ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'?
Status
Not open for further replies.
Sidney Vianna
Post Responsibly
Can we just log the devices as 'Pass/Fail'? with no record of a reading.
ISO 9001:2008 4.2.4 stipulates
Records established to provide evidence of conformity to requirements shall be controlled.
A calibration process must follow a procedure (documented or otherwise). A procedure has requirements. If the calibration record does not provide evidence of conformity against the calibration procedure, it violates that requirement of the ISO 9001 standard.
Furthermore, ISO 9001:2008 section 7.6 requires that the calibration must be done against measurement standards traceable to international or national measurement standards; bla, bla bla... that is ANOTHER calibration requirement which must be recorded, i.e., the traceability to the standard used to calibrate the device. A simple pass/fail log would fail to comply with that requirement as well.
Re: ISO 9001:2008 Sec 7.6 - Can we just log the devices as 'Pass/Fail'?
:frust: How do you show validation? The reason why validation is required is because the products created by that measuring equipment might not be defective even though the equipment was measured out of tolerance.
You can't just say this equipment is slightly out of tolerance, therefore all products made using it are bad because some products might still be within an acceptable range.
The relevant part of 7.6:
...the organization shall assess and record the validity of the previous measuring results when the equipment is found not to conform to requirements. The organization shall take appropriate action on the equipment and any product affected.
My emphasis. In order to have a meaningful record of such an event, it will be necessary to record what happened and what was done about it. You are arguing against a contention that no one has made. The question is about the actual results of the calibration, and no matter how much anyone chooses to torture the language into submission to their own misconceptions, "Pass" and "Fail" are valid results.
Imagine you have 100 components that were made with a caliper that was found to be out of tolerance by 1 mm, the standard for each component is 10 mm +/- 2 mm. 50 components have measurements of 8 mm, 25 of 9 mm, and 25 of 10 mm. You would rework all 100 components even though 50 are still in the allowable range? That is madness.
The only way to know why an affected product is defective is with objective evidence, which is in the ISO definition of validation. :read:
First of all, a minor technicality: The standard calls for assessment of validity, which is not exactly the same thing as "validation" in the ISO sense. What's being done is an assessment. That bit of pedantry out of the way, I'll point out once again that you're arguing with a strawman because a record must be created. A record that presumably would include the extent of the gage error and its potential or actual effects on previously measured product.
And it what world is a single employee doing all of these tasks, and having them write down an exact measurement for equipment too much work/information?
See above.
If the result of the calibration is "Pass," there is evidence of conformity with the calibration procedure, if that's what the calibration procedure calls for. There is a difference between evidence and proof.
I agree that there should be reference to standards used, but that doesn't mean that the actual result can't be pass or fail.
The only thing we can know for sure, given a calibration report, is that the calibration report exists. There might be know way of knowing whether or not calibration was actually even done, so I think we might be giving the records more weight than they deserve when it comes to effectiveness. In the end, the burden is on the auditor to show evidence that the process--whatever it is--is effective or not effective. The null hypothesis going in must be "effective," in other words. We can't be writing NCs against things that have never happened (NC product resulting from out-of-calibration devices, e.g) and without good reason to believe that they will happen.
Pcool
The relevant part of 7.6: My emphasis. In order to have a meaningful record of such an event, it will be necessary to record what happened and what was done about it. You are arguing against a contention that no one has made. The question is about the actual results of the calibration, and no matter how much anyone chooses to torture the language into submission to their own misconceptions, "Pass" and "Fail" are valid results.
Look at the original question once again:
StevePenny said:
ISO 9001:2008 Section 7.6 Control of monitoring and measuring equipment.
sub-Clause 'a' states 'be calibrated or verified, or both'...
With regard to mics and calipers, the question I have is,
Or is there the requirement to record a reading As Found - As Left ?
I do not see this in the standard, but our registrar has told us it is required?
He wants to know if there is anything in the standard that would require the reading of his caliper (side note: I'm not focusing on mics because I'm not as familiar with mics)
You can't achieve validity (noun. state of being valid) without validation (noun. from the verb "validate" meaning to make valid). Who am I making a strawman argument for?
See above.
That comment was in response to what Big Jim wrote in posts #12 and #57.
insect warfare
QA=Question Authority
You have seemed to create your own definition of the word "validity" throughout several posts in this thread to make your point, as I have too. However, the fine folks from Technical Committee 176 SC2 (the same SC involved in the creation and revision of ISO 9001) have already defined "validity" for us in this document, which they fully encourage users such as you and I to apply when using ISO 9001 and 9004.
According to their guidance, "validity" is defined as "conformity to fact, accuracy or precision". The presence of the word "or" is probably the underlying argument with those who oppose your viewpoint. To "validate" is to "carry out validation" as defined in ISO 9001 paragraph 3.8.5. The definition of "validation" has normative status in ISO 9000, which I'm sure you already know.
FYI only - not here to be argumentative, as I've already made my peace in this thread.
Brian :rolleyes:
Sidney Vianna
Post Responsibly
There is a difference between evidence, proof and a record. The latter is the subject of the contention in this thread.
Some believe that there is no requirement for the minimum content of quality records in general and, in this specific case/thread, a calibration record.
I think differently and I believe I pointed out the ISO 9001 requirement which stipulates that a record (including calibration records) must demonstrate that requirements associated with the activity/process/system/product have been complied with.
A calibration process has several requirements in addition to the obvious final result. If we are to allow that records become minimalist in nature, then we could not object to records such as management review records, internal audit records, inspection records, etc... to be summarized with 3 words: It's all good.
Having said that, the adequacy of the calibration record contents could also be affected by the assessment of the calibration process itself: how well defined is it? what is the competence level of the person performing the calibration, etc...
Like you, when it comes to auditing, I believe that we must stick to requirements. But just because section 7.6 of ISO 9001 does not stipulate the minimum contents for a calibration record, it does not mean that the standard does not have a requirement for quality records, in general.
Sidney Vianna
Post Responsibly
The danger is always to say "show me the shall" and to look for one clause to state everything needed.
Indeed, Andy. As you pointed out in the early phase of this thread, ISO 9001 has many linkages. The search for the appropriate "shall" should not stop at the immediate vicinity of the subject at hand and it can be contained elsewhere in the standard.
Pcool
You have seemed to create your own definition of the word "validity" throughout several posts in this thread to make your point. However, the fine folks from Technical Committee 176 SC2 (the same SC involved in the creation and revision of ISO 9001) have already defined "validity" for you in this document, which they fully encourage users such as you and I to apply when using ISO 9001 and 9004.
Brian :rolleyes:
That's a fair point (except for the part about me "creating" definitions). I was looking at the English definition of validity, validate, valid. To make my thinking visible to you:
va•lid•i•ty (vəˈlɪd ɪ ti)
n.
1. the state or quality of being valid.
2. legal soundness or force.
[1540–50; < Late Latin]
val•i•date (ˈv?l ɪˌdeɪt)
v.t. -dat•ed, -dat•ing.
1. to make valid; substantiate; confirm.
2. to give legal force to; legalize.
3. to give official sanction, confirmation, or approval to: to validate a passport.
val?id (vld)
adj.
1. Well grounded; just: a valid objection.
2. Producing the desired results; efficacious: valid methods.
3. Having legal force; effective or binding: a valid title.
4. Logic
a. Containing premises from which the conclusion may logically be derived: a valid argument.
b. Correctly inferred or deduced from a premise: a valid conclusion.​
5. Archaic Of sound health; robust.
because I don't have these definitions in my copy of the QMS fundamentals and vocabulary. Thank you for that resource.
Lets use the ISO definition of validity(because it actually gets to my point more quickly than the English definition), you've made a measurement on a product using a caliper. That caliper is now out of tolerance. You are now going to assess (ISO definition: evaluate or estimate the value of) and record (ISO definition: stating results achieved or providing evidence of activities performed) the validity (as you correctly pointed out: conformity to fact, accuracy or precision) of the previous measuring result. The product had an numerical measurement result from that caliper, to prove conformity to that measurement result you have to show another numerical measurement result from the failed caliper.
On top of that, there are other requirements already mentioned by Sidney and others that show you would need to record the reading of a failed caliper.
Status
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
