment is necessary. If the specification is so broad that measurement errors don't matter, then it's not.
Cari Spears
#15
Yeah, this is why I was asking what the "visual control" is. If they just take a premade mix and fill with water or another chemical to a "fill line", what monitoring and measuring devices would there be that needed control?
Trolle
#16
"I think the key to 7.6 is the phrase "where necessary to ensure valid results..." If any relatively small error in ratios might cause a problem, then calibrated equipment is necessary. If the specification is so broad that measurement errors don't matter, then it's not".(Howste)
"Yeah, this is why I was asking what the "visual control" is. If they just take a premade mix and fill with water or another chemical to a "fill line", what monitoring and measuring devices would there be that needed control"?(Carrie Spears)
This I belive to be bullseye!
Everyone thank you for your coments, I'm sure there is more to follow.
Cheers!
bpritts
Involved - Posts
#17
To play with this a little further, it sounds like there may be some
container/vessel with a "fill to here" line.
I would think about verifying that vessel once when I put it into service,
and perhaps making sure that the same vessel remained in use with no
damage -- e.g. hadn't been replaced with a used 55 gallon drum. I have
seen stranger things. If in QS9000 I have to include the measurement
device in my system if it's on a control plan. However, the calibration/
confirmation method I use is up to me, and can take the needed precision
into account. A visual inspection for damage once a year would do the job.
Brad
Trolle
#18
Excellent thinking Brad! Your reasoning is well aligned with the paramount QMS principle of “KISS” and I’m sure everyone else contributing to this site would come to the same obvious solution - but me. I will build from your advice!
Cheers!
Trolle
#19
ddhartma said:
of 8.4a).
Please believe me that my aim here is NOT to ridicule, but to illustrate some of the perceptions that your ISO assessors may come away with. :bigwave:
Yes ddhartma, this is what I hoped my rather casual wording would trigger, nevertheless I'm sure the statements I've made is very real for many of us. In this context Your kind (?) coments will help me focus my arguments! Thanks :bigwave:
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
