ISO 9001 4.4.1 "...shall determine the processes needed..."
John C. Abnet
Teacher, sensei, kennari
#11
Good morning @Big Jim Thanks for the feedback. I am in agreement with you. However, my "dive" into this is more academic than application. While I don't disagree with your statement, I still do not see any requirement beyond what the organization determines. There is no need (as we know) to document the processes,...simply "determine" the processes. (Again, in order to benefit the organization by visualizing the organization strategy and to provide evidence of the act of "determine the processes", I recommend a simple process flow map....BUT there is no requirement to do so).
I would argue that this (in reality) occurs organically. If I own a pizza shop, I'm going to have processes beyond the examples I listed, in order to simply function. If we take the "shall determine" in context, ...it follows the opening statements "...establish, maintain, improve, a quality management system, including the processes needed...." My point in all of this is that IF an organization has the processes needed and functioning ....then they (assuming they are compliant to the balance of the 9001 standard [again, seems nearly impossible to be compliant or operate a functioning organization without the "processes needed"] ), ....then there is no nonconformance, regardless of WHICH processes they specifically "write down". Demonstration of the effectiveness of the QMS, including (not sure how you could separate it), the processes needed- is all that is needed.
What I am digging for is an actual refute of this position based objectively on the verbiage within the standard.
Thanks to all for humoring me in this. There is a reason behind my madness (in this case ;)
Be well.
John C. Abnet
#12
I appreciate the video you provided @Big Jim . It is well done and can be very helpful. However, it is taking liberties beyond the requirements of the standard (remember, I am in agreement with what the video proposes to be done....no argument there. HOWEVER, just because I council organizations to do it for specific benefits, there is NOT a requirement in the standard).
Here is a portion from the video, which is inconsistent with requirements of the standard.
Be well.
John Broomfield
#13
If the business is running and reasonably successful, indeed, the processes tend already to exist.
Auditing the system and its processes for effectiveness may not be impartial and objective, however.
But the work of investing in continual improvement, maintaining facilities and equipment and recruiting and training for competence probably will be up and running unless the business has a death wish.
Dare I say risk-based thinking is alive and well but less as a process and more as a work environment touching all critical processes.
Trouble is many “implementers of the standard” are deceived by that command to establish a quality management system and fail to appreciate what they already have.
John Broomfield
#14
I found the video as part of PJR’s corrective action for a 14-year old nonconformity very interesting.
It says their auditors are now trained to ensure their clients “identify processes in an appropriate manner” or they’ll receive a nonconformity report.
Big Jim
#16
14 year old NCR?
ANAB wrote an NCR against PJR during a reaccreditation audit in 2014. Some PJR auditors were not auditing to the auditee's IOP, mainly because they were not written well so to perform a thorough audit the auditors tried to guess what they were.
It is evident that the writers of the standard never intended for the IOP to be used to create an an audit plan. Telling ANAB to show them the shall in ISO 9001 didn't get anywhere.
This is another case of where the writers of the standard in their ivory tower don't know what is going on in the trenches and evidently don't care.
I posted the link to the webinar for those who were seeking guidance for what the CBs are looking for and why so an IOP developed with this in mind can help set up for more effective auditing, both internal and CB.
I find it interesting that the prior widely accepted approach of flow charting led to the confusing IOPs that didn't do much to define the core processes.
If you found the link helpful, great. If you didn't, so be it.
Big Jim
#18
But they didn't explain it very well. Until they come up with a better definition of what they mean by "process" this confusion will still exist. What they mean by process in 4.4 must be very different than how it is used in 8.5.1f. But they only have one definition and that definition is so broad that a universe could be fit into it. TC-176 doesn't get a pass on their reckless use of the term. They own it and all the confusion it seeds.
Tagin
#20
TS9002/2016 4.4.1b seems to support this:
when determining the sequence and interaction of these processes, the links with the inputs and outputs of the previous and subsequent processes should be considered; the methods for providing details of the sequence and interaction of the processes depends on the nature of the organization; different methods can be used, such as retaining or maintaining documented information (e.g. process maps or flow diagrams), or a more simple approach, such as a verbal explanation of the sequence and interaction of the processes
J Safety Special Equipment (e.g. lift, boiler) shall be audited by ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
GStough REACH and ISO 9001:2000/13485:2003 - Never the Twain Shall Meet? RoHS, REACH, ELV, IMDS and Restricted Substances 4
Gman2 ISO 9001:2000 Internal Audit: Someone PLEASE find me the "Shall" on "Process Audits" Process Audits and Layered Process Audits 37
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
