ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6'
First paragraph under 8.1. Will someone explain what is meant by:
So is this saying we have to plan and control the processes used to implement the requirements of 6? As 6 is the planning section, is this planning not already implied?
Or are we talking about actions from 6, that may apply directly to our production planning for a specific product or service? Certainly this might apply for risks and opportunities identified under 6.
Big Jim
It is a little redundant as you noticed. The main thing though is if the risk mitigation involves anything is Section 8, Operations, then Operations Planning (8.1) says that you Operations Planning needs to address the risk mitigation.
So if you identify a risk during the build of the product you need to plan on how to control the risk. A common way is to include it on the Traveler. Creating the Traveler is often one of the main elements of production planning.
I have found that to consider it this way works:
Let's say in considering the Context of the Org, the leadership identify that it's a risk to the QMS to not have sufficient skilled people - they just aren't available (sound familiar). So, to address that risk, the organization decides to attract some high-school graduates and train them in a kind of apprenticeship program, involving a local community technical school, or trade school.
Using section 6 requirements, the idea would be to develop the QMS process(es) to address the development and implementation of the apprenticeship programme. There's a good chance that, since the org. never did this type of training before, the current QMS process(es) aren't sufficient for the task - and hence the need to plan, define what is going to be done, who is responsible and so on (listed in section 6). Nothing redundant here. The resulting process(es) are then deployed to meet section 8 requirements.
Jen Kirley
Quality and Auditing Expert
Simply put, do what you planned to do as per your risk determination. Don't just make plans.
qualprod
Andyn
When yo say "are then deployed to meet", I think those are the plans for the mitigation of the risks?
Andyn
If the risk is a lack of skilled people (in my example) then the deployment of the apprentice training process is going to be the way to address this risk. I am careful to keep away from using (professional) risk management terminology, since I don't believe the ISO 9001 standard terminology needs elevation to such a vaunted level... But, whatever you want to call it is fine by me.
Paul Simpson
Some good points made earlier.
As has been mentioned clauses of 9001 are structured to follow a strategy development / risk management process.
  • It all starts in 4.1 where you are expected to identify 'issues' (risks and opportunities) your QMS is intended to manage. Typically at the organisational level.
  • In 4.4.1 f you are expected to address risks and opportunities associated with the processes you operate
  • In 6.1 you plan to deal with all the risks and opportunities identified
  • In 8.1 you implement operational controls at the process level (see 4.4.1 f again) to manage process risks.
Hope this helps.
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Does the ISO 9001:2015 standard require a disaster recovery plan or emergency response plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S ISO 9001:2015 & ISO 14001 Re-Certification Audit Preparation ISO 14001:2015 Specific Discussions 8
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
