ISO 9001:2000 Documentation Requirements
Marc
Fully vaccinated are you?
Date: Fri, 13 Oct 2000 16:16:22 -0500
Subject: Re: ISO 9000:1994 Vs. ISO 90002000 /../Whitcomb/Robinson/Paten
In my opinion, Clause 4 of ISO 9001:2000 is auditable / audited for the same reasons Clause 4.2 of ISO 9001/2: 1994 was:
The General Requirements of clause 4.1 are met if the specific requirements of clauses 5-8 are met ( i.e. have you established a system that meets the requirements of ISO 9001:2000 ) - could be audited as follows:
Review quality manual to determine if a systematic approach is defined for:
1) identifying and managing QMS processes (or elements) in accordance with the "process approach" defined in clause 0.2 and Figure 1 of ISO 9001:2000 identifying and showing the relationship between the following QMS processes (or elements) and their related sub-processes: Clause:
* Management Responsibility
* Resource Management
* Product Realization
* Measurement, Analysis and
* Improvement
2) ensuring the criteria, methods, information and responsibilities for managing QMS processes are in place.
3) ensuring that data is collected, analyzed and used to assess QMS process effectiveness and to identify needed actions or improvements.
Likewise, The General Documentation Requirements of clause 4.2 could be audited as follows:
Review quality manual to ensure required procedures are included or referenced (per clause 5.5.5).
Review QMS documentation to determine if documented procedures are appropriate for the size and type of the organization, the complexity and interaction of processes, and competence of personnel.
Review QMS processes to ensure they are adequately defined in procedures, process or job descriptions, work instructions, or other appropriate system documentation.
Note: there are only six "required" procedures:
* Document Control (clause 5.5.6)?
* Control of Quality Records (clause 5.5.7)?
* Internal Audit (clause 8.2.2)?
* Control of Nonconformity (clause 8.3)?
* Corrective Action (clause 8.5.2)?
* Preventive Action (clause 8.5.3)?
If/as appropriate, procedures may also be "needed" for:
* Planning (5.4, 7.1, 8.1, 8.5.1)
* Communications (5.5.4)
* Management Review (5.6)
* Resource Management (6)
* Training (6.2.2)
* Customer Processes (7.2)
* Design and Development (7.3)
* Purchasing(7.4)
* Operations Control (7.5.1)
* Product ID/Traceability ( 7.5.2)
* Customer Property (7.5.3)
* Preservation of Product (7.5.4)
* Validation of Processes (7.5.5)
* Process Measurement/Monitoring (8.2.3)
* Product Measurement/Monitoring (8.2.4)
* Analysis/ Improvement (8.4, 8.5)
Review applicable standards and statutory/regulatory documents to determine if the QMS identifies required documentation and records.
Review other external or internal documents to ensure QMS identifies documentation and records needed to effectively manage the organization's products, processes and activities.
Note: Clause 4.2 requires that documentation be defined here - QMS document and record controls must be per clauses 5.5.6 and 5.5.7).
This is how I read it anyway!
Mike Paten
Marc
Date: Mon, 9 Oct 2000 13:01:46 -0500
Subject: Re: ISO 9000:1994 Vs. ISO 90002000 /van Putten/Hankwitz/Robinson
<John.Hankwitz> wrote
<snip>
> and you no longer are required to have everything you
> do documented. (You can even rip the work instruction off
> your coffee maker if you want to.) ;-)
<snip>
This is exactly the kind of actions that I feel will create all kinds of grief between registrars and clients. If you look at the preamble to ISO\FDIS 9001:2000 (also in ISO\DIS 9001:2000) clause 4.2, Documentation Requirements, states that quality system documentation shall include - item d) "documents needed by the organization to ensure the effective planning, operation, and control of its processes". Now I know that this area is not one of the auditable modules, but it is general advice to all organizations. Does anyone care to guess at how many disagreements will erupt over determining how much is "needed by the organization...of its processes"?
I personally feel that this may become the achilles heel of this version of the ISO standards, and I don't think the standard has done anyone any favours in this regard. Many companies, I fear, will adopt this attitude and either delete any documentation not specifically called up in the new standard, or just let those existing pieces fall by the wayside.
If you don't have your processes documented, how can you be sure everyone is doing things correctly? Just what way is the correct way? How can you be sure your processes have any integrity? I can see a great proliferation of industry specific standards coming into being where product quality can have life threatening impacts - medical devices, aerospace (already in place to address perceived shortfalls in the 1994 version), automotive (already in place to address perceived shortfalls in the previous versions), pharmaceuticals, chemical manufacturing, and many others. Service industries will not escape this either. Can you see hospitals not having full and complete documentation for its processes?
It will be a shame if, during the five or six year life of this version of ISO 9001, the standard becomes considered to be of less value that it currently possesses. If the Firestone/Ford situation can happen under the 1994 environment, what does the future hold for the 2000 version?
It's not a rosy picture to contemplate.
Ralph E. Robinson
Marc
The FDIS six "required" documented procedures:
Document Control (clause 4.2.3)
Control of Quality Records (clause 4.2.4)
David Mullins
It's intersting that these relate back directly to those areas that typically the "Quality Section" of a company is responsible for. This kind of suggests that it is the bare bones approach, and that if you do anything that adds value, beyond the QA stuff mentioned, then you'd better be able to back them up with something as well.
If we had a a think tank company staffed by PHD's who did little more than create ideas for industry, at no charge (funded by Hugh Heffner), and they wanted ISO 9001, then they might only need the minimum number of procedures.
Al the Elf
Ralph pondered :
"If you don't have your processes documented, how can you be sure everyone is doing things correctly? Just what way is the correct way? How can you be sure your processes have any integrity? "
We as an organisation are delighted that the standard is not being prescriptive about the need for written procedures, as we're finding it is empowering our managers to start deciding for themselves where they do or don't need procedures.
I'd also note that the new standard requires a much greater emphasis on measurement, including satisfaction of customers (or should that now read interested parties !). This must surely provide you with the evidence that you are satisfactorily controlling your processes.
Cheers, Al.
David Mullins
That very much depends on how you measure customer satisfaction. If you measure it based on customer feeedback, like complaints, it is a soft measure of the actual level of customer satisfaction - most dis-satisfied customers simply take their business elsewhere, why should they bother sorting out the performance of a company that doesn't make product that suits their needs.
And what about all the customers who don't understand - for example in the health sector, where most people have little to no idea or understanding of the quality of service they should be receiving, hence they are clueless when they've been duped. What a wave of emotion a card from the loved ones of a deceased patient makes, they thank the organisation and staff for their desperate efforts, and you know there were clinical bungles made that probably cost the life of the patient. Customer Satisfaction = 100%.
Al the Elf
David
I agree that customer satisfaction measurement can be flawed and thus meaningless, but is this any worse than having procedures that are neither read nor updated.
We are trying to turn things around to promote better measurement of the key things that matter, and I guess in the case of your example this may include how our staff feel about our performance in delivering health services. Then if the team decides it will improve (or maintain) the level of perfomance by using a procedure or written instruction, then that is what we will do. The key difference now is that the standard is not being prescriptive (with the 6 exceptions).
Your example raises another interesting issue - how far should we consider the interests of the other interested parties ?
To look at your example, in the UK, the taxpayer is an interested party in the provision (costs) of health care services. If the less than 100% service (clinically) is all that was planned to be delivered inside the budget, could you validly claim to an auditor to be creating interested party satisfaction !
Al.
David Mullins
What I'm trying to say is - be careful with customer satisfaction data if you are using complaints as the data source.
From first hand experience in one of the states of Australia (not the one I'me currently in), the ambulance service operates under an Act, which is then enforced (so to speak) by the health department. The department requires the ambulance service to report a small range of financial and transport number info. This includes the number of compliments and complaints.
One Region for example tranports 22,000 patients a year and receives nominally about 22 complaints per year. That's 99.99% Satisfaction, right? Two pilot patient surveys conducted in the same Region in the same period, although identifying a number of issues that required improvement, still recorded an overall satisfaction rating of 99%. The same Region conducts clinical inspections of the patient care records to determine clinical nonconformance and corrective action through training and reinforcement. Let's just say the clinical compliance rate was less than 90%. (Note - the only true method is direct observation of the delivery of the service)
So, we've gone from a very good process capability of 99.99% (complaint data), or a Cpk of just less than one, to less than 90% capapble, or a Cpk less than 0.4
Sometimes it's best not to know these things, but if your in business to make money you'd better be measuring real things that are critical indicators of performance.
Alas production/operation managers like measures that make them look good. Come up with something else / new, and they'll fight like a pitbull.
This is not worse than procedures that are neither read nor updated, it merely completes the illusion!
I
isodog
"Ralph pondered : "If you don't have your processes documented, how can you be sure everyone is doing things correctly? Just what way is the correct way? How can you be sure your processes have any integrity? ""
Hasn't anyone ever heard of a Work Instrauction??? It's like a Procedure but is controlled in the department where it's used.
(Much more cost effective)
Also, if you can demonstrate you omply with the requirements in, lets say, Purchasing. What difference does it make if you've documented it with a hand written memo?
David Mullins
What difference does it make?
One method has a chance of working, and the other has none.
Memo's, if even read, have a life span of a few minutes. Could you conceive that people undergoing an audit could demonstrate ready access to memos on policy? Or do we need a memo to tell us how to file memos, and should there be a color scheme for different types of memos, and do we need a memo to explain the color schemes, and another memo on retention and disposition of records.........?
For the purposes of this discussion, I'm happy to include a Work Instruction as being a controlled system document (just like a procedure). (WIs are not only controlled in a specific dept., they can be at the highest system level - e.g. a WI on Internal Quality Auditing that explains how to fill out the audit report form (if you had one))
The bottom line should of course be, what is going to work for this organisation (based on their needs, culture, etc). The number of procedures should not be based on how slack your registrar is. But as always, if you're only in it for the registration as a sales tool, then do what you must!
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
mosheeps Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
