ISO 9001:2008 Management Representative and other Management Staff
toto2010
Dear Everyone,
I have several questions regarding the ISO 9001: 2008 on change of management representative.
1) I heard that change of management representative has to be documented. Not sure whether this is mandatory and which clause states this.
2) For my company, we are still developing the ISO system. Does the appointment of MR has to be documented? Again, if this has to be done, which ISO clause states that?
3) Is this the function of HR department or quality department to document the appointment of MR?
Thank you very much.
Regards,
Toto2010
Re: ISO 9001: 2008 Management Representative and other Managment Staff
Dear Everyone,
Regards,
Toto2010
This is a great example of the type of questions which arise, when the answer is in a copy of the standard. Presumably, what you heard wasn't from someone who has read it, which is always a bit dangerous. If you are still in process of implementation, do you have a copy of ISO 9001:2008? If so, might I suggest that your answer is in there.
Some baggage left over from earlier times in ISO 9001 is the misconception that everything needs to be documented. This is one of those things that there is no specific requirement to document it.
That said, depending on how you have set up your quality management system, you may want to document it, but it is up to you.
If you use an organization chart to help put some structure to 5.5.1 where it says that you need to define the responsibilities and authorities in your organization, you may want to document it there. Please note that define does not necessarily equal document.
You may have a contractual requirement to notify your certification body when you change your management representative.
toto2010
Hi Andy,
I do have a copy and I have read through clause 1 to 8. I couldn't find the answer. Really appreciate if you can enlighten me directly according to my questions.
Regards,
Ben
toto2010
Thank you very much Big Jim.
So the clause is 5.5.1. I have read and understood it.
You are truly acquainted.
Once again, thank you very much.
Regards,
Toto2010
Hi Andy,
Regards,
Ben
Aha, I see Ben. You were looking for validation that you knew the correct answer. So many people come here because they didn't (or don't want to) buy the standard. Then we get into all kinds of "ISO says so" answers.
Depending on the size of the organization, it is not required to document this role. In a small organization it should be sufficient to have top management say "You're the management rep, Ben, you have the responsibility to design us a QMS, to maintain it and you have the authority to...blah, blah, blah.
If then, when you have an external audit, the same "story" is told by the top management, then you're good. Not even an org chart is needed.
However, if you are in a much bigger business, then some documentation of the role, who holds it etc. and so on. Often the culture and practice of the business is to issue "position descriptions" etc, and tht may be an option.
If you do change who is the Management Rep, then the "documentation" might be in the form of a management review, since this is a change which might be considered to affect the QMS. Also, competency might have to be demonstrated...
Mazoku
My company just went through a Management Rep. change and, as an internal auditor, I'm not sure how to handle this. The previous Management Rep.'s title was Quality Manager. Which I guess is conforming to the standard as he is technically a manager but was really detached from any real management. Anyway, they laid him off about 2 years ago and gave the Management Rep. responsibility to a Manufacturing Engineer. We even recorded that on our Org. chart. I know this is a non-conformance with the standard and has caused the Management Rep. position to be even more detached from Top Management. We somehow passed registrar audits, perhaps they didn't realize his title. As an auditor I feel inclined to bring this up or write it up as a non-conformance during my QA audit but I haven't. I know the guy quite well and I'm assuming he was given a pay raise for his increased responsibilities. He does try to do the best job he can with what he is given. I also know that he supports his wife and child on his salary alone, and I refuse to be responsible for him being demoted. At the same time, our company really is suffering because of it. Management has almost completely detached itself from Quality at this point. I don't really know what I should do now.
Q
Quality Bryan
I believe the standard doesn not specify that the Rep is a QA Manager per say but rather has the authority and direct access to Top Management to resolve all QMS related issues.
For what it is worth, Quality gets pushed in the corner at many large companies. I would run this up your chain for support.
Mazoku
Re: ISO 9001:2008 Management Representative and other Managment Staff
ISO 9001:2008 Section 5.5.2 Management Representative states:
"Top Management shall appoint a member of the organization's management who, irrespective of other responsibilities, shall ..."
We're a pretty small company too which is sad, less than 70 employees.
It's not really about any of the things you point out. It's all about whether this person can demonstrate competency in the role, and can represent the QMS for management etc. It's NOT a nonconformity, however and having a "manager" title, doesn't really make much difference.
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
