OP, if your auditor wrote this up against ISO9001:2015 section 4.3, and addresses it against the “scope of certification” I believe the auditor to be totally wrong. 4.3 requires “[FONT="]The scope of the organization’s quality management system shall be available and be maintained as documented information”.[/FONT] It also states that the scope shall “provide justification for any requirement of this International Standard that the organization determines is not applicable to the scope of its quality management system. The scope on the certificate is normally (for most registrars) 15 words or less. You could exhaust your 15 word limit just explaining what you don’t do!
A company’s context documentation is usually where you will find the documented scope required by 4.3 to be “maintained”. The “scope statement” is not “maintained” by the company, it is “maintained” by the registrar (after all, the company does not issue the cert).
ISO 17021-1 section 5.1.3 “The certification body shall be responsible for, and shall retain authority for, its decisions relating to certification, including the granting, refusing, maintaining of certification, expanding or reducing the scope of certification, renewing, suspending or restoring following suspension, or withdrawing of certification.”
