ISO 9001:2015 - 8.5.1 - Routers not being signed
Hybrid
the validation, and periodic revalidation, of the ability to achieve planned results of the processes
for production and service provision, where the resulting output cannot be verified by subsequent
monitoring or measurement;
Have an audit coming up and noticed most of our routers that are filed haven't been signed off. I took the position of QC manager 2 months ago and strictly enforced routers to be signed from day 1 and it has been working.
I am afraid of the auditor pulling routers from before i became manager and ding us for it.
How can i prevent this?
Randy
Is there a specific requirement (in this case your requirement,) that routers be signed? Do you require it? Either Yes or No
Mike S.
Happy to be Alive
Why did you start to "enforce" the signing of routers?
If you require it (make it a "shall") for whatever reason, you have to do it or else it is a NC. If it is a "should" it is not a requirement.
Sounds like (correct me if I am wrong) it was not a requirement before you became QM and you made it one, so routers before "you" are not in violation of a shall, so no NC.
mnobrien
Technically you could likely avoid any NC by simply documenting a change to your procedure(s) to now require sign-offs with a clear implementation date (any docs that pre-date would not be 'nc-able' due to the effective date of the process change).
But if you want to pad your binder with easily obtainable evidence that addresses other ISO req's....I would do the following...
-Write an internal audit non-conformance for that clause that your system fails to address the requirement. (+1 for evidence of internal audit program)
-Review the audit finding in a management review session (+1 for evidence of mngmt review inputs)
-Document the corrective action plan as an action item (+1 for evidence of mngmt review outputs)
-Determine the risk (if any) before action item is complete...a simple yes/no is what i use (+1 for evidence of risk assessment)
-If there is risk, document the mitigating action (+1 for evidence of risk mitigation)
-If team determines 'no risk' then no action needed
-Codify your Action Item... i use the following 'AI Codes': QI = QMS Improvement , R = Resource Addition , PI = Product Improvement
- this case would be a 'QI' (+1 for evidence for 9.3.3)
-Implement the Corrective Action (+1 for evidence of corrective action)
-At the next management review...review 'effectiveness' of this action item (+1 for evidence of corrective action)
Doing this changes this whole situation from just trying to avoid an NC during your ISO audit, and turns it into a storybook/portfolio of evidence that demonstrates that your system employs and complies with several ISO requirements.
Good luck and let me know if you want a template of how I show the above.
-Matt
Randy
Or keep it simple and take the signature block out. If it works for you and you still get what you need, go for it cutting out the piddly bull.
Jen Kirley
Quality and Auditing Expert
I take it that this signoff takes place after the job run is completed - is that correct?
Signing routers is not process validation or re-validation. It is more like an act of monitoring, or verification that something was done (or the document says it was done).
If there were problems that this post-process review should have caught but didn't, maybe the monitoring is important. I agree that if this post-process monitoring is important to you, and if you are worried about an audit NC you can start an internal NC. If this is just a signoff for the sake of signing something, I also would support the corrective action to be taking off that signature block.
Conrade
Do you have a documented 'WIP Product Identification and Traceability' system (not necessarily huge procedure, can be a Matrix)? This proved useful in defending your elected approach. If Automotive, consider review of risks identified in PFMEA and related Control Plan. This review should impact related Work Instructions / SOP's
C Computerized System Validation in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Experience Records - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
