ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS?
#11
Re: ISO 9001: 2008 - Do I have to rewrite the QMS?
To further explain my question. The structure of the Table of Contents of the system we have is right out of the 1994 standard, it has the twenty "elements". The 2008 is very differently structured. Take Training for instance, the 2008 puts it under Human Resources. Do I change the requirements where it is applicable or change Training to Human Resources?
That is correct. However, you've now got everyone's attention about why you're only now asking about this...
Bearing in mind it's been 10 years since ISO 9001:2000 was issued, there are many, many questions which arise, not least of which is to do with the structure of the QMS.
Are you certified by a 3rd party?
hogheavenfarm
#12
Scott is right-on here,
I had to revise our our version (1994) to 2008, and I rewrote all the procedures to make them more generic, anticpating future revisions (2014) as well. I removed explicit references in our procedures to the standard, and basically rewrote the procedures as well, then keyed the procedures numbers to the requirements, as well as form references. We had originally written procedures individually by department, so we ended up with 77 procedures, many of which overlapped departments. I scrapped the whole thing and wrote new procedures based on the process, overlapping the departments, and reduced the procedures to 9, again anticpating some future revisions. This made it much more manageable and easier to reference for audits.
#13
Structure is not that meaningful as far as compliance. If your existing structure has all of the elements to meet the requirements of the current standard then you have to change nothing. A registrar should not care if your training procedure is not part of your human resources documents as long as the procedure is effective.
I'm going to guess your procedures reference the standard and that is causing the question... if this is the case then you will either have to change the references in the procedures to match the current standard or get rid of the references to the standard in the procedures. I would choose the latter. There is no requirement to put an ISO section on a procedure.
Are you ISO 9001 registered?
Scott - it's highly unlikely that a system built on the 94 version meets the 2000/2008 requirements isn't it? Training is a (minor) piece now - as we constantly beat the drum here, it's about COMPETENCE, so I can't agree with your assertion. Let's not overlook the fact that TC 176 - not the CBs - recommended 3 YEARS to transition to the new requirements!
Paul Simpson
#14
<snip>Let's not overlook the fact that TC 176 - not the CBs - recommended 3 YEARS to transition to the new requirements!</snip>
TC 176 has no real interest in the certification process :mg: but does get drawn in and ends up 'endorsing' recommendations generally pushed by IAF and ISO's CASCO committee - by and large made up of CBs and ABs. I argued strongly against this but it snuck in when I wasn't looking! :D
A standard is a standard and exists until it is superseded. As soon as (for example) the 2008 edition is out companies should be making the move towards updating their systems (if needed). Certification bodies could give their own 'last chance to transfer' dates (and used to in the past) but that is now the role of the IAF in order to keep a level playing field. ISO support of the transition date is just to give it extra credibility.
ScottK
Not out of the crisis
#15
Andy - I think you misunderstood what I wrote and are going off on a tanget.
The question is not about training. The way I read the OP's questions it's that he's worried that he has to re-write the entire QMS becuase 9001 no longer has the elements layed out like in 1994.
My assertion is that it doesn't matter how it's laid our as long as the requirements of the current standard are met.
As to the training tangent - I don't know about your part of the world, but in US it's still really, really common to have a training procedure to meet the needs of 6.2.2. And 6.2.2. is still colloquially referred to as "training" even though it goes deeper.
#16
Surely, this is at the very heart of an effective management system? And, the old version really didn't have much, and as a result, people documented their silos, in procedure form...
I'm simply concerned that anyone who's asking such questions will go away with the idea that to upgrade their system, it's simply a case of renumbering their existing documentation, when clearly the task to develop a fully compliant and effective system (see Hogheaven's post) is a major undertaking...and we really can't debate what's common, can we?
That's not what I got from your post, Scott!
ScottK
#17
Andy - I answered the way I did because I feel the OP is having a document control issue and is worried that he has to renumber everything to match the current ISO layout.
Re-read the questions. He's talking about the table of contents and under what section to place what procedure.
You are going way deeper than that.
#18
Indeed, Scott - much deeper, because nearly every day we see somewhat similar questions which are often based on a fundamental misunderstanding of the differences between versions of the standards, misquoted requirements and so on and I'd rather not make assumptions. I've always found that getting back to basics is the most effective if not always expedient way of dealing with such situations. I'm also very cautious about readers who 'pick up' the silver bullet they've been looking for, without the knowledge or nuances of experienced implementers - such as yourself - posting them.
All will come clear once Emil has answered our clarifications as to whether they are certified etc.
Big Jim
#19
I can't help but jump in here.
Although it is true that the structure of the quality manual and the procedures does not have to follow a specific structure, and that an organization can choose to keep the structure from the 1994 version if they wish, it would certainly lead to confusion.
Just because they can doesn't mean it is the most effective way. I certainly could not recommend it.
Big Jim
#20
Hi, Emil. Despite the confusion over the standard numbering I hope the consensus is shining through - the changes to the 2008 edition are minor and don't require anything more than a review of existing systems. No rewrite required! :)
Don't forget that it has to be compatible with the 2008 version. I hope that is what you meant when you say it has to be reviewed. It would be more correct to say it needs to be reviewed and modified as needed to be compatible with the 2008 version. It is likely that the modifications would be light, but it depends on what is found during the review.
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
G Determining the Scope of ISO 9001:2000 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
