ISO 9001:2000 Design and Developement
I
intrestedparty
Dear All
We need your help, We are desing, developement and manufacture of Medical Devices. We are plan for ISO 9001:2000 certificaiton. The system effective date (SED) is 01-11-2005. We are in the filed for past 6 years. Form SED we desing one product.
As per ISO 9001:2000 7.3 (Design & Developement) we need to document the design records for all existing products or just the new one product we desined after the SED.
During Audit, the existing designed product is coming into scope, Whether Auditor asks about the existing designed product details
Kindly clarify this Issue
Thanks & Reagrds
Karthi.T
For ISO 9001:2000, you would definitely be expected to comply with your new procedure for any project that starts after the procedure is implemented. If you have a project in process at that time, you MAY have a few options depending on your registrar.
One option would be to scope the procedure to exclude projects that are already in process. However, your registrar will need to see evidence that the system works, so if your only projects are those already in process, you will probably need to include them.
A second option would be to pick the project up mid stream and apply the new procedure from that point forward. However, some downstream items may depend on items that would have been completed earlier in the new process. This would force you to go back and complete those earlier requirements. The further along the project is, the less likely that you would be expected to go back. Again, if these are your only projects, you will still need to show evidence that the process works.
You do not need to go back and generate records on completed projects.
Al Rosen
intrestedparty said:
Dear All
Thanks & Reagrds
Karthi.T
If you are in the Medical Device Industry, you will need to meet ISO 13485 not ISO 9001. You can do both, but ISO 13485 is the standard required for Medical Devices at this time. There are additional requirements above ISO 9001 and some of the requirements are different. Look at the standards and compare them. Do a search here in the cove for ISO 13485 and read some of the threads. You may then have more questions to post.
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
