ISO 9001:2015 - Record requirements for out of calibration tool
Sidney Vianna
Post Responsibly
#21
You are correct that the OP did not explicitly mention there is a torque spec for the assembly process, but that was the only plausible explanation for the scenario, since it costs money to send a torque tool to an outside cal lab and the OP already mentioned that they are cost conscious and have revised other similar manufacturing instructions to get rid of torque specs.
If there was no torque spec requirement, the corrective action to the original NC would have been to drop the torque adjustable tool from the assembly process.
Johnnymo62
Haste Makes Waste
#22
Consistency and screws not falling out are requirements Embedded mentioned. I would think there should be a torque requirement. Threads can strip from over-torque or cross threading. They may look properly seated but come loose and fall out later.
:2cents:
Big Jim
#23
You have made two bad assumptions. First ". . . that was the only plausible explanation . . . ". Not even the smartest of those on this planet can possibly know all plausible explanations. That's why auditors need to ask questions.
Second there could be a variety of reasons to continue to use a calibratable torque tool. It may be that it is what they had and didn't want to buy another tool. This could be particularly true for an electric powered screwdriver, which would make assembly faster. The fact that it was sent out for calibration by habit is not conclusive evidence that using a calibrated torque screw driver was required.
It is my belief that there was not enough evidence provided to write a nonconformance. True, after digging deeper (asking more questions) it may turn out to be a nonconformance, but jumping to conclusions and writing bad nonconformances is a very bad reflection on the entire ISO 9001 scheme.
As one who helps others with understanding what ISO 9001 really means, you especially need to stay on guard to not do that.
Big Jim
#24
:2cents:
Indeed, torque specs become meaningless when cross threaded. Also if the screw is too long so it is bottoming out.
Sidney Vianna
Post Responsibly
#25
You might not be aware, but we are NOT in an audit here. We are in a forum trying to help people who come with questions. You might not be following the situation here. The OP wanted to make sure there is no chance of a repeat NC for lack of records when devices are found to be out of tolerance, upon verification of the as-received condition in a calibration lab. So, his query is about a requirement for a record to exist, to what I have already provided my answer.
Big Jim
#26
I am aware. I read the whole thread before responding. Not being in an audit is no excuse for inaccurate information though. Would you like to leave it there or should I get into your comment about the corrective action which is misleading?
Sidney Vianna
Post Responsibly
#27
Please, by all means, we are here to learn. What inaccurate information am I spreading? I definitely don't want to do that, as my personal goal here at this space is to provide accurate and relevant information. If I am not doing that, I want to be the first one to know.
Thanks.
Big Jim
#28
Would you agree on the definitions of correction and corrective action as defined in ISO 9000:2015?
correction - action taken to eliminate a nonconformity
corrective action - action taken to eliminate the cause of a nonconformity and to prevent recurrence
If you do then what you suggested would only be the correction and not the corrective action. At this point little has been said about cause even if there is concurrence that a nonconformity exists. Corrective action has to speak to the cause of the nonconformance.
Perhaps what you meant was that removing the requirement to use a calibrated torque screwdriver would be the beginning of a thorough corrective action.
Poorly written nonconformance responses are rampant in the ISO 9001 world, and it would help to not contribute to the confusion, accidntly or not.
If you don't agree with those definitions, please fill us in.
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
