ISO 9001 and ISO 13485 GDP (Good Documentation Practices) Findings
mdurivage
I occasionally run across companies with poor documentation practices i.e. using correction fluid, pencil, scribbles, date changes, etc. I know there is not a specific site (ISO/CFR). What is the best way to write these practices up as a finding in an audit report and what do you use as a citation?
p.s. I did run a search here on the Cove and the internet and did not really find a solid answer!
somashekar
If it is leading to anything not legible in documents / records, then it is a sure NC.
" There is evidence to state that documents / records are not legible as seen in the following examples " .... (cite examples)
To err is human, but to hide the error is more a sin.
The procedures for documents and records can address this effectively.
Errors when noticed can be deleted with a strike through and re-written legible at the place and signed off at the nearest place.
Doug Tropf
With regards to ISO 13485, the guidance document (ISO 14969), offers some specifics in sections 4.2.4.4 and 4.2.4.5.
treesei
Besides whatever specified in the standards, you may cite them against the company's GDP procedure. If there is one, most likely the poor practices have violated the procedure.
... and if there's not a discussion of GDP as part of the Control of Records (or standalone) SOP, and any handwritten records are being maintained as part of the QMS, is that a large enough failure versus ISO13485 4.2.4 to warrant a major NC? I bet you :2cents: that some of our medical OEM Customers would say so! :whip:
:bigwave:
Rolling out Good Documentation Practices at our site and lots of good questions.
One that has come up is regarding the comment section on a form.
If there are no comments, is it acceptable to leave it blank?
Our GDP SOP says that blank fields should be marked "N/A" with initial/date...
but does this count?
somashekar
:bigwave:
A lot has got to do with the design of the form itself.
A comment section on a form must have 'comments' or '-- NIL --'
The N/A (Not Applicable) as I understand is always a grey area.
I would even suggest you look into your GDP SOP with more insight.
Never let a field go blank.
GStough
:bigwave:
If your GDP SOP instructs you to mark blank fields with "N/A" with initial/date, why would you not want to follow it? IMO, to blatantly not follow the SOP, well, that is just low-hanging fruit for a zealous auditor, who will likely write an NC.
However, there are ways to modify a form so that blank fields are acceptable. For example, a question such as, "Additional information and/or comments? Y/N" and a checkbox with the correct option checked would be reasonable.
Q
qualityphil
I have a similar question - Can you intentionally leave a comments section blank? I was always told that a comment section should be left blank and not marked N/A in the event of an NC or Recall, the form could be updated? is this accurate?
I Does BSI require suppliers to be ISO 9001 Certified? EU Medical Device Regulations 12
Ron Rompen ISO 9001 Sanctioned Interpretations and FAQs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
K Need Help With Auditing Suppliers Against ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 50
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 5
L Change Log in (controlled) Forms? (ISO 9001:2015) Document Control Systems, Procedures, Forms and Templates 6
K ISO 9001 Clause 8.3 & 8.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Transition training for Internal Auditor from ISO 9001: 2008 to the ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
H R&D Lab ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Clause 8.5.1 Control of Production and service provision - Help with Work Instruction Access ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
Q ISO 9001-2015 Internal audit finding Internal Auditing 14
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
