ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'?
Status
Not open for further replies.
#21
Re: ISO 9001:2008 Sec 7.6 - Can we just log the devices as 'Pass/Fail'?
What Kees means (I'm sure) is that it's required "to run an effective calibration system which prevents problems occurring"...
"Pass/fail" doesn't employ one of the basic Quality Management Principles - that is "Use of Data". Since no actual measurements are taken, no-one can determine the next suitable recall, and, as been mentioned, there can be no evaluation of the effects of the out of spec. situation on product.
It's all very well chanting the mantra "show me the shall", but the effectiveness of such a system is what's at stake here...
Who said that "no actual measurements are taken"?
#22
If measurements are taken, I fail to see why - if you want to run an effective calibration system - recording pass/fail is going to help. Why not record the measurements. Variables data always trumps attribute in this situation!
You cannot predict - the very heart of an effective cal system - the trends if you use pass/fail...
#23
The question wasn't about whether or not it's prudent to record measurement data, it was about whether recording the data is required by the standard. It isn't.
#24
having a log that only has "pass" or "fail" without any other parameters might make it difficult to assess the validity of previous measuring results. Don't you agree?
What that part of 7.6 means is that when a device is found out of tolerance, you're supposed to try to determine whether any previous measurement of product might have been affected. We must assume, even though the actual measurement data isn't recorded for posterity, that at the time an out-of-tolerance condition is identified, the extent of the error is known and it's possible to determine whether the nonconformity might have affected prior measurements.
#25
If you read 7.6 alone, Jim, that's true. As you well know, the failing is in reading one requirement in isolation of the others! We know there's no "shall", as there isn't for many other requirements - read in isolation.
If anyone wishes to run an effective system, the use of actual recorded information must be used to determine what to do next - planning. You cannot effectively plan for the recall of a device if you only record pass/fail, let alone go back when a problem occurs.
For anyone to simply state "where's the shall?" is doing a dis-service to those who seek to implement an effective system - and strikes at the very heart of why so much bad is written about the standard, IMHO...
Pcool
#26
shall assess and record the validity of the previous measuring results when the equipment is found not to conform to requirements.
Lets break this down:
Shall means required.
Validity of a previous measuring result - For an argument to be valid the conclusion has to be logically entailed by its premises - "pass" or "fail" results are conclusions and have no premises by themselves. Because this "Shall" must record the validity, you have to show the premises that allowed you to reach a pass or fail conclusion.
Equipment because it says equipment.
#27
You have ignored the "assess" part of the requirement. It says "assess and record the results..." which means you must record the results of the assessment--you must have a record of having determined the possible outcome(s) of the device being used to measure product.
Pcool
#28
Without ignoring "assess"(which I already mentioned in a previous comment) the sentence still reads "shall assess and record the validity of the previous measuring results"... it does not say "assess, and record the results"
The subject being validity of the results, not just the results. "Pass" or "Fail" are not valid alone, they need conditions(premises) that make them valid conclusions.
For that reason, StevePenney must show more than just pass/fail.
#29
I think you may be confused about what "measurement results" means in this context, and you might reading something into it that isn't there. Let me explain:
  1. I calibrate a caliper, and find that it's out of tolerance. I know the exact amount of the error.
  2. The result of the calibration is "fail."
  3. I review the records to determine what product might have been measured with that caliper (previous measurement results) and take action accordingly.
  4. I create a record of the actions taken. This record might include reference to the amount of error found in calibration and could be separate from the calibration record itself.
  5. I am in compliance with 7.6.
Pcool
#30
There is no confusion on "measuring results" :frust:
Yes, in this example you would be compliant because you know the exact amount of the error.
To build upon your example:
  1. A caliper is out of tolerance by 5 mm, we allow +- 2 mm of tolerance for a 15 mm space between the components of the product in our process.
  2. The result of the calibration is Fail
  3. I review the records(I have to asses and record the validity of previous measurement results). I see one of the products was recorded as having 14mm of space between components. If it just said "Fail" I would not be able to validate that this product is bad. I have to be able to see the amount the caliper failed by and then take action based on that amount.
  4. I create a record of the actions taken. This record will(Validity is a requirement) include reference to the amount of error found in calibration and could be separate from the calibration record itself.
  5. And then you are in compliance with 7.6
Status
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
