ISO 9001:2000 - Documents Requiring Control - Documents of External Origin
Wes Bucey
#22
This seems to be an old thread. I found the initial post through Google, and it was really informative. Thanks to whoever posted it! :)
I have a somewhat silly question regarding controlling external documents. I apologize in advance for its silliness, but I figure it's better to be sure than be sorry after the audit. :D Is there a need to control communications (e.g. letters, memos) from external parties?
I also welcome you to the Cove. In my post #13 above, I touch on the concept of "control"
The essence of a document control system is to ensure documents
  • are protected from harm (or unauthorized modification),
  • are "managed" (stored and easily found and retrieved and run through an authorized revision system)
  • are "controlled" (to ensure superseded, obsolete, or unauthorized versions do not find their way into the manufacturing or other process and activities of the organization.)
This refers to documents which have an impact on the product or service you render to a customer. To determine if the document needs to be "controlled" in addition to beng retained and managed, you first have to decide if the document (correspondence) impacts the product or service (is it an order? an explanation of a print? a waiver of a requirement? OR merely a pleasantry about the weather?)
If it is worth controlling, to what extent? Do you restrict who may read? copy? implement an action based on the content?
Too often, folks go overboard in controlling documents which do not need to be controlled merely because they do not understand the spirit and intent of the word "control."
Y
Yvaine
#23
Thanks, Wes. :)
My follow-up question would be, in cases where communications with clients or external parties are handled by many different project managers, how do you manage to make sure that all those important correspondences are indeed controlled? Especially in the case of e-mails?
mirrorcrax
#24
Excellent "article", it sums up a lot of techniques to fullfill iso9001:2000 4.2.3 and 4.2.4 requirements thumbs up:agree1: :applause:
i would also like to share a couple of thoughts i use in training:
- Documents and records are the memory cells of a company, it is the means to communicate then recollect, analyze, and improve
- Documents and records are means but not an end, just like a pipe may carry water from the ground floor to the 2nd floor, having too much of such means may actually inhibit the flow all together
- Product Brochures and marketing letters are some of the documents a lot of organizations do not exercise careful control over, leading to misinforming the customer
A data flow diagram, or document flow diagram may prove useful to elaborate on the transfer of documents between different department
In regards of the project communication question,in the PMI BOK (Project Management Institute - Body Of Knowledge) there is the need to establish a communication plan prior to project initiation, where there shall be a formal agreement with all stakeholders on the form and channels of communication to be utilized and when, you may begin by classifying the nature of communication to be performed at first,such as submission of drawings, periodic reports, progress review meetings,....etc. so that you'd have all regular (expected) communication performed through previously identified channels, then any irregular communication may be classified based on what it affects, so that you's identify the relevant personnel for every element and in turn identify the recepients who would be interested in such information accordingly
Wes Bucey
#25
Thanks, Wes. :)
I can envision a system where an organization makes a primary decision whether Quality-related correspondence documents are sorted according to the product or service provided or to the customer who may receive multiple products and services.
In a company which offers "off-the-shelf" products to multiple customers, it may make sense to sort by customer, since requests and changes are probably only for quantity, shipping details, delivery dates, or a choice between regularly offered options. Hence, regardless of who in the organization communicates with the customer, ALL the correspondence should be shunted to a "customer correspondence folder," since rarely will the correspondence have anything to do with how the product is manufactured.
Where an organization produces a product or service unique to a single customer, regardless of how many other unique products are produced for the customer, correspondence should be relegated to a Product File since it will most likely affect quantity or characteristics.
The essence of modern Customer Relationship Management software is to manage and control all customer correspondence (phone, email, hard copy) so that any employee of the organization may have it all available for review when corresponding with the customer or when working on the product or service.
Does that clarify the situation of dealing with correspondence?
Y
Yvaine
#26
It does, thanks! :) My particular dilemma, actually, is making sure that each of these managers know what to do with different types of correspondences. Some people can be really stubborn even after you've oriented them about records control. :D But mirrorcrax also made a good point about establishing the communication plan during project planning. All these ideas will help me make suggestions for refining our system. :)
Scoobz
#27
Not all forms require control, in the same way that not all documents require control, obviously.
If a form is used for the recording of Quality Critical data (e.g. analytical results, batch records, works orders) then of course it is also critical that they be controlled effectively.
Many I point out that this isn't just an ISO requirement. It is a GMP requirement and one that is widely applied across many regulated industries, including where some companies do not have ISO certification (as it isn't strictly needed).
Raffy
#28
How about applying the new requirements for ISO9001:2008 for Clause 4.2.3 f " to ensure that documents of external origin determined by the organization to be necessary for the planning and operation of the quality management system are identified and their distribution controlled.
Basically my concern is how to create a provision of system for determining control for other non-manufacturing external documents, i.e. HR, Accounting and Import-Export. :confused:
Thank you very much in advance for the usual prompt attention you will give this request.
Raffy:cool:
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
