Re: ISO 9001:2015 Clause 7.5 7.5 - Is Review and Approval applicable to Records?
The text you are quoting is about records, but it sounds like you're talking about documents such as work instructions or procedures because you wouldn't need to update records periodically.
To answer your question about periodic review: In my opinion it doesn't really matter if you change the revision number/letter at the time you review or if you keep a record that the review took place. Actually ISO 9001 doesn't even require a record that the review took place. If you do choose to do it though, it's probably more important that whichever method you choose that it's useful and effective for the people your company. I believe either one would be acceptable in an audit.
Dear Howste
Your last paragraph
"Review and approval for suitability and adequacy" should be done for every record (in my opinion) at a minimum by the creator so that we know the record is readable and has the correct information in it. Other approvers may also be added if the organization believes it would add value.
I think it is what we used to do in 2008 version, where we defined a timeframe
to revise documents for adequacy, because sometime they remain the same for a long time, which means are not part of the system improvements.
BTW, at doing this activity , the idea is that document owners revise their documents at time defined (say 2 years from the last change), the evidence in my opinion, could be to change number of revision, even if it was not changed.
I could think in having an email from the owner saying " I have revised the documents xxxx,xxxx,xx ,etc.) and not change the revision on the documents, but is not a good idea.
What do you think in both topics?
Your last paragraph
