ISO 9001:2008 Audit Major Finding - Dial Calipers not set to zero
cavrdave
ISO Auditor found a set of dial calipers with the dial not set to zero and considered this a major finding. He feels Calibration is only permitted to adjust the dial(loosen the set screw and move). He felt that product could be out of spec but not get caught. The operator was not using the calipers. He had gotten them but didn't get to using them yet so he hadn't looked at them yet. Does anyone have a similar experience?
On what does the auditor base his "feeling" that only Calibration should be permitted to adjust the dial? What does your written procedures have to say about it?
Speaking about calibration: As the calipers in question had not been in use, they could hardly have caused any faulty products to slip through the inspection, could they? How great is the risk that they do get used, ending up with faulty products slipping through? Again, what does your written procedures say about inspection, which equipment to use, and its calibration status?
To consider this a major finding sounds a bit stiff in my opinion... :notme: ...but I suppose that depends on what a faulty reading could result in.
Not as bizarre as this! Are you talking about a CB auditor? "ISO auditor" is a term people use for both internal and external auditors. If it's a CB auditor, can you give us the exact wording of the "major"?
In practice, this is a totally bizarre finding and you MUST take it up with the CB (if that's who this is) and tell them that your auditor is incompetent and you won't pay for an audit done by an incompetent auditor! If the auditor took just this one instance and didn't subsequently check what was going on, then they are not doing their job effectively.
Q
qualitypirate
It sounds like your auditor has no idea how calipers actually work. Putting an offset on them can sometimes be key to checking a part. If the guys in my shop had to come to me to return their calipers to zero I would have to put one of those take a number things out in front of QA.
Ninja
Looking for Reality
ISO Auditor found a set of dial calipers with the dial not set to zero and considered this a major finding. ...snip
I'm in agreement with the above...the operator setting the dial to zero before use (or possibly another number) is part of the normal operation of using calipers.
All the same, findings are when actions do not match requirements.
What is the requirement cited in the finding?
Is there a procedural requirement in your system that states that calipers will be set to zero when not in use? If so, the described situation would be a non-conformance.
Finding that NC, I would suggest an OFI to remove such a silly requirement from the procedure.
BradM
It would be the same as pressing the zero button on a digital caliper.
While I do agree that clarifying whether zeroing a piece of equipment is considered appropriate by a user, I certainly don't think it merits a finding; especially one with no backing.
If the users zero the device before use and remove the error, why would an auditor be worried about that? I would be more concerned with someone picking up an instrument with error present and not doing anything about it.
The practice of zeroing the calipers do need to be proceduralized and be consistent. But on the surface, I don't see anything that would merit a major finding. If that's the worst thing they find in your process, you should receive a medal; not a finding. :)
Randy
It's a Horse$hit finding :horse:. File an appeal to the CB and if they balk appeal to the AB probably ANAB
It doesn't matter a **** how the auditor feels...Oh yeah, I know how calipers work and the caliper probably doesn't measure small enough to gage the auditors intellect on this one.
Mike S.
Happy to be Alive
Sometimes there is a "rest of the story" that could change one's views. For example, if the auditor saw the offset from 0 and then asked the calipers user how he/she uses them to measure and he/she just grabs them and measures something without checking zero, thereby giving a wrong answer, I can see it as a finding.
If the user(s) of the calipers know to check zero and what to do if it is not zeroed, I'd say it is a BS finding and should be protested.
Had a similar experience about a decade ago. What we did was to place a 'calibrated' 1" block on every workstation, mainly to show the auditors that there was a procedure to go through before using the calipers.
Of course zeroing was the first, (but there was no physical evidence of this), so we added the 1" block and had the operator take the reading before any measurements (this was written on top of the SPC sheet we were using). This provided the evidence that the procedure was being followed and as an added benefit, was a check on whether the dial was zeroed or not.
This was a workaround , to be sure, but it was the simplest solution for us at the time.
Ron Rompen
Go ahead Randy, tell us how you REALLY feel :lol:
Sounds like you have been through an audit 'finding' similar to this in the past.
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
