ISO 9001:2000 Upgrade - What costs can a company expect to incur in the changes?
E
energy
Recently while reviewing transcripts of a chat session with ISO Experts I saw this question:
“What kind of costs can a company expect to incur in the changes?” I thought the answer rendered by the so-called expert was not the response the requester was looking for.
This was the answer: To XXX’s question re costs, my opinion is that an organization should not be doing things just to comply to the standard. There needs to be a business reason-does the work make business sense? In that sense there should be “no cost” associated with complying with ISO-just because we did not do something that we should have been doing is not a good reason for “blaming” ISO for being responsible for “extra cost.”
Is it me? Is it my contempt for any type of professional that does not answer a direct question? Is it a good answer and I’m just trapped in my own paradigm? (Like that, Kevin?) What a word! :vfunny: How would YOU answer it? With approx. numbers or a lecture about compliance costs shouldn’t be a consideration because you should have been in compliance?
:ko: :smokin:
E
energy
There was another one, too!
Here's another typical response:
Question: What are the implications for companies regarding continual improvement? How will auditors know if enough improvement is going on?
After three time asking this was the response: To XXX, why worry about what an auditor would think regarding CI processes? If the organization is addressing corrective action, conduct meaningful management reviews and doing good internal audits, these processes should be a meaningful way to address CI.
Then a follow up answer: "And XXX, the organization must also have a policy that includes commitment to improvement and measurable objectives set with that commitment in mind."
Then another follow up answer: "More to XXX, what is enough is limited by the resources and prioritoes of the organization."
Finally, and this (IMHO) should have been the first and last: "And XXX, remember that it is the third party auditor's job to audit your process. The decision on what to improve and how much belongs to the organization implementing the standard."
I would wager that the last answer would be what the inquirer would have received several times over here in the Cove, almost immediately. And without all the posturing. I must be spoiled.
:rolleyes: :ko: :smokin:
Randy
I know I've said it a few times.;)
E
energy
Quite a few
For sure. Most of the "experts" here have said the same thing without being continuously prompted and offered as an afterthought. But then, you didn't only have an hour to peddle your books while you answered questions.:vfunny: :ko: :smokin:
E
energy
My thoughts exactly
I thought about it, too and was thinking more on the lines of real time mock audits. You know, no time to research your answers. Just shoot from the hip like you would in real life. ;)
:ko: :smokin:
A couple of things here. First, the answer is valid. We should not be concerned with cost if we are doing what makes sense. However, If you do not know the cost, how will you determine if it makes sense? Make sense? Just because it makes sense, you still would like to know what the cost is before taking the upgrade road.
I would probably have given the same basic answer, but followed it up with something that might give the person asking the question some ballpark on costs.
:ko: :smokin:
I agree. Vague answer. "Business reason - - No Cost"???? Does not equate.
Cost is very important, more important IMO ROI.
R Key Process Indicators (KPIs) for ISO 9001:2000-certified Service Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
P Internal Audit for ISO 9001:2000 vs. Internal Audit for OHSAS 18001:2007 Internal Auditing 4
H ISO 9001:2000 Certificate - Original approval date 18 July 1995 and valid until 2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E ISO 9001:2000 transition to ISO 9001:2008 - Do I have to rewrite the QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Advantage between ISO 9001:2000 vs ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Quitting ISO 9001:2000 - Necessary Changes to product literature, logos, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Updating a Quality Manual from ISO 9001:2000 to ISO 9001:2008 Quality Management System (QMS) Manuals 57
B Updating from ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Advice needed for ISO 9001:2000 update to 2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K How to update from Procedure to Process - ISO 9001:2000 to ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F How much longer can a company declare registration to ISO 9001:2000? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N ISO 9001: 2000 to ISO 9001: 2008 - How to change the documents & procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
S Transition from ISO 9001:2000 to ISO 9001:2008 and TS 16949:2002 to TS 16949:2009 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Validity of ISO 9001:2000 Certificates - How to handle supplier ISO 9001 certificates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
K Interpretation of the differences between ISO 9001: 2000 & 2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q How long is ISO 9001:2000 good for (valid) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N ISO 9001:2000 version to ISO 9001:2008 - Necessary Document Revisions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001:1994 Upgrading to ISO 9001:2000 or ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Time frame for validity of ISO 9001:2000 Certifications IATF 16949 - Automotive Quality Systems Standard 3
H Effectiveness of ISO 9001:2000 Implementation in small industrial organizations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Is Version Change needed for ammending ISO 9001:2000 to 2008 Document Control Systems, Procedures, Forms and Templates 1
L ISO 9001:2000 vs. ISO 9001:2008 differences and concerns ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R ISO 9001:2000 to ISO 9001:2008 Transition - Changing documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
C Recertification for ISO 9001:2000 - framework ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Relationship between ISO 9001:2000 and EFQM ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Acquisition (Merger) of an ISO certified to ISO 9001:2000 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Is ISO 9001 Transition (from 2000 to 2008 version) Training Required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
D To change or not to change? Our documents reference ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 31
A Registration to ISO 9001:2000 in 2009? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S What are the consequences of having an expired ISO 9001:2000 Certificate ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A A macro-process structure approach to auditing for ISO 9001:2000(8) General Auditing Discussions 19
B CNC Controls under ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc Summary of ISO 9001:2000 and ISO 9001:2008 Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 166
A Brief discussion about ISO 9001:2000 clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Advice on exclusion of 7.5.2 of the ISO 9001:2000 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
L ISO 9001:2000 and CMMI v1.2 Integration and Org Deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
S GAP Analysis for ISO 9001:2000 vs. ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 2
D ISO 9001:2000 - Implementation in an Environmental Consulting Firm ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Getting started with ISO 9001:2000 Templates Document Control Systems, Procedures, Forms and Templates 18
Z Synchronizing two quality management systems: ISO 9001:2000 Quality Manager and Management Related Issues 5
J ISO 9001:2000 4.2.3- Quality Records, Production Travelers Records and Data - Quality, Legal and Other Evidence 9
C ISO 9001:2000 Certificate - How to have a 3 year validity instead of 1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
N When will ISO 9001:2000 Certificates turn into ISO 9001:2008? General Auditing Discussions 11
J Should product brochures be controlled per ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 2
I ISO 9001:2000 Recertification controls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J ISO 9001:2000 7.3.5 "Verification" and 7.3.6 "Validation"- Clarification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
J Must you use an ISO 17025 lab in order to receive ISO 9001:2000 Certification ISO 17025 related Discussions 16
