ISO 9001:2015 - 8.4 Control of externally provided-Distributor & drop shipments....
ogghall
The 2008 revision required ensuring control outsourced processes. My question is does the 2015 revision requirement now require the same level of control to be applied to these outsourced processes that had and still are for the traditional purchased product? For example would calibration services, equipment maintenance, transportation, and employment recruiting services now require, "evaluation, selection, monitoring of performance" criteria be determined and applied for them? Where in the 2008 standard they were required to be controlled to the "type and extent" we defined?
BoardGuy
Re: ISO 9001:2016 - 8.4 Control of externally provided ......
Most of what is contained in ISO 9001:2015; Section 8.4 comes from a number of locations within ISO 9001:2008. Clause 4.1, Note 3, Control of Outsourced Process (under scope of your registration), 7.4.1, Purchasing, 7.4.2, Purchasing Information, and 7.4.3, Verification of Purchased Product
Outsourced Processes are process you have not excluded from you scope of registration such as design and development, Section 8.3 of 2015. In the example of design and develop, when you outsource this work to a 3rd party you are not absolved of the responsibility of conformity to ISO 9001:2015 Section 8.3, customer, statutory and regulatory requirements.
The good news is when some of these processes are outsourced, such as calibration; you communicate the requirements from Section 7.1.5 to your calibration service via a purchase order and then verify their compliance upon receipt. Other elements of 7.1.5 you perform in-house such as reviewing the calibration certificates for out of tolerance conditions and adjusting calibration intervals.
Measurement of supplier performance is not new. Organizations and their certification bodies may have overlooked a measurement of supplier performance in the past but now it more directly stated in 2015.
ogghall
In the 2008 revision 7.4 dealt specifically with Purchased product. As you mentioned most of what is in 2015's 8.4 comes from 7.4 except that 8.4 also includes "externally provided processes..." It does now appear as "howste" answered Yes to that the standard is requiring the "evaluation, selection, monitoring of performance" of those other processes outsourced. 2008 4.1 did not require the same amount of control so to speak as 8.4 now does. For the most part I am not referring to the complete outsourcing of a process but certain portions of a process. For example some calibrations, some external maintenance, etc.
I think referencing 7.1.5 regarding calibration besides identifying requirements in a PO now requires more then reviews of the certificate for the calibration results but includes how calibration facilities will be evaluated. For example their delivery, the quality of their calibrations, the quality of their paperwork, etc. And the records of those reviews.
Thanks for the response
BoardGuy
Yes ISO 9001:2008 4.1, Note 3 does speak to requirements of outsourced process because if you did outsource them the note becomes applicable and must be applied in some form. 4.1 now show up as 8.4.2 D) without the reference to “outsource”.
Don’t over think requirements of 8.4. Yes, you are more directly required to apply appropriate controls to the organizations direct and indirect suppliers to assure requirements for product and service can be net but you must do so within resource constraints of your organization.
What are some of the requirements for outsourcing calibration? That would be Section 7.1.5 along with 8.4. Design and development, Clause 8.3 plus 8.4. Special process supplier like plating would be Clause 8.5.1 plus 8.4.
Hope this helps.
Kronos147
I think a little difference between ISO 9001:2008 and 2015 is that the auditor will also be poking around for Risk Based Thinking and how it was integrated into your system.
LUV-d-4UM
re: ISO 9001:2015 - 8.4 Control of externally provided-Distributor & drop shipments....
If your company is a TIER 1 supplier to OEM, is it mandatory to have your supplier certified for ISO/TS 16949 Requirements? Thanks.:)
dubrizo
Depends on the particular OEM's requirements. IATF 16949:2016 goes so far as to state that suppliers of automotive equipment shall develop a QMS which is to become certified to ISO 9001 with the end goal of certification to IATF 16949 (unless otherwise authorized by the customer).
Hope that helps a bit
RocknRonFoster
8.4.1 I am really confused on this issue. Controls of External Providers/Drops Shipments
We are authorized Distributors for several lines. We Drop Ship bearings, motors, etc, directly from the Manufacture to the Customer. For Controls we have always used our AVL, Supplier Performance and have then Vendor send us their Manufacturers Certs and their pack slip.
My auditor states this is not sufficient for control. He suggested source inspection at the Vendor whenever we have a drop ship. What??
Any suggestions??
Sidney Vianna
Post Responsibly
You are probably dealing with an inexperienced auditor. You have to ask the auditor what EXACT requirement would force a distributor to inspect a product intended for drop shipment, manufactured elsewhere. Especially when the product is delivered with a manufacturer certificate of conformity.
When an auditor basically comes to a conclusion that a business model tested and tried for decades is inadequate, someone must question this auditor's business acumen.
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
