ISO 9001 Clause 4.2.4 - Records of Conformity question
John Broomfield
#11
I work for an injection molding facility with many customers and many different parts. Every customer has different requirements and many of the requirements are visual/no dimensions. I personally do all of the inspections myself on a sampling schedule for each part. With most parts, I visually inspect and when when it visually does NOT look OK I will measure the parts with calipers to see if the parts are in tolerance. How can I possibly provide records showing conformity and meet ISO requirements? If I were to write down every dimension shown on a drawing for 2 or 3 parts per run, 100% of my time would be occupied running around writing numbers down.
djbeatsent,
This is why you plan your verifications per clause 7.1c, conduct the verifications per the plan and record them per 7.1d.
You may have a general inspection and test plan which you can then tweak for each product, order or customer.
Then you keep the records per 4.2.4.
John
#12
Here's the part of 4.2.4 (ISO 9001:2008) in question:
"Records established to provide evidence of conformity to requirements and of the effective operation of the quality management system shall be controlled."
This doesn't say anything about records of conformity being required, per se; it says that if there are such records, they must be controlled. If you've determined what records are needed for your processes, those records must be controlled.
RDQuality
#14
Please refer to Section 8.2.4 "Evidence of conformity with the acceptance criteria sahll be maintained" In your circumstance, all that is needed is for you to record something as follows: " On 2/23/2011, 34 of 35 widgets passed the tolerance requirements of document 269WR87 Rev. 1 on Contract Number W8934D68 Issue 3.
Again refer to Section 8.2.4 "Records shall indicate the person(s) authorizing release for deliveryto the customer". The person is the one performing the inspection and the customer may be the next stage in the production line or the final custmer, etc. so in addition to recording the number of pieces passing the acceptance criteria, document number, contract number and date, the inspectors name, initial, inspection stamp or other identification must also recorded on the record.
If the inspection gate is located on the traveler, the inspectors initials, signature or stamp affixed on the appropriate traveler gate might be sufficient as long as the traveler is maintained as a record.
RDQuality
#15
Please refer to Section 8.2.4 of the standard. "Evidence of conformity with the acceptance criteria shall be maintained" In your circumstance, I be leive all you have to have as a record is something like this: On 2/1/2011, 34 of 36 widgets passed the dimdntional tolerance requirements of document 34XK 2874 Rev 2 Contract Number 35683MVW. the contract number may be optional. In addition, please refer to Section 8.2.4 again: " Records shall indicate the person(s) authorizing release of the product for delivery to the customer." The person is the inspector and the customer could be the next manufacturing operation or the actual cusomter. So the inspector must also include his(her) signature, iniitials, inspection stamp ro other identifier on the record.
If the inspection gate is depicted on the traveler and a copy of the traveler is maintained a s arecord, the inspectors signature, initials, inspection stamp or other identifier could be affixed to the traveler to confirm the required inspection has been performed.
I hope this has helped.
S ISO 9001 Clause 8.2.3 - Review of the requirements for products and services in a Cafe ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Scope of ISO 9001 clause 10.2 in the product life cycle ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO 9001 Clause 8.3 Design for an education services provider ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001 Clause 8.3 - Design & Development for training course center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
S ISO 9001:2015 Clause 9.3.2 - MR (Management Review) - Adequacy of resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S ISO 9001:2015 Clause 8.7 Control of Nonconforming Outputs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
qualprod ISO 9001 Clause 9.1 - Monitoring measurement analysis and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D ISO 9001:2015 Clause 8.4.3 "Information for External Providers" buying from online retailers. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Records required for ISO 9001 clause 7.1.5.1 - Fitness for purpose of the monitoring and measurement resources ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E ISO 9001:2015 Clause 10.2.2 - Evidence of all nonconformities and actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
qualprod ISO 9001:2015 Clause 8.3 - Is it possible to exclude one product but include it in other? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
qualprod Only manufacturing, non applicable - ISO 9001 Clause 8.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A What ISO 9001:2015 clause could be used to write nonconformance for not updating licensed driver list? General Auditing Discussions 8
MichaelDRoach ISO 9001:2015 Clause 9.3.2c)3) - What process or processes is this focused on? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
H Clause 8.5.5 and Clause 8.6: which one should be coming first? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
GStough ISO 9001:2015 Clause 8.4.2 - Who Is The "Its" in (a)..The Supplier or Their Supplier? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Which ISO 9001 Clause applies to "Procedures are outdated"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 31
R ISO 9001:2015 Clause 7.1.5.2 - Is Measurement traceability applicable? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q How to comply with ISO 9001:2015 Clause 7.4 Communication ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
qualprod ISO 9001:2015 - Right method to address clause 6.1? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J ISO 9001:2015 Cl. 8.1 - 'and to implement the actions determined in clause 6' ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Referencing ISO 9001:2015 clause for Audit General Auditing Discussions 10
P Design and Development Clause ISO 9001:2015 Exclusion for Medical Services Design and Development of Products and Processes 3
K ISO 9001:2015 clause 9.2.2 a. - Define the audit criteria and scope Internal Auditing 2
K ISO 9001:2015 Clause 5.1.2 Customer Focus (a) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Values - ISO 9001 2015 - Clause 4.1 Note 3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to 3rd Party Audit ISO 9001 Clause 7.1.6 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M What do you do for ISO 9001 clause 9.1? Key Performance Indicators ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A How to approach ISO 9001:2015 Clause 7.1.6 when 3rd Party Auditing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K What can be considered a "Post Delivery Activity" (ISO 9001:2015 Clause 8.5) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A ISO 9001:2015 Clause 9.3.2 - Management Review Inputs must be Documented? Management Review Meetings and related Processes 15
A ISO 9001:2015 Clause 7.1.1.b refers to ....? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S What do I have to do for ISO 9001:2015 Clause 6.2 - Planning ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S What do I have to do for ISO 9001:2015 Clause 4.1 and 4.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Does the word "claim" in ISO 9001 Clause 8.2.2 mean "requirement"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q Drawings from Client - ISO 9001:2008 Clause 4.2.3 or 7.5.4? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W ISO 9001:2015 Clause 7.5.2 - Is Review and Approval applicable to Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 30
B Clarification of ISO 9001:2015 Clause 8.5.6 Control of Changes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S ISO 9001:2015 Clause 8.2.1 e) - Requirements for Contingency Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Application of ISO 9001:2015 Clause Interpretations for Service Industries Service Industry Specific Topics 2
