ISO 9001:2000 transition - Document and Process Discussion
CliffK
#71
I think AndyN's main point got lost in the is-a-process/is-not-a-process discussion.
The big 6 are activities that many companies do not do very well and that many managers would like to avoid. In its wisdom, therefore, the TC has mandated a control measure (documented procedures) for these six activities/procedures/tasks/systems/whatever.
Also, sometimes managers can ignore the big 6 because employees have been taking care of business. For example, the manager may think document control is not an issue because the informal methods used by his employees have been effective. The problem, of course, is that the system is not robust. So, if the one guy that has been making document control work gets run over by a beer truck, things go down hill fast.
In a sense, the big 6 are a somewhat like a colonoscopy:
1. Nobody wants to have one.
2. Some people never have one and yet live a long and happy life.
3. A problem in that area can cause real harm eventually, so prudent people have it done.
G
Gary E MacLean
#72
Ewwww, Gawwwd; very apropo however disgusting analogy. Good way to get our attention Cliff - Hey, can I drop over some time? Always wanted to say that.
Stijloor
#75
can i got some procedure documents for reference?
thanks everybody
Hello cnjerryli,
Welcome to The Cove!
Can you tell us a little bit more about the processes for which you would like to see documented (sample) procedures? This Forum represents a wide variety of organizations from around the globe. Be specific, and we'll be able to help you.
Stijloor.
Helmut Jilling
Auditor / Consultant
#76
Re: ISO 9002:1994 to ISO 9001:2000 conversion (transition)
...The mistaken impression that a procedure is only a procedure if it is documented has caused many companies to vastly over document and complicate their systems.
I agree. A procedure is a method to perform a certain activity or process. Sometimes the procedure (method) is very clear to everyone and does not need to be documented. Other times, a company would benefit from writing it down and controlling it. ISO and TS allow the company a great deal of leeway to decide which ones need documenting.
But, please, let the need dictate which get docuemnted, some some arbitrary rule or goal. If you need it, document it, If not, don't bother.
cnjerryli
#77
Welcome Jerry.
Do you mean examples of ISO 9001 procedures?
Have a look at this
Hello cnjerryli,
Stijloor.
thanks very much, I need the morintoring and measurment procedure for a
bag production factory.
thanks for your kind help.
regards glade to meet your guys here,
Stijloor
#78
thanks very much, I need the monitoring and measurement procedure for a bag production factory.
regards glad to meet your guys here,
Hello cnjerryli,
You're very welcome.
"Monitoring and measurement" in a production factory usually means "inspection and test" of product. I did a search here at The Cove in the "Post Attachment List" on the word "inspection." The link is here: http://elsmar.com/Forums/fileslist.php?mode=allfiles&sortby=filename&pageamt=2&criteria=Inspection
Please note that not all documents will be applicable to you. You have to kind of "pick and choose" for relevant examples. It may be a good start to look at these examples.
I'm sure you will get responses from others here at The Cove.
Stijloor.
CliffK
#79
Cnjerryli,
Are people doing the inspection and test work now?
Are the results satisfactory?
If the answer is yes, then why do they need a documented procedure?
If the answer is no, why don't you find out the root cause? Your time will be much better spent than it would be if you write a document "just because."
It's probably NOT because there is no documented procedure. But if it is, then write one. Otherwise, fix the real cause.
Sorry if I seem grumpy. Over-documented systems are a hot button with me. They're a waste of time and a distraction. Might as well try to row a battleship.
Cliff Kachinske
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
