ISO 9001 Cl. 8.5.2 and 8.5.4 - Identification in Products
Q
QAMTY
Hi everybody
Regarding to identification of products (see below)
Should this identification be done by using supplier code (label of the product) or must be a label of mine, designed and controlled into my Quality system?
Please feed me back
8.5.2 Identification and traceability
The organization shall use suitable means to identify outputs when it is necessary to ensure the
conformity of products and services.
The organization shall identify the status of outputs with respect to monitoring and measurement
requirements throughout production and service provision.
The organization shall control the unique identification of the outputs when traceability is a
requirement, and shall retain the documented information necessary to enable traceability.
8.5.4 Preservation
The organization shall preserve the outputs during production and service provision, to the extent
necessary to ensure conformity to requirements.
NOTE Preservation can include identification, handling, contamination control, packaging, storage,
transmission or transportation, and protection.
howste
Thaumaturge
No. Or yes. Or maybe. The standard is vague because each organization needs to determine identification needs for their own situation. What do YOU need to ensure product is suitably identified is the question. And the word "label" is not used in the standard anywhere.
BoardGuy
[FONT=&quot]If your system was based on ISO 9001:2008 there is no real change to requirements of these two sections and your current method should work just fine.[/FONT]
Q
QAMTY
Thanks Howste, Gulfman and Boardguy
I think the only think I have to consider, is to write down somewhere
that I comply these clauses by using the tags/labels which come in the packages of the raw material.
wouldn´t be of confusion for employees to have different kind of identifications?
some of them having numbers, letters, barcodes? comparing it with the mine which could be the same label/tag for all the products?
Eredhel
Quality Manager
We, like most probably, use the Job # from our ERP software for traceability. It can be put on a tag, bag, label, traveler, written on a part, et cetera. It's one traceability number with multiples ways to attach it, if that's what you mean. Not sure how you are doing your traceability though.
Coury Ferguson
Moderator here to help
Hi everybody
Please feed me back
8.5.4 Preservation
Let's take this sentence by sentence:
"The organization shall use suitable means to identify outputs when it is necessary to ensure the conformity of products and services."
This would fall under the Organizational Control. The documents/labels that are furnished by the Supplier are the beginning of the traceability. During the organization's process, using a traveler/work order that has a unique identification, would meet the intent. Using stamps (acceptance/rejection)would cover the conformity issue when applied to the specific operation completed.
"The organization shall identify the status of outputs with respect to monitoring and measurement"
This addresses the inspection or operational outputs. The Traveler/Work Order mentioned above would also meet the intent. Reflecting acceptance or rejection.
"The organization shall control the unique identification of the outputs when traceability is a requirement, and shall retain the documented information necessary to enable traceability."
This could the number assigned by your ERP System as long as the number is not used again. This would also involve Serialization, if required, by Contract/Purchase Order.
"The organization shall preserve the outputs during production and service provision, to the extent necessary to ensure conformity to requirements.
NOTE Preservation can include identification, handling, contamination control, packaging, storage, transmission or transportation, and protection
This is addressing the requirements to protect the product throughout the operational processes.
This is just my interpretation, and others may have another interpretation.
BoardGuy
[FONT=&quot]If your current method is working for your organization I would not add additional layers that would add confusion. Within your quality manual or as a stand-a-lone document describe your method for identifying the product and how you maintain its traceability through your production process.[/FONT]
T ISO 9001 8.5.2. - Identification and traceability to Identify Outputs - Services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Stefan Mundt ISO 9001:2015 - 8.5.2 Identification and Traceability Manufacturing and Related Processes 14
M ISO 9001 - 7.5.5 - Meaning of Identification and how it helps Product Preservation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Identification of Calibration Status - ISO 9001 Clause 7.6c Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I Identification of ISO 9001 Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Intention of Identification in ISO 9001 Clause 4.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Customer Property Identification Requirement - ISO 9001 Clause 7.5.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 77
V ISO 9001:2000 to ISO 9001:2008 - Identification in meeting notes. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
eternal_atlas Identification of ISO 9001 Clause to a specific Non-Conformity General Auditing Discussions 7
R Document Revision Identification Requirements - ISO 9001 Clause 4.2.3(c) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Incorporating SOP Into ISO 9001 Procedures - 7.5.3 Identification and traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
O Process Identification - Painless method to comply with ISO 9001 paragraph 4.1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Reports under change management | ISO 13485:2016 & ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 3
K Integrating ISO 9001:2015 with ISO 17025:2017 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 29
T Relationship between ISO 9001 and ISO – IEC BS EN 870079- 34 2020 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Sequence of ISO 9001:2015 Implementation Steps ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Business Continuity Planning in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Brizilla Employee Data Privacy Policy - ISO 9001:2015 requirement(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
P ISO 9001 certification with zero customers? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
A What must be recorded? (ISO 9001:2015, subclause 10.2) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S ISO 9001:2015 vs 21 CFR Part 211 matrix Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
S ISO 9001 implementation in a Gold exporting business ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Does the ISO 9001:2015 standard require a disaster recovery plan or emergency response plan ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Tips and Tricks to understand ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
B ISO 9001 - "Remote Audit Fee" Registrars and Notified Bodies 13
John C. Abnet ISO 9001 4.4.1 "...shall determine the processes needed..." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
D ISO 9001 certificate issued by QMS International for 10 years - legit? Registrars and Notified Bodies 17
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M ISO 9001:2015 and AS6081:2012 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Implementation ISO 9001: 2015 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Audit Checklist for Integrated Management System for ISO 9001:2015, ISO 14001 & OHSAS18001 (IMS) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G National Structural Steel Specification 7th Edition - Do I now have to be audited against ISO 3843-3 as well as ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Sister-company providing parts is only ISO 9001 registered IATF 16949 - Automotive Quality Systems Standard 7
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Does ISO 9001:2015 cover all the requirements of ISO 10012:2003? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Logistic organization and controls - IATF/ISO 9001 audit Nonconformance and Corrective Action 2
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 - Small Shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M ISO 9001:2015 case study sample ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Sample of Nonconformity report for ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Q ISO 9001 8.5.1 - Control of production and service performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Case study help as per ISO 9001: 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
