ISO 9001:2015 Is a Project Evaluation form necessary?
Jansen L
Upon completion of a project or service (Design and Development of Products and Services (8.3), our company requires a project evaluation form to be completed by the account director. This form asks generic questions, including: 1) lessons learned and 2) opportunities for improvement and 3) what method will be used to obtain customer feedback. Our company uses a customer satisfaction survey to collect feedback from our clients. To me, it seems like this project evaluation form is outdated and probably a relic of a past ISO 9001 revision. Does this form have any intrinsic value or fulfill any of the 8.3 requirements?
John C. Abnet
Teacher, sensei, kennari
The results that are captured on your form are a record. The question then is really for your internal organization?
Where are these records stored? If digitally, can you see who/when in regard to the last time these records were accessed? Have you asked those who WOULD likely use these records if/when they have ever looked at them? Better yet, have you asked those who WOULD likely use these records if they know where/how they would access these records? (you may find that no one beyond the originator even knows where these records are stored ;) )
Food for thought.
Hope this helps.
Be well.
Jansen L
Food for thought.
Hope this helps.
Be well.
Yes, I understand that these would be records. Upon completion of these forms, they are filed digitally in cloud-based storage. They are accessible, but I can guarantee they are not looked at after the initial population of the forms. IMHO, it seems that the questions are ambiguous, and may need more specificity ( e.g. did the company stay within budget, did the project have sufficient human resources, etc.). I forgot to add that one of the questions is if the company "exceeded customer expectations?" It's difficult to self-evaluate and come to a non-bias answer, so why not leave this kind of a question out and let the customer answer this.
My original question was more or less if anyone else uses a similar kind of form to capture information at the completion of a service/product/project?
John C. Abnet
Thanks for the feedback.
I would simply council that instead of trying to "make" the form work (i.e. adding specificity), simply consider your original question...
i.e. 'does this form add any...value"
To the second part of your question...."does this form...fulfill any of the 8.3 requirements? "
Obviously ISO 9001:2015 clause 8.3 has some specific "shall" requirements. I can only wonder if the form you are referring to was simply created by someone to help "check the box" that these requirements (or others) have been addressed...
*'verification/validation activities
* Information derived from previous...
* Reviews are conducted
* ...involvement of customer..
...but possibly not in a way that actually benefits your organization and/or your customer.
Yes, ISO 9001 registered organizations need to conform with the requirements of the standard. I would council, however, that organizations should be extremely selfish to ensure ALL is done for benefit the organization and its customers (simply ensuring that it meets the requirements of the standard in the process).
Hope this helps.
Be well.
Tagin
I don't see the form as being applicable to any 8.3 requirements. Instead, it is post-activity feedback which most aptly would be used for 9.1.3 Analysis and evaluation, 9.3.2 Mgmt Review inputs, 10.3 Continual improvement.
It is also relevant to 7.1.6 Organizational knowledge. Specifically, see NOTE 2a of 7.1.6:
NOTE 2 Organizational knowledge can be based on: a) internal sources (e.g. intellectual property; knowledge gained from experience; lessons learned from failures and successful projects; capturing and sharing undocumented knowledge and experience; the results of improvements in processes, products and services);
If the form is being filled out and simply filed away, with no one ever analyzing or acting upon them, then it would be pointless to fill out the form. But before scrapping the form, it would seem a better idea to examine the potential value to the company and to 9.1.3/9.3.2/10.3/7.1.6 of that information.
Big Jim
The form in question is not a requirement of the standard. Depending on how the information is used, it could be a best practice to use it though.
Like someone else asked, is it adding value to your organization? If not, determine if it is desirable or not. If it is desirable, figure out how to get it to be appreciated. If not desirable, drop it.
C How to to become an ISO 9001:2015 consultant ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Computerized System Validation in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Experience Records - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Integrating ISO 9001:2015 audits with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 9001: 2015 MR Outputs - "any need for changes to the quality management system' Management Review Meetings and related Processes 13
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
G ISO 9001-2015 How to co-relate Clause 4.2 & Clause 6.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
B ISO 9001:2015 vs ISO 13485:2016 Gap analysis ISO 13485:2016 - Medical Device Quality Management Systems 9
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
