ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented?
armani
Management review inputs (9.3.2) must be presented for review in a documented way?? Or just verbally is enough (but then how can organization demonstrate that inputs covers a) to f)?
P
PaulJSmith
Re: 9.3.2 must be documented??
In 9.3.3 resides a requirement to "retain documented information as evidence" of your Management reviews. The minutes of the Review, which would include the inputs, amongst other information, would surely satisfy this.
DRAMMAN
Can it really be an effective management review process if nothing is documented?
That aside, how an auditor would verify this is by asking who participated in the Management review. Then ask each participant what was reviewed, the inputs, outputs, etc. If eveyone gives a consistent story then the process is effectively deployed. If everyone starts giving different stories or responds with..."what is management review?" Then you are likely looking at a NC.
My CB Auditor said that a good way to simply meet the requirement is to create a power point with the minimum information and email it the management team. That will allow you to avoid NC's. Is that an effective management review process....probably not.
Chennaiite
Never-say-die
What do you exactly mean by Verbal inputs to Management review? Could you elaborate more? It is beyond my imagination.
On a lighter side (strictly not meant to offend), some of my wild imaginations are,
Lunch-table review; Water-cooler review; Happy-Hours review; En route-to-Airport review;:)
Marc
OK! that's what an external auditor will want. But "show me the shall" for documenting inputs...there is none.
Management Review has long been discussed. I think many people over think this. In the past some people have even interpreted the requirement to be one big meeting once a year (minimum), which is not the case.
In this discussion I do not see an issue. Management reviews have an agenda. It would be difficult to hold the meeting if a documented (written) agenda was not made and communicated to prepare people for the meeting and to guide the meeting. That agenda should list all inputs. If other inputs do come up they should be entered into the (documented) meeting minutes. Remember: Management Review Outputs are Inputs to the NEXT Management Review meeting.
As to "... show me the shall ..." - In general I would go along with that line of thought if an auditor asks for something there is no specific "shall" for. But, in this case it is the basics of having such a meeting that really require a documented agenda.
For some thought on this, read through: What should be included in Management Review Meeting for ISO 9001:2015?
That said, even though there may not be a specific "shall", I certainly would have a documented agenda and if the auditor asked for it I would happily provide it.
I think the old saying goes: "Choose your battles carefully". I wouldn't get into a pi$$ing match with an auditor over this.
Since we're on the topic, you might also want to read: Management Review Input/Outputs - Most Items Discussed in Other Meetings
I did do a Goggle search on "effective meetings" and all essentially were like this one: https://www.thebalance.com/effective-meetings-produce-results-before-the-meeting-1918729 - Every one says (and I fully agree) that a written agenda in necessary for an effective meeting.
As a last thought, a documented agenda, as well as meeting minutes and documented outputs may be important in the future such as if a legal issue arises, and in general the outputs of management review meetings are important to Continuous Improvement.
:2cents:
armani
Thanks Marc for these helpful sources of information.
Unfortunately, there is no satisfactory answer to my question - no doubt, it is more effective if documented inputs are used, but there is no such requirement.
So, for an external / internal (?) audit this may be an OFI but definitely not a NC.
P
PaulJSmith
No offense, armani, but if you're doing this to meet the strictest requirements of the ISO standard, then you are really missing the point of a Management Review. It's not about meeting the "shall"s of the standard. It's about meeting the expectations of a successful organization. It's the most effective method, whether the standard requires it or not.
Marc's post is dead-on.
DRAMMAN
ISO9001:2015 explicitly requires there be inputs. Section 9.3.2 is titled "Management Review Inputs". The standard does not specifically state what your inputs must be or how they are documented. It does state....
"The management review shall be planned and carried out taking into consideration:" Then it lists what to take into consideration. The list would be the minimum of what to take into consideration. You can add more input topics.
The frequency needs to be at PLANNED INTERVALS which you define. Annually is a planned interval. But my opinion is that more frequent management reviews is more effective.
Your documentation requirement for the Management review is as follows
"The organization shall retain documented information as evidence of the results of the management reviews".
So no, you do not need to document the inputs. My opinion is your Management Review process will be more effective if you document the planned intervals, the required inputs, the outputs, and the results. And your audits will surely go smoother.
Agendas, meeting schedules, management review procedures, power point presentations, reports, metrics, and action item trackers are all types of "documented information" that can be used to as objective evidence to prove you do Management Review. More than likely, we all work at companies who already have some of this, if not much more.
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
