ISO 9001:2008 for Marketing and Sales Department Only.
John Broomfield
#21
Hello all,
I'm new to this forum. Just registered few minutes ago. I'm working in an insurance company which used to have a sales depertment only while now preparing to have a marketing depertment along with the sales. My company is also an iso certified company but we're are forming a new company now which will include this marketing department. I already have the processes and procedures of iso for sales but I don't have the iso processes and procedures of marketing.
I tried to find out in many websites but could not find till now.
I'm wondering if any one here can help me where to find it?
Thank you very much in advance for your help.
Regards,
:thanks:
:bigwave:
Analyze your core process from end to end to determine your key processes and to identify their sequence and interaction.
Assign a competent person as the owner of each key process. :biglaugh:
Then work with that person to analyze and document each key process to the extent necessary for effective planning, operation and control.
Share your support processes from sales to also support (nurture and improve) the marketing core process.
Do not use "ISO procedures". :confused:
JaneB
#22
You can't find them because you're looking for something that doesn't actually exist.
There's no such thing as 'ISO procedures'. (The Standard does say that you need procedures where they are necessary for good management control, and it mandates them in 6 areas.)
What you need to do (as John says) is to work out what your marketing process (or processes) is and decide where and if procedures are required. If they are, you'll need to write them.
ABUHASHIM
#23
Hello all,
Regards,
:thanks:
Hello Khalid,
I think you need to refer to the customer releated processes, clause 7.2, follow up all requirements which pertain to marketing & sales processes.
regards
mirrorcrax
#24
Abu Hashim,
I totally understand where you're coming from, and please let me explain to the rest the most common reason behind such a request from top management, which i have encountered in several organizations i have worked with as a consultant.
TOP MANAGEMENT are Misinformed, LAZY, and are taking decisions based on street knowledge and common heresay such as "ISO is Saying what you do, Writing what you say, then Doing what you write" which is most common in several of the organizations i encountered taking such a similar decision.
So, back to your question, which requirements should you exclude, hmmmm i would definitely say 7.6 unless you perform site surveying, 7.5.4 if you don't use any customer property, 7.5.2 "special Process", 7.3 "Design and Development" unless you prepare drawings for the customer or other design activities, please bare in mind that is just off the top of my head, and that it depends on what you sell.
I agree with the other opinions and would like to clarify to you, that in order to meet 9001 requirements, it is not enough to just prepare procedures and forms for what you're doing, the standard addresses an "Organization's" Management System, and hence by singling out each dept and applying it separately you will need to either prepare redundant documents for training, purchasing, and other support and management processes, or you will just have to cross the scope boundaries during the audit and go visit those other departments.
i hope this helped.
bel tawfik ;7
ABUHASHIM
#25
Abu Hashim,
i hope this helped.
bel tawfik ;7
TAWFIK,
You are right about your opinion about the TOP MANAGEMENT-generally-perhaps at your area, but in our AREA, TOP MGT. are more aware about ISO9000, as excellence model focusing on customer and performance more than merely documentation.
I think you needn't to mislead givingthe right answer to the question asked by Khalid, at which he is asking about processes/procedure needed for M&S department.
thx :)
mirrorcrax
#26
Who is TAWFIK? ... seeing your name is ABUHASHIM... i Said "Bel Tawfik" meaning good luck in Arabic, that's not my name!
What area? ...... i'm a consultant... i get to see all sorts of organizations ... none of which are "my area"
If your top management were really as you say, they would've never requested that a Quality Management System Standard Meant for "Organizations" to be implemented on a "Marketing and Sales Department" ... doesn't seem so customer focused to me
please explain "needn't to mislead giving the right answer" ... i have no idea what you mean
Who is Khalid? .... i thought you were the one asking the question
harry
#27
:mad: Heated posts :mad:
It would appear that this had become a heated thread through some communication problems. Please refrain from any further posts which might appear less than objective. Moderator action to isolate any questionable posts will occur.
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
