ISO 9001:2008 Calibration of Measurement Equipment Requirements
silentrunning
#11
My own simple rule of thumb is - If it comes in contact with a customer's product, it gets calibrated. This includes during set up, production cycle and final inspection. If any decision about a customer's product is made as a result of the readings from an instrument, it gets calibrated.
Q
QMS QUB
#12
Is this statement sufficient for not calibrating instruments?
The reason im unsure, is that we have a sister company who have are fully accredited and do not calibrate rules or tape measures:
This is what they have included in their procedure for calibration
"3.4 Steel Measuring Tapes
Steel measuring tapes and rules are not calibrated and are considered as production items only. Any employee who suspects their tape / rule is not accurate for production purposes may request the quality inspector in their area to verify their tape/rule. Any non-conforming tape / rules shall be disposed of and replaced."
Is it enough to include this in the procedure to eliminate the need to calibrate rules and tape measures?
The Specialist
#13
I disagree.
Essentially, if the steel rule/tape measure is used to measure a critical parameter then it will need to be VARIFIED as accurate against a known standard. You will not 'calibrate' it.
The statement in the example you give above is also ambiguous and misinforming.
Either it IS or IS NOT critical and will be controlled/verified as required; simple as that!
Mark Cost
#15
"...Steel measuring tapes and rules are not calibrated and are considered as production items only. Any employee who suspects their tape / rule is not accurate for production purposes may request the quality inspector in their area to verify their tape/rule. Any non-conforming tape / rules shall be disposed of and replaced."
Is it enough to include this in the procedure to eliminate the need to calibrate rules and tape measures"
How would an employee "suspect" a tape or rule is not accurate?
IMO - Write a procedure, calibrate it and keep the record. I guess my "rule 'o thumb" is, if you aren't sure, calibrate it (or come to The Cove).
BradM
#16
Re: Is this statement sufficient for not calibrating instruments?
As has been mentioned, how is is that you can state that they are not going to be calibrated; then offer in the next sentence to verify them if they are not accurate?:D It just seems kind of confusing to me. :)
If their accuracy matters, then verify them. :agree1: And I think you might find it easier to have it part of the program, than trying to do them on a random basis.
Q
QMS QUB
#17
Also we have quite a lot of pressure guages attatched to air lines and gas canisters (oxygen and acetylene). These are not there to measure product conformance, but rather as a check to make sure there arent any leaks in lines, and as a visual aid when assesing air pressure. What im trying to get at is these guages are not "measuring equipment needed to provide evidence of conformity of prduct to determined requirements".
Is it nessesary to have these calibrated for ISO 9001:2008?
ps. Thanks for all the help so far guys.
BradM
#18
I know where you are coming from. :agree1: The thing is, you should be looking at the equipment and determine if the reading matters. On the air lines and canisters, what impact would it have if the gauges got way off? Would it matter?
I know I (and some other keep saying that), but it's very difficult to answer a question about something needing to be calibrated or not without knowing more information. Every process is unique, and different.
For some processes, gauges on air/gas canisters are meaningless. They require no further action. For other processes, the readings are kind of important. Thus, they should be checked out.
For air, while the exact value may not be important, the indication of the presence of pressure is an important safety issue. You don't want someone messing with something that has 100 PSI of pressure on it. So, while the gauge reading is not important, the functionality of the gauge working correctly is important. You don't want a gauge to always read zero because something is broke, and the operator think there is no pressure, when in reality it's at full pressure. :agree1:
You really need to do some process analysis prior to determining calibration requirements. :agree1: Talk to the people in your facility, ask them how they use the instruments. Ask them if they write it down, make some kind of assessment on it, etc. This will lead you to your answer of "does this need to be verified?":)
Q
QMS QUB
#19
Brilliant. I think this is my question answered:agree1:. Thanks. The more important pressure guages we have are attatched to our fabricating machines and they are checked with each service, (every 6 months).
Chance
#20
My company has approximately 28 scales that are used to measure products that are at design stage. In other words, our scales are not used for pass/fail. We are ISO 9001:2008 certified, and we decided to calibrate/validate them in-house using different set of weights. Is Statement of Accuracy (that goes along with the set of weight) valid enough to show to our external auditors?
I beleive we are in compliance to the standard. Don't you think?
Please help me.
Thanks,
Chance
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
