ISO 9001 and the HR Function - Developing a Total Quality Management System for HR
N
Navillus
I’m delighted to find this forum and appreciate all the hard work that goes into creating and maintaining a site like this.
I work for a large global organization that wants to develop a total quality management system for the HR function using ISO 9000 as a framework. I have no background with ISO but in reviewing the family of standards, it appears to me that ISO 9001:2008 provides the best alignment with what the organization wants to accomplish. Is my thinking on the right track?
I’m looking for general input as well as specific “where to begin” advice. Understanding the standards are intended to be implemented organization wide, how might I find guidance or examples of organizations that applied them to a single functional area? Should I purchase the ISO requirements document? I really don't know where to start.
SteelMaiden
Re: ISO 9001 and the HR Function
You certainly could use the ISO 9001 model for a single functional area, even though most of us see it implemented within an entire organization. If you choose to use this model, I would suggest that you purchase the standard.
Now, as to how to and where to start? There is a search function at the upper right, you'll see it in yellow text. There are several threads that discuss how to go about implementation of the standard. There is also a list of related topics listed at the bottom of the page for each thread. There is also a green box up in the upper left that says "Post Attachments List" you will find a wealth of attachments there that posters have shared throughout the years. Good stuff and examples you can use.
Other than that? I usually recommend that people find and attend an implementation class. I read, reread, and read again, the standards, but after I took my implementation class, things started to make sense. Are there organizations in your area that are registered? You can visit there and perhaps find a mentor or two. And, the most important, don't be afraid to ask questions here. This is a wonderful resource and you'll learn lots here.
Re: ISO 9001 and the HR Function - Developing a Total Quality Management System for H
I would strongly recommend that you buy the standard, although the part that mostly involves HR is not even one page of the standard. Most of what you need is in element 6.2.
In the most basic of terms, it says that people need to be competent. Competency can be from education, training, skills, and experience.
Further it says that the organization (your company) needs to determine the competencies need for people to perform their job. These competencies are often shown of job descriptions, but they can be simply listed by job title.
Then it says the organization needs to show how those competencies were acquired be it from training or from education or experience, so that you can demonstrate that they are competent with records. You also need to show that you have confirmed that any training was effective.
N
Navillus
I apologize for the basic level of my questions but the more I’ve read the more confused I’ve become. I told my boss ISO 9001 appears to provide the specific guidance we could use as a framework for developing a TKMS for the HR function. His response: “no I want to use ISO 9000 as a framework”. I’m not sure what to do with this. ISO 9000 looks to me like a very broad set of guidelines and I don’t know how to use it to shape a quality program for a single functional area. I’m wondering if this is a semantics issue. By using the 9001:2008 guidelines would it still be correct to see we’re using ISO 9000 as a framework?
I’m going to purchase the standard and, as suggested, I’ve been searching this site. There’s lots of good stuff on implementing / certifying for the entire organization but that isn’t helping me frame my thinking about just using the guidelines as a framework. Perhaps no one uses them as principles for developing a TQM for one function of an organization but since it really is a proven framework, it seems worth doing. Any guidance on how to structure my thinking or where to look for more information is appreciated.
SteelMaiden
True, but the rest of the standard applies to all processes, and if you look at it like the HR dept is providing services to the rest of the organization, the entire standard applies.
ISO 9000 is not a standard, it is a guidance document defining vocabulary and the fundamentals of the standard. ISO 9001 is the standard itself.
N
Navillus
Since ISO 9001 is the standard why do companies say they are ISO 9000 certified?
SteelMaiden
:lmao::lmao::lmao:
If they have a clue, they don't.:notme:
Sometimes I think it is just a way of shortening it up, many just say ISO certified, and there are tons of ISO certification schemes.
Peter Fraser
Bear in mind that ISO9001 is not a model for designing a management system, it is a standard for assessing one. One of the criticisms of the way in which previous versions of the standard was used was that many system descriptions were structured around the sections of the standard rather than the way the organisation operates. Even the current version of the standard (which requires you to identify and manage your business processes, ie how you work) does not always achieve that result.
I would suggest that you concentrate on defining how you / your department / the organisation meets its objectives ("how work is done") before you look at the detailed requirements of a standard. It sounds as though your requirement is to define a system which helps you to manage and operate efficiently rather than (just) to comply with an external standard.
ISO9000 does cover the Fundamentals, and ISO9004 goes further than ISO9001 in terms of guidance, but bear in mind that the revision process has started for all 3 standards, and (certainly here in the UK) there are some significant possible improvements being drafted within the CQI. But the review process is so involved that you won't see the next revision for years yet!
N
Navillus
Thanks Peter. There is quite a bit of process improvement taking place in the HR function and their desire is be more strategic about quality. They envision a mission, a set of tactical objectives and a set of competencies that are key long-term (based on the tactical objectives).
While the objective is not compliance with an external standard, the thought is to design or structure the program in a manner that would align with an established measurement standard. Does it make sense to use ISO in this way or are they barking up the wrong tree?
RosieA
Here's another thought.
The ISO standard is about process and contolling processes.
With your HR team, outline the tasks that your department is responsible for and then do an Input-Process-Output analysis to define where your requirements are coming from (input) what you do with that information (process) and where does the work go next? (output)
You can then define the input as your supplier, the work you do, as the process and the output as your customer.
Now you've defined your process. (See ISO 9001 clause 4.1)
Ask: what are the requirements for input? (special format, certain information required, timeliness etc) (see section ISO section 7.4, and think about the input as something you might "purchase", theoretically)
Is my process documented? Do I have goals and objectives to meet? (ISO section 4.3 on documentation applies, as does 5.4 on Planning)
What does the output need to look like? Are there requirements for that? Is the receiver of the output satisfied? (5.2 Customer Focus applies)
ISO is pretty much in manufacturing language. It takes a little effort to transform it to fit a non-product related function, but it can be done.
Hope that helps get your creative juices going.
L ISO 9001, 14001, 45001 Audit Questions for a Security & Corporate Affairs Department ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
giavannatabbs ISO 9001:2015 Control of Records - QMS Communications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
H ISO 9001:2015 - 8.5.1 - Routers not being signed Manufacturing and Related Processes 9
Q Documented information ISO 9001:14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Is there a mandatory requirement to notify customers of the complaint resolution in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J ISO 9001:2015 Document Revison History ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q KPI rules for ISO 9001 first certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
Sidney Vianna Tesla Lacks Major Automotive Quality Certifications such as IATF 16949 and ISO 9001 IATF 16949 - Automotive Quality Systems Standard 15
Cats Clause ISO 9001 - verification of Tape Measures and Steel rules ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
S ISO 9001 Quality Management System and its processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Preservation of Raw Materials in ISO 9001:2015 Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Assignment on the link between Quality Gurus & ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
jeancloude17 Advice for ISO 9001 for software Design and Development of Products and Processes 2
Ed Panek ISO 9001 Cert Scope Adjustment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
P ISO 9001: Quality Management as a process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
J Iso 9001 Clause 7.1 - Advice needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
K Applicable ISO 9001 clauses for Human Resources? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D ISO 9001:2015 Internal Audit Check Sheet ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A ISO 9001- any advise please with transitioning from a paper based system to eQMS and multi site scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I QMS and ISO 9001 Misc. Quality Assurance and Business Systems Related Topics 11
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J ISO 9001:2015 Clause 8.2.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B ISO 9001:2015 Registered Companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
JDJohnson Micrometer & Caliper Calibration (ISO-9001) General Measurement Device and Calibration Topics 26
G Why do you guys think ISO 9001 doesn't ask specifically for preventive maintenance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
D ISO 9001:2015 Calibration Procedures Manufacturing and Related Processes 16
G Auditing Top management: 6.3 ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
G IT being audited during ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Moncia Customer satisfaction monitoring - ISO 9001 and 14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
Sidney Vianna ISO 9001 News ISO 9001 Design Specification to be developed - May 2022 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S ISO 9001:2015 Project Plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Common items : which iso 9001 are common to all areas? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G ISO 9001 - when implementing customer requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
V ISO 9001 or ISO 17065 required for an organization issuing 5 star rating certification of digital experience? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P How to keep a ISO 9001:2015 certification when a company is sold ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D ISO 9001:2015 Recertification Audit Timing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J ISO 9001:2015 Is a Project Evaluation form necessary? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
malasuerte Performance of ISO 9001 certified vs. non-certified manufacturing companies ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Filling totes and pails - when is a calibrated scale / flowmeter required in ISO 9001 General Measurement Device and Calibration Topics 4
Moncia ISO 9001 calibration question please ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001 Clause advice Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Sidney Vianna ISO 9001 News ISO/TC 176/SC 2 Listing of Approved Interpretations against ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Management Review ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
J Process capability analysis in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Use an iso 9001/2015 form for api q1 systeme Oil and Gas Industry Standards and Regulations 5
Q Which Kapt standard assignment ISO 9001:2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Quality Awareness 7.3 ISO 9001-2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Cats Clause ISO 9001:2015 7.1.5 Monitoring and measuring resources: Application to training providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Quality Management-ISO 9001:2015 General Auditing Discussions 1
E Sources of every single paragraph of the ISO 9001 standards? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
