ISO 9001 Calibration Requirements
Tyler C
I am new to the cove, so please forgive me if this has already been asked.
I am working on getting everything ready for our Stage 1 audit, and I have a question on calibration.
We have several pieces of equipment that are under service contracts. We don't do any calibration to them, other than the daily maintenance which is captured on the maintenance logs.
Should these pieces of equipment be listed on the calibration log?
Thanks in advance for any answers.
Tyler C
Re: ISO 9001:2008 Calibration Requirements
Excellent response, thank you. When you put it that way, I'm not sure how I hadn't thought of that.
howste
Thaumaturge
ISO 9001:2008 clause 7.6 said:
Where necessary to ensure valid results, measuring equipment shall
a) be calibrated or verified, or both, at specified intervals, or prior to use, against measurement standards traceable to international or national measurement standards...
Are they necessary to ensure valid results? If so, you are responsible to ensure that they are calibrated/verified. You don't have to do it yourself, but it needs to be done.
ISO 9001 does not require a calibration log. If you choose to use a log for your convenience (to ensure calibration/verification gets done), then I'd probably put them on the log so you don't lose track of them.
JoShmo
... We have several pieces of equipment that are under service contracts. We don't do any calibration to them, other than the daily maintenance which is captured on the maintenance logs.
Should these pieces of equipment be listed on the calibration log? ...
Can't say either way without knowing what you're aksing about! You say "service" contracts but that doesn't tell us what equipment they are. Picks and shovels are equipment and you may have them on a service contract, but you can't calibrate them. Gotta know more stuff for a real answer.
Tyler C
Thank you Howste. What other methods have you seen in place of a log?
JoShmo, I appreciate your feedback. I tried not giving too much info as some of the equipment is proprietary to our industry, but I understand that it makes it hard to answer.
One example of the equipment is a marking laser. It is a laser that marks the part number and some technical info along with a few other things. We don't have the capability internally to do anything to this equipment other than use it and do some minor maintenance. In this case, we don't have a service contract for calibration/verification, nor is there anything we can do in this regard. Will the auditors question this?
We do however have a service contract for a different piece of equipment where the tech comes on site and performs any maintenance beyond our ability and any calibration if necessary.
I appreciate all of your replies.
Marc
The bottom line is what howste said - Nothing requires calibration unless it is used to measure something. A marking laser isn't a measurement device.
That said - You have to ensure it marks adequately and accurately. Old story: Label printer toner cartridge ran very low and could not print a human readable label. Have seen same written up as an observation in an audit, but it isn't related to calibration.
You might want to read through this old thread here: What needs to be calibrated? Nothing has changed over the years.
Also see Brad's thread: Calibration Fundamentals: The How-To Thread
The key words are: "Is it a measurement device or check fixture which is used to ensure valid results?"
Marc
JoShmo
Some would have you spending all kinds of cash chasing the holy calibration grail. Now, in the spirit of people helping people (not to spend cash) are you SURE the contractor who does service actually calibrate the stuff they serviced? You may need to get up to speed on what they ACTUALLY do, because they may CALL it calibration but it ain't. Even equipment makers get there story wrong. If you call it "calibration" you can charge more, but I can tell you it's often something less than calibration and isn't even an accurate verification. Trust me...
Tyler C
Thank you for your input Marc. This is a very interesting concept, one which I have never heard before. It may have just shined the light I needed on this.
Just to make sure I understand, anything used at final inspection for pass/fail authority would need to be calibrated, but equipment that is not used to measure would only need verification or validation? Of course, manufacturer requirements would play in here.
Also, thank you for all of the additional resources you have shared. I will look through these as well.
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 - Record requirements for out of calibration tool ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
G ISO 9001 and ISO 17025 - Measuring tools not in calibration system General Measurement Device and Calibration Topics 3
D ISO 9001:2015 Calibration Records - List vs. Software Calibration and Metrology Software and Hardware 6
K Verification instead of calibration?(ISO 9001:2008) Calibration Frequency (Interval) 10
P ISO 9001 Requirements for ISO 17025 Accredited Calibration Laboratory ISO 17025 related Discussions 5
M Sealed in Wax Thread Gages - ISO 9001 Clause 7.6 Calibration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M How to include Gas Measurement Equipment Servicing & Calibration Scope to ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Identification of Calibration Status - ISO 9001 Clause 7.6c Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
kedarg6500 Protection of Data in Calibration Software & ISO 9001 Calibration and Metrology Software and Hardware 4
Q ISO 9001:2008 Calibration of Measurement Equipment Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 58
B Can we neglect (exclude) the ISO 9001 Calibration clause? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
J Calibration Service Suppliers must be certified to ISO 9001? General Measurement Device and Calibration Topics 14
N Minor for no objective evidence in regards to Calibration - Clause 7.6 ISO 9001:2008 Nonconformance and Corrective Action 5
P Calibration - Clause 7.6 of ISO 9001:2000 - Is all this necessary? General Measurement Device and Calibration Topics 42
B ISO 17025 logo & ISO 9001 logo on calibration certificate/report ISO 17025 related Discussions 7
P Certificate of Calibration Suppliers for an ISO 9001 company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
T Calibration of "Working" Tools in Calibration Procedure - ISO 9001:2000 General Measurement Device and Calibration Topics 11
P Plug Gage Calibration Report does not include actual data - ISO 9001:2000 section 7.6 General Measurement Device and Calibration Topics 3
A Are ISO 9001 certified companies required to use ISO17025 facilities for calibration? ISO 17025 related Discussions 13
R ISO 9001 Clause 7.6 - Calibration - Audit finding ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
F ISO 9001:2000 Calibration Audit Checklist General Measurement Device and Calibration Topics 4
G ISO 9001:2000 Calibration Procedures for DMM/Oscilloscopes/Power Supplies General Measurement Device and Calibration Topics 12
S Calibration requirements for ISO 9001:2000 - We do not conduct GRR studies General Measurement Device and Calibration Topics 12
W ISO 9001 Calibration Requirements for Hotel Industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Verification of Calibration Results - ISO 9001 Clause 7.6 General Measurement Device and Calibration Topics 2
W Complying with ISO 9001 Calibration Requirements - Report Before and After Data General Measurement Device and Calibration Topics 12
E ISO 9001 Registered Calibration Facility for tooling & electronic testing equiptment General Measurement Device and Calibration Topics 4
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 2
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q ISO 9001 - Reseller Exclusions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
N ISO 9001 - Training business with fewer than 5 employees ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Opportunity in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
