ISO 9001:2008 Sec 7.6 - Can we just log measurement devices as 'Pass/Fail'?
Status
Not open for further replies.
Big Jim
#51
Re: ISO 9001:2008 Sec 7.6 - Can we just log the devices as 'Pass/Fail'?
Mathematic is the difference between the standard's value and the measured value.
Would you allow a practice like using a micrometer to calibrate pin gages? The 10:1 rule isn't in the standard.
The act of calibration in dimensional tools is mathematical comparison between a known value and an assessed value. Its result is a number. If the number exceeds the allowed limit or not, a decision is made. But that is what is derived from the measured value; the value is the result.
I never mentioned the 10:1 rule. You have brought it up as a defense, and it just doesn't fit the scenerio.
Actually, the 10:1 rule isn't always appropriate. From earlier posts here from those that mainly deal with 17025, sometimes (and if I remember correctly mor often than not) it is 4:1.
The real point is that the 10:1 (or 4:1) rule has no bearing on this topic.
You have moved into requirement creep, imagining that there is more to it that what is in the written word.
How long are you going to try to keep this spinning?
Pcool
#52
Wow this thread is going off on tangents... Lets bring this back to just 7.6, no spinning is necessary to see the requirement.
Here is a scenario: You have been using calipers to measure components for products. The next morning, a caliper is tested and found to be out of tolerance. You know that a few products have been measured using that caliper before it was found to be out of tolerance by another employee. What are you going to write when you assess and record the validity of previous measuring results from that equipment on the affected products? All you have is a log that says the caliper failed.
What are you going to write down so other people know why the equipment caused a defective product? :deadhorse:
BradM
#54
It would appear that you conveniently left part of my post off in your quote here:
That, in a nutshell, describes what has happened to this thread.
How many angels can dance on the head of a pin?
So here is the entire post:
You cannot legislate morality. And you cannot ( and do not) want to try to have an international standard that mandates every jot and tittle.
There is too much to gain by writing down the actual raw data when performing calibrations. Write the data down.:2cents:
BTW... four angels can "fit" on the head of a needle.:cool:
Without seeing the actual write-up and the auditors observations, there may be solid evidence for the findings as a by-product of some of the other required standards.
It's also possible the auditor was referring to other standards besides ISO 9001.
If I paid somebody for a calibration and all they could produce is a pass/fail evaluation, I ask for my money back. That to me, is not a calibration.
Back to the OP's question, I would be interested to find out more as to what the findings was surrounding, what was cited, etc. At this point, it appears to be nothing more than speculation.
But instead of arguing that it is not a requirement, given that paper and pens are pretty cheap, it takes no additional resources to record it and much is gained by recording it, I would thank the auditor for the chance to improve the process, implement, and start gaining from the benefits.
BradM
#55
I don't think anyone here, with the possible exception of the OP, thinks limiting the record to pass/fail is a good idea. You also don't want auditors making up their own requirements, though.
I agree Jim. :agree1: Being privy to the write-up, what was observed, etc. would help.
Generally I don't like any knee-jerk responses. Many times they lead to silly patches for things that aren't broken in the first place. But anytime any recommendation is made to record data, I would say it's a good thing. :2cents:
#56
Have you ever told anyone about the 10:1 "rule"? Would you allow the practice of calibrating a pin gage measuring to millionths using a micrometer measuring to ten thousandths? It's not in the standard.
There is no universally applicable 10:1 "rule" or 4:1 for that matter either. It might become a rule if I make it one, for my system, but otherwise it's only a guideline.
What is being recorded: the measurement when comparing the instrument against the standard, or the decision to accept/not accept? Both of which are included in good practice calibration documentation, with accept/not accept recorded as pass/fail for as found condition.
You're being very selective in your definitions. How about, as a definition of "result," A consequence, effect or outcome of something? Is "Pass" not an outcome?
7.6 requires a record to be kept of the results of calibration and verification. The FreeOnlineictionary defines results as Saying merely "pass/fail" is record of a decision, not the value.
This last makes no sense, I'm afraid. There is nothing anywhere (except in the tortured interpretations of some in this thread) that says that numeric values must be recorded.
Big Jim
#57
What more would you know if you did have the actual measurements? NOTHING. You know it failed. You know when you found it to be out of specification. You know the last time it was checked. So everything measured in the interval from the last time it passed until it failed becomes suspect. How is that changed because you recorded the actual measurements? It hasn't.
Big Jim
#58
Yes. About as good as "day-time"/ "night-time" is to asking what time it is. :)
That is not a good analogy, but since you brought it up, sometimes "day time"/"night time" is enough.
Big Jim
#59
And you know for a surity that four angels can fit on the head of a needle? Why not thousands? Why not one would cover many needles? This falls into the realm of the unknowable.
I would agree that it is a good practice to write down the readings, after all, they had to be at least mentally noted in the process of determining pass/fail. But that isn't the question here. The question is really very simple. Is it a requirement. No matter how much you would like it to be, it simply is not.
Big Jim
#60
I have no arguement that it is a good thing. It just isn't a requirement.
Status
Q What is the ISO 9001:2008 certificate status after 15 Sep 2018? Registrars and Notified Bodies 7
Q Surveillance Audit of 2008 before Transition Audit to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T ISO 9001:2008 to 2015 transition - How much work to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Upkeep of ISO 9001:2008 during Transition TO ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna IAF Ruling - No more ISO 9001:2008 nor ISO 14001:2004 audits after 2018-03-15 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
W Internal Approval of Deviations - ISO 9001:2008 & ISO 13485:2003 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
D Customer Audit - Root Cause Help - ISO 9001:2008 Cl. 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Incorrectly Performed ISO 9001:2008 Internal Audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Total number of Requirements for ISO 9001:2008 vs. ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
P ISO 9001:2008 Design and Development Process & Forms examples wanted Design and Development of Products and Processes 3
P Need a new video for employee training ISO 9001:2008 Training - Internal, External, Online and Distance Learning 6
J ISO 9001:2008 - Can I still conduct Internal Audits in my company? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Objective and Goals - ISO 9001:2008 Frequency Revision Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Internal Auditing Requirements (ISO 9001:2008) Internal Auditing 3
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 Surveillance Audit - No Internal Audits Internal Auditing 9
P Small company of approx 28 Employees - ISO-9001:2008 Guidelines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T TS16949 - What extras over the ISO 9001:2008? Gap Analysis IATF 16949 - Automotive Quality Systems Standard 5
P Tasked to change ISO 9001:2008 to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
K Must I update the Quality Policy? (ISO 9001:2008) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
C ISO 9001:2008 to 2015 Transition Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Tailored ISO 9001:2008 for DLA (AS9100) (AS9003) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Marc ISO 9001:2015 vs. 2008 - Internal Audits - What changes are you making? Internal Auditing 44
B Global / Local Management Review - ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Steps from ISO 9001 2008 to 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Should ISO 9001:2008 be treated as a standalone quality standard alongside AS9120A? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M How important is a Quality Manual - ISO 9001:2008 to 9001:2015 Quality Management System (QMS) Manuals 95
Q Criteria for not rising NCR's in 8.3 of ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Large vs. Small Quality Manual - ISO 9001:2008 Clause 4.2.2 Quality Management System (QMS) Manuals 19
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T 8.3 ISO 9001:2008 Nonconforming product ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q What to consider in 6.4 work environment? ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Records Retention and Disposition - ISO 9001:2008 Requirements Records and Data - Quality, Legal and Other Evidence 5
S ISO 9001:2008 Lead Auditor Exam Fail - How to follow up? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Should we register to ISO 9001:2008 or ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Audit Nonconformance - ISO 9001:2008 Clause 6.2.2 - Competencies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
A How best to start revising an existing ISO 9001:2008 system in a company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q ISO 9001:2008 requirement for Design Organization Approval prior to "Repair" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J In the ISO 9001:2008 company, can give reference to sister company also. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H ISO 9001-2008 Violation Tickets Misc. Quality Assurance and Business Systems Related Topics 12
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
D Hard cut off date for certificates to be issued against ISO 9001:2008? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E ISO 9001-2008 Purchasing controls ? Issuing POs Without Specific Approvals Quality Manager and Management Related Issues 8
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
H ISO 9001-2008 Management Review Management Review Meetings and related Processes 3
R Clause in ISO 9001:2008 for Requesting Material from Customer Service Industry Specific Topics 9
F Implementing ISO 9001:2008 in a new Food Processing company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
