ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records?
W
wywy2020
Documented information now includes procedure and records.
7.5.2 Creating and updating
c) review and approval for suitability and adequacy.
For records, does it applicable for review and approval?
e.g every record need for peer review and approval?
Pancho
wikineer
Re: ISO 9001:2015 Clause 7.5 7.5 - Is Review and Approval applicable to Records?
Hi Wywy,
The first paragraph of 7.5.2 is key: "When creating and updating documented information the organization shall ensure appropriate:"
"Appropriate" review and approval of a document is what will ensure that you deliver quality. Your organization determines that.
For example, in our organization, a few records may require a supervisor's review and approval. Some may also require review and approval by the client. Many more may require no review nor approval by anyone.
Hope this helps!
W
wywy2020
Hi Wywy,
Hope this helps!
Thanks for the reply. SO the key word here is "appropriate" mean the organization decide it on their own.
Is there a scenario that the organization deem it is appropriate but somehow auditor feel it is not? haha
Pancho
wikineer
That is indeed possible, but if you show quality, the auditor has no argument. Conversely, if you are having non-conformities caused by inadequate review or approval, then such activities (or their absence) are not appropriate.
W
wywy2020
It looks like ISO 9001 is always subjective then....more to judgment by auditor. And can be differ auditor to auditor....
Pancho
wikineer
Of course ISO 9001 is subjective. Quality is subjective. But it is your clients who's really judging whether or not you are providing it.
Auditors are not there to ding you. They are to help you spot quality issues that your own people may miss. Know the standard and demand from auditors quality in their own service.
BoardGuy
Clause 7.5.2 does not apply to “records” as there is no requirement related to retaining documented information as evidence of conformity within in this clause. The clause that relates to records would be Clause 7.5.3.
There is, however, requirements related to records such as release of product and services found in Clause 8.6 (i.e. receiving, in-process and final inspection). This clause requires product be released by a relevant authority with traceability to the person authorizing the release. In this case, let’s say, an inspector releasing product to the customer. A review of ISO 9001 finds that there are 21 required records each containing specific requirements.
howste
Thaumaturge
I have to disagree. 7.5.2 is about creating and updating documented information, which by definition (ISO 9000:2015 3.8.6 Note 2) includes both documentation and records. The standard does not have to use the word "retain" for it to refer to a record, but in general it does. The requirements in a, b, and c must be applied to both documents and records when "appropriate" as pointed out by Pancho above.
Here's my take on this clause applying to records:
"Identification and description" helps us to index, access, and find records.
"Format and media" ensures the records are created and stored appropriately instead of on sticky notes, cocktail napkins, or on the back of the operators hand.
"Review and approval for suitability and adequacy" should be done for every record (in my opinion) at a minimum by the creator so that we know the record is readable and has the correct information in it. Other approvers may also be added if the organization believes it would add value.
BoardGuy
I would disagree based on your reference to your reference “a, b, and c”. When a record (retained document information) is completed the reviewer would not verify that the title, issue date, author and/or reference number (7.5.2, a) of the record as being suitable and adequate (7.5.2, d). Additional when the record was completed its format for recording information would not need suitability approval at each completion (7.5.2 b & c).
When I performed a line by line review of ISO 9001:2015, Clause 7.5.2 and found this clause to correlate to the control of document Clause 4.2.3 of ISO 9001:2008 as follows:
7.5.2, 1st Sentence: Formally 4.2.3.b
7.5.2.a: Formally 4.2.3.g
7.5.2.b: Taken from ISO 9000:2005, 3.7.2, Note 1
7.5.2.c: Formally 4.2.3.a, b, & g
I would say that this clause is indicating that the format and media for recording information as retained document information (record) must address these requirements before document issue (electronic or hard copy). An ongoing review of “a, b, and c” each time the document is used is not required.
howste
Thaumaturge
I'm not sure what part of my post you're disagreeing with. I'll just reply to each part of your post to clarify what I mean.
A person filling out a form should verify that they used the right form and the correct version of the form. If no form exists, there should be some control in the QMS telling them how they should create and identify the record.
Again, when filling out a form, they should verify that they used the right form. If there's not a form to fill out then there should be another QMS control to tell them what media to use etc.
I agree that those are close equivalent clauses. But because in the old standard they lived in 4.2.3 does not mean that they don't apply to records now. The 2015 standard is a new standard and must be read in its own context. Also "identification" is found in 4.2.4 of the 2008 version.
I agree. These are part of the QMS controls you would have to ensure that the records being created are suitable and adequate.
I agree with this statement too, but it's implying things that I didn't say. :confused: The standard does not say that a, b, and c are reviewed each time a record is created. It requires the organization to ensure that controls to ensure appropriate a, b, and c are in place when the record is created.
C How to to become an ISO 9001:2015 consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Computerized System Validation in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Experience Records - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
