ISO 9001:2008 Management Representative and other Management Staff
Q
Quality Bryan
#11
Re: ISO 9001:2008 Management Representative and other Managment Staff
It does not state this person must be titled the "Quality Manager". Many times this person does have this title but for smaller companies it could easily be the Business Manager or the person with the most quality experience.
I agree with you, I'm just stating that the Standard is written to offer options.
Q
Quality Bryan
#12
Re: ISO 9001: 2008 Management Representative and other Managment Staff
Question about attaining a new Registrar (Potenitally answered by the moderator):
Is it common for those bidding on a contract award to ask to see a copy of your current ISO certification? I assume they would want to know with whom you are currently registrered with thus potentially using that information in the bidding proces.
I don't think our company should have to provide our registration for those bidding.
Your thoughts?
Thanks!
Mazoku
#13
It's not really about any of the things you point out. It's all about whether this person can demonstrate competency in the role, and can represent the QMS for management etc. It's NOT a nonconformity, however and having a "manager" title, doesn't really make much difference.
I want to believe this, but the standard clearly states the Management Rep must be a member of management, it's not worded in a way that can be taken otherwise. I'm not saying he needs to be called Quality Manager, and I'm not saying he needs to have "Manager" in his title at all. But he does need to be a member of management, and he clearly is not. Unless I am completely off course here. Which is not out of the realm of possibility. I am new to ISO and auditing so maybe I'm taking things too literally?
Q
Quality Bryan
#14
I apologize if I misunderstood your question. The Quality Rep should be in management. I was stating that that Manager does not have to be in the QA department.
Mazoku
#15
It's OK, perhaps I miss-worded myself. I have a tendency to do this
W
Wilderness Woody
#16
The statement and intent of clause 5.5.2 does indeed mean "management"... the reasoning is that the authority needs to be explicit in order to achieve the required results. Now, this management role may be granted to an employee that does no direct supervision of staffing, but rather has oversight of the QMS company wide.
Depending upon the size and type of organization, this representative may report to upper management and liaison with Top Management or report only to the Top Management. Quite often it is assumed that for a small organization that the QMS is directed and run from a TOP position. However, there will be companies where the Owner/President/CEO is not knowledgeable, experienced or capable of the QM role. Through a new hire or training of internal staff, some other person takes on that role... they need to be given the authority commensurate with the responsibility in order to succeed.
#17
So, the key question is "member of management" - what is this?
In his role as management rep they may function as a member of management, can't they? Regardless of their "regular" work...
toto2010
#18
Hi Andy,
Thank you for your advice. I did read through 5.6 management review but I didn't know I can put the change in it. Really thank you very much.
Also 5.5.1 states that authority shall be defined but it does not say documented....
Once again thank you and have a nice day.
Regards,
Toto2010
#19
Your thoughts?
Thanks!
Are you asking about changing registrars? If so, then yes, they will need to see your current certificate. They will need to see if it is accredited (ANAB, UKAS etc) and they will (ultimately) need to see your past audit reports etc. to ensure they know what they are walking into. You will need to provide a reason for changing registrars, too.
Big Jim
#20
I believe the standard doesn not specify that the Rep is a QA Manager per say but rather has the authority and direct access to Top Management to resolve all QMS related issues.
For what it is worth, Quality gets pushed in the corner at many large companies. I would run this up your chain for support.
Actually you are mixing in a requirement from AS9100.
5.5.2d
"Top management shall appoint a member of the organization's management who, irrespective of other responsibilities, shall have responsibility and authority that includes . . . d) the organizational freedom and unrestricted access to top management to resolve quality management issues.
This would certainly be a good practice for an ISO 9001 company, but it is beyond requirements.
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
