RCBeyette said:
Personally, I like the way it [is] currently structured...it is in-line with a PDCA methodology which works hand-in-hand with our Business Management System. The format of ISO 9001:2000 fits, for the most part, very well with us.
Unfortunately, there is a lot of overlap in the Standard. For example, a bit of production maintenance here, a little bit there. Quite often during an audit, I'm checking off N/A on several checklists to get to the relevent portions covered in several clauses...lots of paperwork from an auditor's standpoint.
Control of Documents...well...I guess, but I still find it amusing that I need a document on how I control my documents. A procedure for Records Control is somewhat pointless...a master list, however, conveys so much more.
Internal Audits is the one I don't quite understand...if the tools are provided to do the audit, why is a procedure required.
The fact that they are done are reviewed at Management Review, as required by the Standard. Do we really need a procedure telling us how IA's are done within an organization? Perhaps...or maybe I'm just assuming (bad move, I know) that we'll all use common sense when it comes to scheduling, implementing, and conducting IA's.
When you say "lots of paperwork" - why not eliminate the extraneous stuff from your audit checklist before it reaches the auditor's hands?
"Control of Documents"
Which brings us to an audit "Procedure." Simply ask yourself the following and supply your own answers:
- Without a procedure, what is the basis to have consistent audit from auditor to auditor and year to year?
- Where did you get the plan to use which tools for the audit?
- What curriculum did you use to train auditors to use the "tools?"
- Is the Management Review covered by a procedure? Do the reviewers perform the activity consistently each time or do they "wing it?"
- If they "wing it," do they expect the auditors to "wing it" too? Why not?
