ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs
John Broomfield
#11
Thanks for your clarification.
I would apply clause 8.7 to any nonconforming output from the system and to any process within the scope of the system.
Such process, system, service and product nonconformities would be subject to correction and may be worthy of corrective action (removal of root causes)
BTW, errors may not result in nonconformities, that depends on the design of the process being robust enough for errors not to become nonconforming outputs.
tony s
Information Seeker
#12
Is it Mean final products or servcies or the output from each process in system?
Output is defined by ISO 9000:2015 as "result of a process". If we substitute its definition to clause 8.7, then its title will be read as "Control of Nonconforming Results of Processes". To better understand what are nonconforming outputs (8.7), organizations need to know first what are the expected outputs of the processes (4.4.1a). Nonconforming output is the opposite of expected output. See examples below for various processes:
Other than the "results of the processes", clause 8.7 applies also to "outputs of the organization". Refer to 8.7.1 statement i.e. "This shall also apply to nonconforming products and services detected after delivery of products, during or after the provision of services".
John Broomfield
#13
Tony,
The content of the bottom right cell in your table bothers me.
Audit findings are substantiated during the audit and should not be a nonconforming output caused by a tardy audit report.
Late audit reports show contempt for the requirements; thereby undermining quality.
Has anyone taken this apparent mistake up with its authors?
John
tony s
Information Seeker
#14
Since I want to establish that nonconforming output is the opposite of expected output, there are, actually, two opposites in the statement "On-time submission of accurate reports". One is "late" and the other one is "unsubstantiated". Unsubstantiated here means "unsupported" or "without clear basis".
sunrizenew
#15
dear friends
if i got a complaint from the client regarding non conforming outputs detected by the client in this case it will be treated with clause 8.7 or 10.2
John C. Abnet
Teacher, sensei, kennari
#16
dear friends
Good day @sunrizenew ;
It depends. I assume by "client" you are referring to your customer ?
Assuming the customer's complaint is valid (i.e. confirmed that output is indeed nonconforming), then...
8.7 would be the consideration of how to control and/or segregate that output.
- Does the customer's "product" need contained and/or returned to you?
- Does your organization have same or similar "product" still in your facility that needs contained/verified?
- Is there "product" in transit to your customer that is also suspect and needs contained/verified?
8.7 is the governance for any control and segregation of the output (product)
Once any necessary control of actual and/or suspect output/"product" is dealt with, then...
10.2 is corrective action to eliminate root cause required?
- Does the customer require corrective action to eliminate root cause?
- When your organization ' 10.2.1-b "evaluate(s) the need for action to eliminate the cause of the nonconformity...", did your organization determine it IS necessary to eliminate the cause of the nonconformity?
10.2 is the governance of identifying and eliminating root cause IF that is determined to be required.
Hope this helps.
Be well.
tony s
Information Seeker
#17
Deal with the nonconforming output first using 8.7. If your organization believes that the nonconforming output can be prevented from recurring and would want to prevent it, then proceed to 10.2.
Kronos147
#18
If an organization sends a quote that is way way way overpriced due to a typo and you don't get the business, would the boss consider that a non-conforming output?
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
