ISO 9001 and ISO 17025 - Measuring tools not in calibration system
greif
We have several calipers which are not in the calibrations system, used for rough measurements. Is this likely to cause a problem during an ISO 9001 or iSO 17025 audit?
normzone
What prevents those calipers from being carried to another location and being used for "less rough" measurements?
Calibration is the easiest thing for a lazy auditor to write a nonconformance against.
dwperron
If you want to continue to use the uncalibrated calipers be sure they are clearly marked as not calibrated. Make sure your work instructions clearly state that only calibrated tools can be used on acceptance measurements (or whatever terminology your organization uses).
In the 17025 world it is accepted that not everything is calibrated to 17025 - just the items used for 17025 measurements.
ISO 9001 is similar:
When measurement traceability is a requirement, or is considered by the organization to be an essential
part of providing confidence in the validity of measurement results, measuring equipment shall be:
a) calibrated or verified
ISO 9001 or 17025 expect you to know when traceability is required in your processes, and then to use the correct tools.
Michael_M
My statement below is for the ISO 9001 side, I don't know anything about ISO 17025 requirements.
Are the calipers used (in any way) as product acceptance? As an example, we have machinist scales used for material 'stick-out' (how far material is sticking out of a lathe on the first part). This has nothing to do with product acceptance as the machine is going to set and cut everything after automatically. These don't need to be calibrated. However, if the scale was used to 'measure' the length of a part coming off a saw then that would most likely be product acceptance since it is measuring a part. Calipers would fall under the same requirement, are they used for product acceptance at any point, calibrate.
M Does the scope of ISO 9001:2015 applies to tenders, pricing and sales department of a medical devices distributor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Can an ISO 9001 Certificate have Remote Locations? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D ISO 9001 - 8.4.1 Evaluate All Suppliers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 66
Sidney Vianna ISO 9001 News ISO 9001 Quality Check - spinning facts in LinkedIn ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A ISO 9001 Internal Audits - No production right now due to furloughs Internal Auditing 5
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Process Audits and Layered Process Audits 15
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 11
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
Q Process matrix examples of ISO 9001 & 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
