ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'?
Status
Not open for further replies.
#31
Re: ISO 9001:2008 Sec 7.6 - Can we just log the devices as 'Pass/Fail'?
How would I know whether if the device failed if I didn't also know the extent of the failure? Why would I not know "the amount the caliper failed by"?
Pcool
#32
You would "know" the extent of a failure, but a person's memory is not a record of validation.
I thought that you recorded it in your first example when you wrote "I know the exact amount of the error."
insect warfare
QA=Question Authority
#33
Without ignoring "assess"(which I already mentioned in a previous comment) the sentence still reads "shall assess and record the validity of the previous measuring results"... it does not say "assess, and record the results"
The subject being validity of the results, not just the results. "Pass" or "Fail" are not valid alone, they need conditions(premises) that make them valid conclusions.
For that reason, StevePenney must show more than just pass/fail.
"Validity" of an assessment is the degree to which it measures what it is supposed to measure. This is not the same as "reliability", which is the extent to which a measurement gives results that are consistent.
Also, the word "valid" is derived from the Latin word "validus", meaning "strong". When applied to 7.6, the organization need only assess and record the strength (or degree) of those previous measuring results. Thus, "pass" or "fail" can be as valid of results as you need them to be. Would "pass" or "fail" suffice in an industry that relies heavily on variable data for its assessments? Probably not, but there is nothing out there that says attribute data is totally worthless either, when utilized in the appropriate manner.
Brian :rolleyes:
Pcool
#34
Brian :rolleyes:
No, you have to say why it failed or why it passed.
We are looking at the ISO definitions of Validation and the English definition of Validity, not the Latin word "validus" ...
Under the Quality Management Systems Fundamentals and Vocabulary
3.8.5 Validation - confirmation, through the provisions of objective evidence (3.8.1), that the requirements for a specific intended use or application have been fulfilled.
3.8.1 Objective evidence - Data supporting the existence or verity of something.
Billy M
#35
In regards to the calibration or verification, it is acceptable to verify that the device is still in calibration by checking against a calibrated standard with regular frequency (daily, weekly, monthly) and recording on a log or form that it passed. That log or form could be a checklist showing the current status. The problem with calibration frequencies on some devices is that when it is re-calibrated, you must verify the as-received or as-found condition. If it is found out of calibration then you must assess the validity of any previous measuring results. If you are verifying on a regular basis, then the time frame for the device going out of calibration can be narrowed down to a time period within the last verification cycle. But the verification has to be documented. I have used this method for many years with no issues from auditors or certification bodies. As a note, I always put a small procedural content on the bottom of the form that described the process of verification and made sure whomever was doing the verification was trained to do so.
Jen Kirley
Quality and Auditing Expert
#36
Yes, it is required.
A good auditor would ask: How did you determine it passed the calibration? If it failed, how far was it out? If it failed you would want to know how far it was out and take appropriate action. Without the actual data, you cannot answer that question.
I agree with this because the standard starts by laying out requirements for us to design and maintain an effective QMS:
4.1c) determine criteria and methods needed to ensure that both the operation and control of these processes are effective,
d) ensure the availability of resources and information necessary to support the operation and monitoring of these processes...
Only after that does the standard break out specifics into sections like 7.6, which give more details but don't tell us to step in march right-foot-left-foot and to breathe-in, breathe-out. It is the difference between auditing compliance and auditing for effectiveness. If we were to only audit to the "shalls" the 4.1 section would have been left out I think.
:2cents:
#37
:2cents:
Madness this way lies. I can't imagine that you believe it's a good idea for auditors to be able to invent their own criteria for effectiveness or their own "shalls."
Jen Kirley
#38
I don't invent the criteria for effectiveness, I discuss the subject with my client and explore with him what his calibration system is trying to achieve. I'm not Judge Judy, I do not write NCs without the client fully understanding the nature, context and reason for them - and I make sure to receive their agreement to the NC before the closing meeting. I make sure we are aligned that the audit is not to simply confirm the shalls are met; it is to verify effectiveness, definition of which we arrive together to ensure there's no wasted effort in asking for a system improvement.
The monitoring and measurement system, of which calibration is a small part, is meant to help make sure the organization's goals are met through valid, reliable measurements. Those two terms don't mean the same thing; asking for an understanding of the instruments' performance is, I agree more than asking for an out-of-tolerance tool to get calibrated.
I think this sort of thing comes down to why we have a QMS. If it is to meet the shalls and maintain a certificate, then we can do the minimum specified in 7.6. If we want our calibration system support our competitive market position by truthfully measuring critical characteristics in a reliable manner, we can ask for more than reactive measures (recalibrating an out-of-tolerance instrument). We don't need to do a full-blown MSA study like automotive does, but we can pay attention to instruments' performance over time and maintain confidence in them.
On the flip side [of what we Navy folks used to call "nuking it" because of the extreme measures the nuclear engineers wold take on their process controls], this kind of analysis can sometimes justify lengthening calibration cycles and saving calibration costs.
If our OP wants to contest the NC he might succeed in getting it reversed. But if he wants a robust system he might consider going past the reactive measures listed in the shalls.
:2cents:
Kevin Mader
One of THE Original Covers!
#40
....If our OP wants to contest the NC he might succeed in getting it reversed. But if he wants a robust system he might consider going past the reactive measures listed in the shalls.
:2cents:
Win the battle....lose the war.
Status
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
