ISO 9001:2015 Internal Auditing
HI,
Can someone help me with a sample of an internal audit checklist for ISO 9001:2015?
Does it necessarily include all clauses?
I would greatly appreciate the help.
Johnny Quality
NASHII,
I would find it unhelpful to do an internal audit based on the standard clause by clause, that's more like a Gap Analysis.
If you have an established system it would be more effective to ask questions to verify the processes are effective, efficient and working as documented. I would start with a process flow of the process, follow it and ask questions from that.
Mike S.
Happy to be Alive
I use an internal audit form that includes some basic questions that apply to every process (i.e. are the people performing the process competent) but the bulk of the "checklist" used is created by the auditor directly from the procedures and work instructions associated with the process.
For example, if the governing procedure says "the Operator shall perform a first-piece inspection on the first part manufactured during every shift" I highlight that "shall" and during the audit I verify that it's being done. The procedure becomes an audit checklist.
Thank you guys.
We do not have a system implemented. We are trying to implement the QMS and therefore, I am trying to work out what specific questions I can use for the internal audit.
Randy
Yes. My bad. We do not have a documented (accredited) system as yet.
You won't have an accredited system, but you can have a registered or certified system.
Now, other than a Gap Analysis checklist that only helps to determine what you have of have not got in place...and that's actually working, no internal audits are ever the same between different organizations, mine will not and can not be the same as yours............And why not? Because what you do and how you do it is different than what I do........
You're asking for something that does not, nor can not exist.
Once you've done a basic Gap, and corrected your lack of meeting all the basic shall's, then you have to audit what you really do and it's really quite simple........Grab a procedure, work instruction, SOP or whatever buzzword you use for documentation and prove that you really do it the way you say you will........
Now if you don't have stuff documented, then ask someone who's actually responsible and hopefully knowledgeable "who, what, where, when, how, and why" about what's supposed to be happening ........ and then verify that it's all happening.
John Broomfield
Now that you recognize that your organization already works as a system to sustain itself by creating and satisfying paying customers (sometimes disguised as a mission statement) you may develop that system so everyone knows how it works and can see what needs to be improved.
Even though you may use your auditing skillls to do this I wouldn’t call it an audit or even a gap analysis.
Better to engage top management in determining the processes that are essential to their system for understanding customer needs, translating those needs into requirements, fulfilling the requirements and obtaining prompt payment to invest in improvement. Those processes that comprise the value stream are supported and directed by other processes in the system such as strategic planning, maintaining facilities and equipment, recruiting, training, purchasing, auditing and investing in improvement.
Ask top management to assign each process to the person best qualified to be its “owner”. With each process owner seek to understand how the inputs of data, information and materials are known to be valid, how value is added and that the results can be relied upon. You could record such facts in deployment flowcharts which could become the documented procedures where none already exist. Capture the “as-is”, and have the process owners arrange reviews for accuracy.
Then you can use your knowledge of the system standard to initiate discussion about the benefits of corrective action as and if required.
So, as you can see, developing the system you’re already part of is preferable to you suggesting that you are trying to impose something new “from ISO” via an audit.
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
