ISO 9001:2015 - 5.3 - The roles and responsibilities matrix rears it's head
normzone
Hello again all -
I find myself looking at methods of meeting 9001:2015 - 5.3 regarding " responsibilities and authorities for relevant roles are assigned, communicated, and understood within the organization "
Previously it was believed that the organization met this requirement thru organizational structure documentation, job descriptions, et al.
But we contracted for a second opinion recently, and the contractor expressed the opinion that this would best be met thru a matrix. Please feel free to read between the lines.
I have found no satisfactory examples on line, which is alarming.
I also question if 9001:2015 a) through e) are adequate, or how deep the rabbit hole could get.
As always, thank you for your counsel, and welcome to the imminent weekend.
Tagin
In the top-level doc for each process I have an "Authorities and Responsibilities" section, where I list which job roles have authority to do what, and then list what responsibilities various job roles have. That has worked well.
Consolidating it all in a single matrix seem like a complication. I understand the idea that it makes it easy to see what auth/resp a particular job role has across the company, but it doesn't seem worth it.
I don't quite understand what you mean by 'adequate'. Those are very high-level requirements which almost certainly you will be performing if you fully implement your QMS. It doesn't specifically say you need to document a-e or have records, but you will need to be able to speak to those points in an audit. (Auditor: "show me how you promote customer focus throughout the organization")
qualprod
Sometimes auditors
Hello again all -
Sometimes auditors, want the information arranged for easy reading
It also could work a matrix , same results compared to use job descriptions.
Michael_M
We use an Organization chart and job descriptions. Remember, the standard tells you what you must do, how is up to you. I suggest not letting auditor's or 3rd parties demand you do it their way. If you meet the requirements, show how you meet the requirements. If you think creating a matrix will add value then create a matrix. If you think the matrix is just 'extra' work and adds no value just to please the the auditor/3rd party then I would not create it.
normzone
[Tagin], I like the approach of having that specified in the process documents and work instructions.
Regrettably a large part of my current mission is QA - Quality Archaeology. My client's documentation is archaic and outdated - and cannot be relied on to contain that information accurately at this moment.
[qualprod], I believe you are correct. I have found some examples online but they are byzantine in their complication.
[Michael_M] and [Tagin], regrettably I am just the hired gun, and my employer felt it was easier to appease the auditor than argue the point. Now I am looking for a rational method to satisfy everyone.
Kronos147
To the OP:
First, hello.
Second, I made a table for our organization. The columns are the following:
Process
Owner
Internal Requirements\procedure\work instruction
ISO 9001 Requirements
Risks and Opportuntities
Key Performance Indicators\Objectives
Relevant Interested Parties\Needs and Expectations
Training requirements
I list all the processes and figure out what goes in each cell.
I make sure the internal audit plan knows\confirms all this stuff.
Respectfully,
Capt. Overkill
Big Jim
Keep in mind that you get to choose how to meet that requirement. A matrix is one of the ways. So is an organization chart and/or job descriptions. Do what works best for you without going down the rabbit hole.
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
