ISO 9001:2000 Process Approach - What is it? Is it 'Real'?
Is the ISO 9001 'switch' to a process approach...
  • The ISO standard now is laid out in a 'Process Approach'
    Votes: 7 16.3%
  • Companies must now adopt a 'process approach' Methodology
    Votes: 8 18.6%
  • Both of the above
    Votes: 28 65.1%
  • Total voters
    43
Q
qualityboi
#61
Process Approach what about a Systems Approach?
So when or where is the systems approach in the gobblety gook? In theory systems transcend processes and bind them together (sounds like the power of the force? :lol: ).
We have great process management in our company but poor overall systems because of siloed management and culture. This abscence in corporate governence leads to multiple processes having similar subprocesses with no corporate governence. Ex. would be a stats group for every department, they use different names however, do not share any of the same resoures or methodologies. When a third party comes in and askes if we have SPC we say sure and show him a statistics group. Problem is they don't know that there are 3 other different groups doing the same things without common resources or methods.
I giggle at the IATF process approach form. It just puts the clauses horizontally on top and processes vertically. Would the result of the audit be different if the clauses were vertical and the processes were horizontal? Ok so who has an article about systems approach auditing?:lol:
Helmut Jilling
Auditor / Consultant
#62
IMO, What you describe is not "great process management" at all. Because you have significant silos, your company is run in a "departmental" mentality.
A true process approach is indeed a "system" of processes, linked together, and functioning effectively as a whole.
That is the intent of the process approach. To define what they are, to define how they link together, and define how to optimize those processes and links. A key item is 4.1.c in this, but is ofteyn overlooked.
Unfortunately, what you describe is a very common state of affairs. But those same companies don't seek help, because they don't realize how far from the true process approach they really are. A little bit of coaching, and you could be off and running. You can look to football, soccer or basketball as a pretty good metaphor for a process approach.
PS: the AIAG form is actually only intended as a "correlation matrix" to ensure all the clauses are covered somewhere in your processes. It's a way of assuring nothing got left behind. It is nothing more than that.
Q
qualityboi
#64
Semantics
I was being somewhat semantical, or was I? I know the process approach means you have determined the interrelations of processes and how each process feeds and outputs to one another, I just thought it would be better stated to call the whole "shameal" a Systems approach. Because you can really have great processes within a poorly managed system. That is why some areas shine and others don't. I have always thought (IMHO) that what they refer to as the process approach should in reality be called a systems approach. No biggie though, I get the gist, dare I say it, the "gurus" are referring too. In order for a systems approach to be supported you have to have good corporate governance and top management support to help thread those process together.
Helmut Jilling
#65
qualityboi said:
...I just thought it would be better stated to call the whole "shameal" a Systems approach. ....
Interesting, and to your point, in TS they do call the audit of the system processes the "system audit." They just want it to follow the system processes rather than the clauses.
Helmut Jilling
#67
Lee said:
JMHO: I don't agree that the ISO 9001 standard is laid out in a "process approach". Not at all.
The standard is laid out in a PDCA model. However, they want the system audits and system management to follow a process approach, rather than the clauses. But, this evolved more after the standard was issued. Thus, the standard makes little mention of it, but subsequent documents and clarifications emphasize it.
Helmut Jilling
#69
Lee said:
I've never had any training on PDCA. Do not have any books or info either. My opinion is no good! :eek:
Well, whether you were trained in PDCA or not, is not so important. The ISO 9001 Standard is laid out in that logical, linear model already. You can just take the standard as it is and work with it.
But, just to explain a bit. The intent of the Plan - Do - Check (or Study) - Act is straightforward. It is essentially a continual improvement circle or spiral where, if you do it well, each lap around is intended to raise the bar (hence the continual improvement). I guess that means if you don't do it well, you just go in circles.
Plan - Plan an activity, define the expected outcomes, determine the criteria and objectives whereby you will know if it was effective, and determine how you will measure or monitor whether those were met. Then, plan the steps of the activity, the inputs and outputs, the interactions, responsibilities and resources needed.
Do - Execute the plan you described in the Plan step above.
Check (or Study) - Check, (evaluate, review, study, analyze, discuss) the results and data you said you were going monitor for this activity.
Act - Based on the conclusions you reached in the Check/Study step, define course corrections, adjustments, and do another lap around the circle.
If you did the Study and Act steps well, the next lap will have improved results. With each lap, the process continues to become refined, and the results continue to improve. Hence, the "Continual Improvement" everyone likes to talk about, but many don't actually achieve.
This is the secret to why Toyota and Honda have improved so much since the 1970's. They came from nothing, while the leaders of that time were fat, dumb and happy, and felt they didn't need a strategy to improve.
A company that does this well cannot fail to improve!
V
vanputten
#70
5,6,7,8
In ISO 9001:
Section 5 is primarily Act related stuff. (Management Responsibility)
Section 6 is primarily Planning related stuff. (Resource Management)
Section 7 is primarily Do related stuff. (Product Realization)
Section 8 is primarily Check related stuff. (Measurement, Analysis and Improvement)
Section 4 is general stuff.
We can look at how the standard is generally laid out to support the PDCA model. Within each of those sections, we can all easily find more PDCA stuff. We can look within each section to find PDC and A related requirements.
But in general, the organization of ISO 9001 is to match the PDCA model. This diagram can be found in 0.2 Process Approach.
Regards,
Dirk
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
