ISO 9001:2015 - Scope of Registration
I was just audited (Transition) to the new ISO 9001:2015 standard and the auditor stated that within the "scope of registration", which appears on our certificate, we needed to add Delivery. It was stated its because delivery is a service we provide (4.3(c)). Should delivery appear in our scope....I don't recall seeing any scopes of registrations with delivery included.
We were given a minor for this issue.
ScottK
Not out of the crisis
I have never seen a nonconformance for a scope of registration issue.
I've seen recommendations, but in my experience it's not for the auditor to approve your scope... it's up to a different part of the registrar to do that.
I would push back on that being written as an NC.
Does your company actually physically deliver the product a paid service? I mean, I've been with companies that have manufactured products and had a truck (usually used to transport to outside processors and other sites) to run parts to customers as needed, but that was a complimentary and occasional service and we did not include it in the scope of our QMS.
As has been stated, this is non-sense and is NOT the auditor's job to hold you accountable for something which the CB should have sorted out. I'd be complaining to the CB about this, so they know it needs to be stopped!
Sidney Vianna
Post Responsibly
Re: ISO 9001:2015, Scope of Registration
It is the lead auditor’s responsibility to ensure the scope of the audit is adequately determined and the scope of the audit is affected by the scope of certification and the scope of the quality system.
The standard requires the scope of the system to be documented. If the auditor uncovered a problem there, s/he needs to bring it up.
Remember the context of the organization might change over time, so this is an issue that should be addressed in each and every surveillance audit, as this is a requirement of 17021.
But, even if the company provides delivery services as a stand-alone service line, it does not have to be in the scope of certification, if the organization chooses that.
John Broomfield
Stevey,
Your auditor has his or her wires crossed. Defining the scope of the certification is the Registrar’s job not yours.
So, your Registrar may need to take some corrective action.
Does the scope of your management system include delivery of your service? If so who designs your service and is this covered by your management system?
John
Le Chiffre
:applause:
Did the auditor catch that delivery was being offered as a service under the 9001 certification claim, in advertising perhaps?
Like the previous exclusions permitted by the organization, according to A.5 (of 9001:2015), "an organization can decide that a requirement cannot be applied to any of the processes within the scope of its quality management system". However "Cannot be" suggests that the exclusion is permitted if the activity is not relevant. In this case it sounds like it is undertaken therefore cannot be excluded.
The next sentence in A.5 defies (my) logic! "The organization can only decide that a requirement is not applicable if its decision will not result in failure to achieve conformity of products and services."
Kronos147
Stevey,
John
I disagree.
You may want to check ISO 9001:2015 4.3 Determining the Scope of the Quality Management System again.
I've changed a ton of "scopes" within the reports I have to file (mostly to better define/clarify them and all subject to review), but I sure didn't write a NC to any clients....That's total BS and pretty lame
Thanks!
John Broomfield
I disagree.
Thanks!
Kronos,
Sure, the auditee is responsible for defining the scope of their management system.
But here we are referring to the scope of the registrar’s certification of this system.
Best wishes,
John
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
M Does the ISO 9001:2015 standard require a disaster recovery plan or emergency response plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
F Logistics and IT clauses in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
V Quality Objectives - ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
Gun46 ISO 9001 : 2015 Lead Auditor Exam General Auditing Discussions 16
Q ISO 9001:2015 man days for surveillance audit ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
I ISO 9001:2015 Section 9.3.2 C1 "customer satisfaction and feedback from relevant interested parties" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
I ISO-9001:2015 and "Relevant Parties" Management Review Meetings and related Processes 2
M ISO 9001:2015 8.2.1 Contingency Plan required for small Business? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Help with Drawing Review - ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
V ISO 9001:2015 7.2 Competence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
B ISO 9001:2015 Transition: Much Easier Than You Think! Misc. Quality Assurance and Business Systems Related Topics 0
A Process Documentation for ISO 9001:2015 Internal Auditing 2
C Migrate ISO 9001:2015 Certificate Registrars and Notified Bodies 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
E Three basic questions about ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Management Review Input Template wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
N ISO 9001:2015 Customer Complaints Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
O Performance Measurement ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Does ISO 9001-2015 have a requirement for manufacturing equipment to be numbered? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
V ISO 9001: 2015 Production drawing Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S ISO 9001:2015 & ISO 14001 Re-Certification Audit Preparation ISO 14001:2015 Specific Discussions 8
S ISO 9001:2015 & ISO 14001:2015 - I need a format for Design & Development planning ISO 14001:2015 Specific Discussions 2
N ISO 9001:2015 - 5.3 - The roles and responsibilities matrix rears it's head ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 Excel Gap Analysis wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
