ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software)
H
hostility
Could some one explain the ISO 9001:2008 Clause # 7.6 Control of Monitoring and Measuring equipment(Computer Softare) is applied to my company?
My company is an engineering company.
We design the heat & power plant.
So, we don't have any monitoring and measuring equipment.
But, we just have lots of computer softwares to calculate many things such as pipe stress, steam and water flow, pipe thickness, etc.
I have thought that these softwares are not intended to monitor and measure things.
But, one of our customer says those computer software shall be applied to clause 7.6.
I have known that ISO 9001:2008 Clause 7.6 requirement is limited to "When used in the montoring and measurement of specified requirements"
sitapaty
Re: ISO 9001:2008 Clause # 7.6 Control of Monitoring and Measurement(Computer Softwar
This is what ISO9001 says about software:
7.6 Control oF MME
"When used in the monitoring and measurement of specified requirements, the ability of computer software to satisfy the intended application shall be confirmed. This shall be undertaken prior to initial use and reconfirmed as necessary.
NOTE Confirmation of the ability of computer software to satisfy the intended application would typically include its verification and configuration management to maintain its suitability for use."
It means you have to confirm its suitability at the time of initial introduction.Later on calibration is required if necessary only.When there is no chance of the software loosing its precision you need not carryout periodic calibration.
Any other interpretation is welcome
qusys
Re: ISO 9001:2008 Clause 7.6 Control of Monitoring and Measurement (Computer Software
Probably you use ad hoc software programs , created by your organization, that make calculations with usage of macro and staff like that. These programs should validate on a certain time basis, for example making calculation in another manner and confriming the same results from two different sources.
Probably you also use commercial program. In this case you have updates from the the oem or specific procedure to control the effectiveness of the software.
Howver you could make calculation by hand and make verifications on spot.
sitapaty
How can a software loose its precision?Even mountains can grow or shrink but a software can not change.Pl correct me if I am wrong.
dgriffith
Once a version has been deemed suitable for use, recorded, and controlled as such, only a new version or a change in (or addition of) calcuable parameters should require reverification.
(Unless you're using National Instruments LabVIEW. Like the mountains, it too will change itself over time. I swear it becomes sentient and messes with its owner . . .)
normzone
As long as your software files do not become corrupted life is good. I think the object of the requirement is to periodically verify that your software has not become glitchy. How you do that and how often is up to you.
H
hostility
Thanks all of you.
I have confused about softwares' purpose specified in ISO 9001:2008, because ASME NQA-1 specifies "computer program testing" precisely. This means all softwares including calculating programs, monitoring and measuring programs, etc.
But, ISO 9001:2008 specifies the softwares to be used only for monitoring and measuring.
I wondered if the calculating programs are not apllied to ISO 9001:2008 clause 7.6.
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
