ISO 9001:2015 4.4.1 - Providing Evidence of QMS Processes "Shalls"
ogghall
Regarding the processes that an organization has determined, ISO 9001:2015 4.4.1, what may be some examples or ideas on the ways to provide evidence of some or all of the "shalls" listed in a-h?
The Specialist
Ogghall, I have added a summary table to start you off...
Hopefully, this will give fellow covers a better overview of your question...
I will also work on some examples for you.
Good luck.​
4.4
Quality management system and its processes
beginning
4.4.1
Establish, implement, maintain and improve a process-based QMS
The company is free to decide how to apply the QMS without forgetting the issues (see sub-clause 4.1) and requirements (see sub-clause 4.2)
4.4.1
Determine the needed processes and their application
"If you cannot describe what you are doing as a process, you do not know what you're doing. Edwards Deming". Process map
4.4.1 a
Determine process inputs and outputs
Process sheet
4.4.1 b
Determine the sequence and interaction of processes
Flowchart
4.4.1 c
Determine the criteria and methods to control processes
Tools of the quality manager
4.4.1 d
Determine and ensure the resources
Needed to support processes. Cf. sub-clause 7.1
4.4.1 e
Assign process responsibilities and authorities
Job description of process owners
4.4.1 f
Take into account the risks and opportunities for each process
Plan and implement actions to address these risks, cf. sub-clause 6.1
4.4.1 g
Evaluate processes and if necessary modify them
Identify methods to monitor, measure, check and modify processes. Cf. sub-clause 9.1.1
4.4.1 h
Determine the improvement opportunities of processes and the QMS
Cf. sub-clause 10.1
4.4.2
Maintain documented information on process operation
Cf. sub-clause 7.5. The bare essential is sufficient. Use process map
4.4.2
Retain documented information on process operation
Cf. sub-clause 7.5. The goal is to ensure that processes' results are those planned
The Specialist
Unfortunately the table hasn't posted very well!
But I think it is still readable.
JoShmo
Process controls aren't the Quality manager's responsibility, they are the Process Owners. Don't forget, some organization function without a "quality function" and ISO doesn't require a "management rep" any more.
ogghall
"The Specialist" Thanks for the reply. I don't have a problem with understanding what is being required. What is more of the issue is how to provide in a concise and simple way, the evidence of the requirements.
We are a large organization under a multi-site certificate. It seemed apparent this year with some of audits (to 20008 rev) that the 2015 rev audits will focus on how we have established our processes and how we can show evidence of these requirements in 4.4.1. I was thinking more in line of a table or registry that could provide that.
I believe this would be helpful not only to the auditor, the audit efficiency but also to our locations who end up having to supply some of this information.
RoxaneB
Change Agent and Data Storyteller
I may be looking at this in too simplistic a manner, but if your organization knows what is required and has implemented processes that conform to the requirements, are not the results of the processes (e.g., records, indicators, etc.) evidence of said conformance?
So, you're proposing a table of some sort that will show the outputs of the processes? In this case, my guess is such a document would be unique to each organization.
Out of curiousity, would the output from the processes vary between your organization's sites? That would certainly be interesting and possibly a discussion point with your auditor - not necessarily a nonconformance, but I know I'd be wondering why the output type wouldn't be standardized (results may vary, but I would expect the output type to be consistent).
It could help in audit prep, no doubt about it...however, and perhaps more importantly, is how it could possibly add value by providing a common direction for the organization. If you are looking to document the output types per process, this essentially can become a scorecard for the locations. Internal benchmarking becomes possible now and lower performing sites don't need to re-invent the wheel when trying to improve.
RoxaneB
Agree...but...when I looked at the "table", it struck me that it really was heavy on the QUALITY management system side of things and lacking in the BUSINESS management system components. Maybe the links would take us into process controls and process monitoring for the product, yet at first glance it doesn't seem to address these.
That said, if "Tools of the Quality Manager" was altered to "Quality and SPC tools", I probably would have liked the table more.
In some organizations, the Quality Manager/Department/Process Owner is responsible for the implementation of the quality tools, yet it is the responsibility of the other Process Owners to apply them. Like Document Control...I was the process owner of Document Control, but if a department decided to not follow the doc control protocols, they received the finding, not I.
As for the Management Rep., sure it's no longer a requirement, but for some organizations, especially the larger ones with multi-site certifications, having a centralized individual to help coordinate and consolidate management systems activities can be a good thing.
Kronos147
In our system, 4.4.1 a, b, are in the manual (yes, we kept ours, info is in the process ID and interaction section), c, d, are management review, e is the org chart, f is embedded in their process (we applied Risk Management at the process level), g per process, h Management Review.
An example of Documented Information (i.e. objective evidence) of our addressing Risks and Opportunities would be our Quote Review process. Part to big for our machines? Will the customer commit to a contract and help us buy a bigger machine? It is on our quote review form. Production - we want to try to use a lathe instead of a mill. It may be documented on an internal NC, and our production travelers (i.e. planning) is rev. controlled.
Don't overthink this stuff. You are probably doing it. Your job is to know what you do, make sure the process owners know how to answer the question what you do, and to make it clear that is what you do in the Documented Information.
ogghall
Kronos147, In one sense I agree with not overthinking it and that would easier if our organization and QMS was contained in a single location for example. We maintain a multi-site certificate with domestic and international locations. Identifying the evidence and communicating it throughout the organization becomes more difficult. Also especially with the new revisions to the standard the ISO requirements may not be as totally understood as it can be in a more localized organization. Creating a more direct link between what we do to the specific requirements so the organizational understanding is there is what the goal is.
dhakadmilind
HI ,
I have recently attented the course for iso 9001:2015.
During training ,we have dicussed this topic for demonstarte the risk base approach.
The results are,
A)We must have process mapping intial one
B)Risk date sheet 0r register:-Which records the risk considered and its mitigation plan
c)By consider B, we have to redesign the process mapping (As shown as Fig 1 in standard)
C How to to become an ISO 9001:2015 consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Computerized System Validation in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Experience Records - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
