ISO 9001:2015 7.2 Competence
Good afternoon,
Our organization has a job description for every position with minimum education and experience background required. Besides, we provide job-related training and keep records of it. Our Human resources procedure says that managers can consider other criteria or referrals and might hire someone without minimum requirements described in the job description. Each year we discuss with our ISO external auditor, and he says that we can not do that. What is the best way to address this issue? As per my understanding, we are complying with clause 7.2 competence by proving job-related training and addressing in our procedure that managers might consider other criteria. Please suggest the best way to address this issue.
Marc
Fully vaccinated are you?
What you really need to do is a search here using the key word competence. This has been discussed extensively MANY times in discussions here.
E.g.: When exactly was "competence" added to the ISO-9001 standard?
site:elsmar.com competence at DuckDuckGo
This is silly. The 2015 standard was published about 4 years ago and the issue with your auditor has still not been resolved?
Thanks for pointing out resources. We haven't hired any employees who do not meet our job description requirements until now. But now we need to hire one on a particular position because of top management requests that is why questions on how to address competency on this particular case re-appear. Anyway Thanks.
John Broomfield
The managers calling for the new hire will know what abilities, skills and knowledge they need from this new employee. Accordingly they develop the job description so the recruiting process can seek candidates who likely will be able to do the job well.
On selecting the new employee they may offer the job for a trial period or not. New employees usually work under close supervision (of a competent supervisor) until they have shown themselves to be competent.
Training may be required to impart any missing abilities, skills or knowledge.
So, where is that new job description or job specification?
Golfman25
With due respect to your auditor, you can do whatever you want. The job descriptions set min. criteria regarding background and education. Your procedures, rightly allow deviation if necessary. None of this has anything to do with "competency." Presumably, based on experience your min. criteria make it highly likely the hire will be competent. But, there aren't any guarantees. You'll still need to evaluate competency.
Sidney Vianna
Post Responsibly
Competence is not an attribute, but a variable. There are degrees of competence, and between you and me, your external auditor is not very competent either. A competent external auditor CLEARLY identifies the requirement your organization is not in conformance with. Just to say: "you can't do this" is not an outcome from a competent CB auditor.
Requirements for competence obviously depend on the job at hand. Some will require very formal academic proof, such as having a Professional Engineering License in the State of...., a Registered Nurse Certification in the State of...., etc... Most jobs don't have such requirements. The record required to demonstrate "evidence of competence" CAN BE a combination of training records, performance appraisal/reviews where a line manager confirms past performance and describe future actions to enhance the subordinate's degree of competence, certificates, diplomas, etc....
Your auditor is likely correct. The standard is VERY clear on the topic.
7.2 "The organization shall: a) determine the necessary competence of person(s) doing work under its control that effects the performance and effectiveness of the quality management system . . . "
It is a requirement that the organization "determine the necessary competence".
Further it states "d) retain appropriate documented information as evidence of competence".
The standard doesn't require that you use job descriptions to determine the necessary competencies. There could be other ways. Job descriptions are commonly used for this though. Complications arise when job descriptions also are used for other things such as recruitment or a place to cover HR requirements.
One should keep in mind that job descriptions belong to the organization and they have the ability and authority to change them as needed. If the job description doesn't match the best candidate THEN CHANGE IT.
Make it work for you, not work against it.
Don't blame the auditor when he finds a weakness THAT YOU COULD HAVE AND SHOULD HAVE FIXED.
Golfman25
Baloney. Their procedures allow them to deviate from the "job description," whatever that is. We have no idea whether their "descriptions" even address competency vs. background. As long as they evaluate their employees' competency do to the job at hand and have records of that evaluation, they should be good.
Mike S.
Happy to be Alive
Do what you think is right and what works for your business. Discuss it among yourselves and make sure you believe it meets the requirements of the standard.
If the auditor doesn't like it, make him write it up as a formal NC citing the requirement and objective evidence of how you don't meet it, and go from there. Once everything is documented, including the NC if the auditor writes it up, things should be less ambiguous. If the NC is bullcrap, then appeal it. Won't be the first BS NC written by a registrar auditor, won't be the last.
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 5
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 5
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
