ISO 9001 8.4.1 - Determining controls applied to externally provided processes
jacoblh
My company uses our supplier's datasheet to verify part dimensions. The supplier does not notify us when dimensions change so we only find out when we have an issue. At that point the paperwork gets updated and the old rev is discarded.
Some parts, however, are catalog so I have transferred these dimensions to a database that I keep updated and rev controlled.
If we check for new datasheets once a year, does this step in our procedures conform to the standard.
I guess my fear is that because we do not check often for changes in datasheet so technically we could be checking against the WRONG one (not most updated). For example, if a dimensions is changed that is not critical so we do not notice that we are not checking against he most updated revision.
Jacob
qualprod
Jacob
What kind of suppliers you are dealing with ?
In a relationship client -suppliers, the agreements and support is essential, if that supplier doesn't help you, change it .
Don't you perform supplier evaluation?
When is done, here is when you detect the suppliers problems and take actions to correct the problems.
Hope this helps
jacoblh
Hope this helps
I agree however I am not in a position to make that change. I appreciate your thoughts.
Randy
Wait! A supplier provides to your criteria, you don't bow or bend to their criteria.
Who's in control, you (the people with the check) or the supplier (the person that want's the check)?
Emmyd
What is your supplier contracted to provide you? If your PO specifies that part 123 should conform to dimensions x, y, z and you get part 123 that conforms with c, y, z - that should not be acceptable. I would see what your supplier contractually is supposed to be supplying and push back from there as applicable (if they aren't fulfilling . If this causes problems in your process or downstream at your customer, changing dimensions without notice is a deal breaker. Even if you aren't in a position to make any changes to the supplier relationship, I would still document the issue.
jacoblh
We purchase part 123 with the requirements being that the part matches the specifications listed. The issue is that we cannot reasonably check for the most updated datasheet each time. I hope that my inquiry makes sense. I do understand that this is a bit strange as the phrase "My supplier doesn't update me when specifications are changed" is odd. It is the nature. We are a small business and they are the sole-supplier for most of our business.
Jacob
jacoblh
We buy the parts. Our verification of supplied product includes a physical dimension check. We are as careful as possible but I worry about what an auditor may think.
John Broomfield
Failure to establish effective contractual controls over your suppliers.
By now you should have issued this Corrective Action Request to the person responsible for purchasing so he or she can get a cross-functional team together to determine and remove the root causes of this nonconformity.
Randy
OK, here's the deal, do you specify what it is that you want? Yes or No.....If no, shame on you
Are you getting what you specify? Yes or No .... If no shame on them and next question
If you get the wrong stuff are you telling your supplier it's WRONG? Yes or no....If no, shame on you
Does anybody with the authority to fix the problem really care to fix it? Yes or no.....If no, it's not your problem it's their's (remember you said you don't have the authority, so it's not your deely)
One question I have is "Why don't you check the datasheets?"
Another question is...:Why is this your problem?" If you don't have the authority to make changes, then make strong suggestions, document it and move on to something you do have authority to do....
Oh yeah, I'm an auditor, that's all I do, nothing else but audit, no consulting, no teaching, no selling the best gee-whiz bang quality thingy, nothing but audit and I'd have a ton of real world questions if I encountered what you've described, some already placed here by our friends.
Q ISO 9001, section 4.3 Determining the scope of our QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
F ISO 9001:2015 4.3 - Determining the scope of the quality management system ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
P ISO 9001 - Determining Core Processes - Recommendation of Online Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Determining the Scope of ISO 9001:2000 Registration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
G Determining Internal Audit Frequency - ISO 9001 Clause 8.2.2.4 Internal Auditing 15
D Determining Necessary Competence for Personnel - ISO 9001 Paragraph 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E Determining and Defining Measurable Objectives in ISO 9001:2000 Clause 5 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 80
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Auditing Quality and Environmental Management Systems 15
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 10
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
