ISO 9001:2000 Process Approach - What is it? Is it 'Real'?
Is the ISO 9001 'switch' to a process approach...
  • The ISO standard now is laid out in a 'Process Approach'
    Votes: 7 16.3%
  • Companies must now adopt a 'process approach' Methodology
    Votes: 8 18.6%
  • Both of the above
    Votes: 28 65.1%
  • Total voters
    43
johnnybegood
#41
Much have been written on process approach but truely I have not come across any simple clarification what it is all about. Is 1994 on procedure approach and 2000 on process approach?What I have read so far (pardon me) is it say it's input with output. But how do I explain with reference to version 1994? How is the audit differ from version 1994? Is the audit no longer go according to clause by clause as in 1994? When carry out an audit on 4.13 Ctrl. of Non-Conforming Prod. (1994) we usually ask the auditee to explain their process from the start to the end. We'll then zoom for further clarification. Isn't this a process approach as in the 2000 version? I am really buffle.
Marc
#42
The simplest way I can explain it is a process approach is like a flow chart. Each box (process) has a input to it and an output from it. In physics it's the old action - reaction equation.
The standard represents it as a circular process. That is to say it never ends (perpetual motion?). It has one output, technically - in their language "Continual improvement of the quality management system" which, I guess, is superior to continual improvement of the product. But, I'm throwing in some 'discussion' (some may say fighting) words now...
I tried to show this in the slides starting at about http://Elsmar.com/Imp/sld032.htm
Don't get excited. It's rhetoric. In reality, systems do interact and they are all processes when you get right down to it. I think they've confused issues in the reorganization of the standard and with this new representation. It is alluding to a change which really isn't. I see it as nothing more than repackaging. And with all the hype, we even see it labeled as "New and Improved!". Now... Where have I seen that before???? :thedeal:
Marc
#44
Originally posted by johnnybegood
How is the 2000 version audit different from 1994?
There are a lot of threads here where the specific differences are noted. That's why no one is replying, I suspect. Try a search or two. Several threads have quite detailed listings of the differences.
E
energy
#45
Standard?
I would add that if you have a copy of the Standard, look at the Annex (s) in the back and you will see the comparisons, as well as the new stuff. No reference to the 94 version means "new".:ko: :smokin:
johnnybegood
#46
Perhaps I should rephrase......in what way is the 1994 auditing process differ from 2000? I came across a note saying that 1994 is procedural whereas 2000 is process. So does that mean that for version 1994 one just audit clause by clause and we can just zoom to 4.6 Purchasing. But for 2000 version we start with all the requirement in 7 Product Realization starting with 7.1 Planning of product realization followed by 7.2, 7.3....up to 7.6 Control of monitoring and measuring devices? Is that what is meant by process audit?
M Greenaway
#47
Speaking from my own experience I have never audited by clauses, I have always audited departments or actual processes and then looked for compliance to the appropriate clauses of the standard.
Certain clauses would be audited at every audit, i.e. document control, training, etc.
What may be slightly different to some auditors is the need to look at the inputs and the outputs of the process, particularly where documented procedures dont exist. Again this doesnt change my personal approach as I always did this where possible, the best assessment you can do of the effectiveness of a process is to actually look at what comes out of the process and see how it meets the 'requirements' (whatever they may be).
Andrei Viorel - 2009
#48
Business Process Oriented organization
The consensus view of the components of a business process oriented organization that emerges from the literature appears to includes:
1. a process view of the business,
2. structures that match these processes,
3. jobs that operate these processes,
4 .management and measurement systems that direct and assess these processes and customer focused, empowerment and continuous improvement oriented values and beliefs (culture) that are embodied in all components
"We define a business process as a collection of activities that takes one or more kind of inputs and creates an output that is of value to the customer" (Michael Hammer and James Champy, Reengineering the Corporation: A Manifesto for Business Revolution [New York: HarperBusiness, 1993], 35).
"A process is a structured, measured set of activities designed to produce a specified output for a particular customer or market.... A process is thus a specific ordering of work activities across time and space, with a beginning, an end, and clearly identified inputs and outputs: a structure for action" (Thomas H. Davenport, Process Innovation: Reengineering Work through Information Technology [Boston: Harvard Business School Press, 1993], 5).
"A process is a set of linked activities that take an input and transform it to an output" (Henry J. Johansson et al., Business Process Re-engineering: Breakpoint Strategies for Market Dominance [New York: John Wiley & Sons, 1993] ).
"A business process is most broadly defined as an activity that carries out a series of steps, which produces a specific result or a related series of results" (Daniel Morris and Joel Brandon, Reengineering Your Business [New York: McGraw-Hill,1993] ) .
"We assume that all processes can be thought of as a set of activities (e.g., 'steps,' 'tasks,' or 'subprocesses')" (Thomas W. Malone, Kevin Crowston, Jintae Lee, and Brian Petland, "Tools for Inventing Organizations: Toward a Handbook of Organizational Processes," working paper #141, MIT Center for Coordination Science, Sloan School of Management, Cambridge, Mass., May 1993).
"Process: a series of operations linked together to provide a result that has increased value.... Process improvement: activities employed to detect and remove common causes of variation in order to improve process capability." (Warren H. Schmidt and Jerome P. Finnegan, The Race without a Finish Line: America's Quest for Total Quality [San Francisco: Jossey-Bass, 1992], 350-51).
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
