ISO 9001 Certification Nonconformance Root Cause Help!
bookcat
#41
This whole discussion goes on about the root cause, but lets accept you justed missed it. My question would be, how many non-conforming purchased materials are not handled appropiately?
If this audit finding was raised due to an example of non-conforming purchased materials not handled properly, then the root cause "I just missed it while drafting the procedure" is inadequate. Anyone who identified non-conforming purchased materials should have raised the fact that there was not an applicable procedure available. But why haven't they. If all non-conforming purchased materials were handled appropiately, why raise an audit finding as such an addition to the procedure does not improve quality. As stated before, there might be no necessity to identify all potential sources of nonconforming materials in your procedure.
Just hitting the bolded part. You will have an issue on Control of Non-conforming Product.
#42
What would the issue be? There's no requirement to identify all potential sources of nonconformity. So long as you have a way to deal with nonconforming product, regardless of the source, and you use the method consistently, regardless of the source, there is no issue.
bookcat
#43
Please provide example of a way to deal with nonconforming product without anticipating the sources of it. Let see if you cover everything and you would not have an issue.
sunilbhai
#44
Re: ISO Certification Nonconformance Root Cause Help!
Yes, the truth is that you forgot but underlying that is that there was a 'failure in mapping non conformance from all areas that could arise in the procedure for control of non conforming products'.
Can this be the root cause ... ?
Now please identify as your corrective action if you have any other processes that could potentially get a non conforming product for you to address it in the procedure, purchased products being one among them.
Dear Sir,
Recently we had completed BVQI External Audit and they raised 5nos of Ncr, I closed two ncr but, one of them i have no idea how to close it. The Ncr as under .
NCR 1 : The internal audit plan does not cover the audit plan for MR function. No evidence was found for the internal audit conducted for MR function.
Corrective Action :
Correction
Root Cause/s :
Corrective Actions:
NCR No. 2 The calibration process, infrastructure & training function are found not audited and no evidence of audit reports of these processes was found.
Corrective Action :
Correction
Root Cause/s :
Corrective Actions:
Note : above both function are looking after by me. (Internal audit & calibration ) so , I not cover the MR function & calibration etc function not cover in audit by me. because both work are handle there why i not audited both function & auditor raised the both above ncrs.
Plz help how to close above ncrs.
#45
The auditors reporting of ncr needs to be improved a little - since 'functions' aren't audited, per se. However, they do seem justified and they do raise some points for you to take action on:
How do you audit the processes that you are responsible for, particularly if you do the work? You do have to have your processes audited - calibration would be pretty important - you can't just not audit them because you can't audit yourself! You have to find an alternative auditor - somehow - who isn't responsible for that work and have them audit it. Make sure, they're competent, of course!
qusys
#46
Dear Sir,
Corrective Action :
Correction
Root Cause/s :
Corrective Actions:
Corrective Action :
Correction
Root Cause/s :
Corrective Actions:
To fix the problem you shall individuate the root cause of the problem.
The containement is to put them in the audit plan, while you shall individuate the corrective action after addressing the root cause.
This is the flow.
Some question: What are the reason why you did not audit Management review process ? It is very strange to me.
You can explain well. I have understood that you are the owner of some processes and so you cannot audit them. No problem. You shall appoint another competent auditor to do that, to assure the independency.
Let me know:bigwave:
David Hartman
#47
As an example: A single procedure that reads "All nonconforming material is identified by whatever means appropriate, segregated (where practicable), and dispositioned as necessary." This blanket statement does include nonconforming materials coming from any source and excludes none. Why would you need any more than this? :2cents:
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
G USAS ISO 9001 Certification, online is it worth it? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O ISO 9001 new certification advice request - Develop a QMS from scratch ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
G Is ISO 9001:2015 certification worth it for a company that does only contract manufacturing? Quality Management System (QMS) Manuals 14
J ISO 9001 - How to decide if a company needs or will benefit from certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Implications of Dropping ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S ISO 9001:2015 & ISO 14001 Re-Certification Audit Preparation ISO 14001:2015 Specific Discussions 8
somashekar ISO 9001 Certification, School context - Students are...? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P ISO 9001:2015 Supplier Certification Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
I ISO 9001 and VWAD (Verified-Accredited Wholesale Distributors certification) Coffee Break and Water Cooler Discussions 1
S Responsibilities between government owner and private subcontractor of a power plant seeking ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E ISO 9001 certification of the new plant before start of production ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
N ISO 9001 certification with limited scope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
G Heavy Civil Construction Company Implementing ISO 9001:2015 for Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q Advice on selecting an ISO 9001:2015 Lead Auditor Certification Course ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
A Combined ISO 13485 Certification with ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 23
G Discontinuing ISO 9001 certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 35
S What to expect in an ISO 9001:2015 Lead Auditor Certification Course Training - Internal, External, Online and Distance Learning 9
S ISO 9001:2008 Certification Scope does not mention "manufacturing" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A How soon can I apply for ISO 9001:2015 certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S ISO 9001 Certification Renewal until 2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M ISO 9001 Certification of the QMS of a Certification Body ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Need assistance with ISO 9001 Certification Approach ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
U ISO 9001 Certification for Highly Distributed International Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Can we exclude our subsidiary company from our ISO 9001 certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
N Passed ISO 9001:2008 Certification Audit Covegratulations 9
M Joint ISO TS 29001 and ISO 9001 Certification - One or two certificates? Oil and Gas Industry Standards and Regulations 5
R Changing ISO 9001 Certification Scope Quality Manager and Management Related Issues 4
G Does AS9100 Certificate include ISO 9001 Certification? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
J TS 16949 Certification for 20 out of 70 ISO 9001 Certified Lines IATF 16949 - Automotive Quality Systems Standard 4
H RABQSA ISO 9001:2008 Lead Auditor or ASQ CQA - Which certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Subsidiary - No Managing Director - Is ISO 9001 Certification Possible? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Steps to Preserve ISO 9001 Certification during Corporate Acquisition? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F Setting up a New QMS for Certification when ISO 9001 is about to Change ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
U Compliance with CFR 21 Part 11 vs. ISO 9001 Certification Qualification and Validation (including 21 CFR Part 11) 9
Q Planning Activities After ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Complete Company Restructuring & Impact on ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J What is the most common industry requesting ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Letting go of ISO 9001:2008 certification...What other framework to use? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Query about ISO 9001 Certification Documentation for a Service company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T What happens in an ISO 9001:2008 Re-Certification Audit? General Auditing Discussions 11
T ISO 9001:2011 Certification - Is that legit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
M Adding AS9100C Lead Auditor Certification to an IRCA ISO 9001 LA Certification AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R ISO 9001 Certification - School/University Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Multi-Site Certification to ISO 9001, 14001 and OHSAS 18001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Moving our Distribution Company - ISO 9001 Certification Impact ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
G Reduced Insurance Premium with ISO 14001 or ISO 9001 Certification ISO 14001:2015 Specific Discussions 3
M ISO 9001 Registration Process - Timeline for obtaining ISO 9001 certification Registrars and Notified Bodies 3
K Which Certification - ISO 13485 vs. ISO 9001 ISO 13485:2016 - Medical Device Quality Management Systems 8
T If a company becomes TS 16949 certified does it still need ISO 9001 certification? IATF 16949 - Automotive Quality Systems Standard 12
