ISO 9001:2008 Management Representative and other Management Staff
Kronos147
#21
Re: ISO 9001: 2008 Management Representative and other Managment Staff
Is it common for those bidding on a contract award to ask to see a copy of your current ISO certification?
Your thoughts?
Every audit the subject of Oasis comes up. If a (potential new) registrar can't access that information on their own, I wouldn't let them in the door.
I would call that a "pre-qualification excercise."
Reg Morrison
#22
Is it common for those bidding on a contract award to ask to see a copy of your current ISO certification? I assume they would want to know with whom you are currently registrered with thus potentially using that information in the bidding proces.
I don't think our company should have to provide our registration for those bidding.
Your thoughts?
If you are shopping around for a new registrar and you have a current, valid, properly accredited certificate, it would behoove you to provide that information to the registrars bidding on your certification. Assuming they can transfer your certificate, in accordance with the IAF Mandatory Document # 2, you could save some money.
Otherwise, they would have to bid the certification as starting from scratch, with stage 1, stage 2, etc...
What is your concern to share the certificate with the potential incoming registrars?
#23
Which is applicable to AS 91XX certificates, ONLY.
Big Jim
#24
What's with the Aerospace mentality with ISO 9001 lately?
OASIS is for AS9100 and its derivatives. There are no ISO 9001 only registered companies listed there.
OK, I should have read ahead. After I posted I noticed that Andy already posted the same thing.
Kronos147
#25
Good point. My mistake.
I looked to see if I could add a disclaimer to my previous post but I am not figuring out how to do so.
I think I forgot how things were (for me) pre-AS9100.
Eric
Q
Quality Bryan
#26
We are moving from ISO 9001 to AS 9100 and must solicit for a new registrar as our previous contract did not specify AS 9100. We are a government organization and thus must follow specific rules. Any advice for making this change and any typical pitfalls or challenges going from ISO to AS and changing registrars?
Thank you very much for your input. I've found this site to be very helpful with support! :thanks:
#27
Changing registrars should be a somewhat seamless process, if ANAB accredited. There are potentially a laundry list of things to consider, but it boils down - in the end - to some simple issues. The process would be to transfer your ISO certificate and then perform the upgrade at the next scheduled visit, if that is at a time which works for you.
A "no visit" transfer can be done for ISO 9001, if your system is in good shape. The upgrade will be additional time to cover the AS requirements. Your selected CB will take care of that for you.
Your choice of CB is critical, of course. What do you use to select suppliers now? Lowest price? All have to be accredited so that's not a differentiator.
Reg Morrison
#28
First of all, you need to make sure the AS registrar is listed in the OASIS database.
According to AS9104/1, irrespective of the fact that you might have ISO 9001 certification, the AS registrar will have to perform a full (stage 1 and stage 2) audit of your system and use the audit time specified in Table 2 of the AS9104/1 document.
Good luck.
Q
Quality Bryan
#29
Is there a requirement for AS 9100 that all potential registrars be listed as a certification body witin IAQG:OASIS?
Also, is there any significance over a CB under ANAB versus ANSI or IAS? I realize they are all accredited under IAF.
The stage 1 and 2 audits are off on the horizon for know although I'm already nervous. Nothing ventured, nothing gained. It should be a worthwhile endeavor.
Thanks for your help!
#30
Hi Bryan. I think this is what you're looking for: http://www.sae.org/aaqg/audit_information/rabsites.htm
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
