ISO 9001:2015 8.5.1 f - Scope with customer special process requirements
qualprod
#11
First of all, your company determines what, in your company and its processes, are "Special Processes". For example, two companies may both have welding as one of its processes. Note that I say YOUR COMPANY DECIDES what its special processes are. A very good example is Special Process Suppliers - It is about special process suppliers, but it shows what processes Cessna (in this case) have defined as special processes related to their product parts. Once the parts have been installed on an airplane it typically takes destructive testing to validate that the process was effective - Which isn't realistic.
  1. In Company 1 they weld a small widget which holds a shelf up in a small, short book stand. They would probably not consider welding a "special process". Failure woud not cause serious injury. Risk factor is low.
  2. Company 2 welds motor bike frames. The risk factor for serious injury or death if any of their welds fail. They would definitely consider welding, in their scenario, a "special process". Extremely high risk factor.
See: Special Processes - Can anyone give me a definition of what a Special Process is?
I also highly recommend reading Don Brecken's article from around 2009: http://asq1001.org/papers/Identifying Special Processes.pdf
Also consider: Definition of Special Process - IADC Lexicon
Thanks Marc
I think a key point in this is, the customer requirement.
If needs long lasting, weather resistant , ok I,ll apply the clause.
If the need is just label within certain dimensions and color, ok for that, don't need destructive testings, and as such , I indeed really can verify product and clause is not applicable., is it ok my idea?
On the other hand, in a work shop where is manufactured steel sheet equipment, like bins, pressure vessels, steel supports, and in all of them , the welding is used to joint parts.
Such processes have to be declared applicable?
But what do customer have to ask us regarding equipment as for us to decide if is special process?
Marc
#12
I have touched on each of your 2 points in previous posts. I get the labeling thing because I wrote test plans in the 1980's which included similar requirements for packaging of electronic "spares" which could, for example, be stored in the sun anywhere on earth. But again, the tests were for supplier materials in the case of labels. Since it was a customer requirement there could not be any type of exemption.
Application of the labels was one of our processes. We did not consider it to be a "special process" because adhereance wasn't identified as a potential failure mode. This was just our thinking at the time.
Now you're back to processes for diferent parts. Like airraft turbine blades are critical as are most pressure vessles. Sheet metal for bins probably isn't critical, but their use woud determine yes or no. Steel supports? Again, use would determine whether welds would be critical.
I simply can't further explain other than to repeat what I have said: customer requirements may play a part in determining some of your company's special processes. The customer doesn't have to "ask" you anything other than to say these are our requirements. Can you meet them? Maybe you can with the equipmet you have. Then again, maybe you would have to buy some new equipment. Your customer may also have input into their "special process" requirements for your company.
Coming full circle: You get a Request for Quote, you have a Contract Review. Your Contract Review should address all requirements, needs for testing, needs for new equipmet, and much more.
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
